<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-NOAA3 - Font size]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">just installed MMM-NOAA3 module and every thing is fine so far - great module.</p>
<p dir="auto">However, I think the font size is far too small. I can hardly read the numbers and letters. Can someone help me how I can increase the font size? I know there is a custom css. but Ihonestly, I m not really familiar with that.</p>
<p dir="auto">What do I have to add/to change in order to increase the size of the letters and numbers - only for this module?</p>
<p dir="auto">Thanks !<br />
Best regards!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9124/mmm-noaa3-font-size</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 15:06:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9124.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Nov 2018 10:33:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-NOAA3 - Font size on Fri, 08 Mar 2019 17:45:35 GMT]]></title><description><![CDATA[<p dir="auto">@myself: ;-)<br />
Found the solution by myself. I had the “.xsmall” part copied over from the original css file in my custom.css</p>
<p dir="auto"><img src="/assets/uploads/files/1552067080889-b2e5d39d-c6ac-4949-acea-854b9ff07e5e-grafik.png" alt="0_1552067080823_b2e5d39d-c6ac-4949-acea-854b9ff07e5e-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This one is used to scale the font size…</p>
]]></description><link>https://forum.magicmirror.builders/post/53951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53951</guid><dc:creator><![CDATA[Medo]]></dc:creator><pubDate>Fri, 08 Mar 2019 17:45:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA3 - Font size on Fri, 08 Mar 2019 14:47:15 GMT]]></title><description><![CDATA[<p dir="auto">I also have a problem with the font size of MMM-NOAA3<br />
…</p>
<p dir="auto">Can anyone tell me please, where to customize the font size of this lower part of the module:</p>
<p dir="auto"><img src="/assets/uploads/files/1552056368163-4aeaf7c0-984f-4270-a38f-184b577b1762-grafik.png" alt="0_1552056368637_4aeaf7c0-984f-4270-a38f-184b577b1762-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I tried every part of the original css file in my custom.css but nothing had the right effect…</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/53938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53938</guid><dc:creator><![CDATA[Medo]]></dc:creator><pubDate>Fri, 08 Mar 2019 14:47:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA3 - Font size on Fri, 23 Nov 2018 15:19:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vortex" aria-label="Profile: vortex">@<bdi>vortex</bdi></a> ahhhhhhhhh yeah that one has been a thorn in my side… I will look at it tonight and see what’s going on.  Sounds to me like you don’t have all the images in your image directory ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/47210</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47210</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 23 Nov 2018 15:19:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA3 - Font size on Fri, 23 Nov 2018 12:04:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">thanks for help. some icons re-appeared, some are still missing.<br />
I m using weatherbit as provider.</p>
<p dir="auto">I still have issues with the font size - I do not know what I have to change.</p>
<p dir="auto">Best regards!</p>
]]></description><link>https://forum.magicmirror.builders/post/47202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47202</guid><dc:creator><![CDATA[vortex]]></dc:creator><pubDate>Fri, 23 Nov 2018 12:04:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA3 - Font size on Wed, 21 Nov 2018 19:42:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vortex" aria-label="Profile: vortex">@<bdi>vortex</bdi></a> Not sure what that happened because the only thing updated was the moon data…</p>
<p dir="auto">What provider are you using?</p>
]]></description><link>https://forum.magicmirror.builders/post/47120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47120</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 21 Nov 2018 19:42:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA3 - Font size on Tue, 20 Nov 2018 12:38:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">thanks for your reply.  Unfortunately I am not very familiar with this. Can you please tell me which parameter i ahve to change to increase font size?<br />
Apart from that, I di a git pull update yesterday (MM showed a notification about an update) and now I do not have the icons anymore… what can I do now?</p>
<p dir="auto">Thanks!<br />
Best regards</p>
]]></description><link>https://forum.magicmirror.builders/post/47058</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47058</guid><dc:creator><![CDATA[vortex]]></dc:creator><pubDate>Tue, 20 Nov 2018 12:38:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NOAA3 - Font size on Tue, 20 Nov 2018 03:30:42 GMT]]></title><description><![CDATA[<p dir="auto">In the css files you can see each classList and go into your css file and adjust the font sizes :)<br />
There are a few places and putting them all in your custom.css would take a while…</p>
<p dir="auto">So make a backup copy of the css you are want to change and have at it ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/47044</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47044</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 20 Nov 2018 03:30:42 GMT</pubDate></item></channel></rss>
