<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Timer based on python script]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I’ve just got my MM up and running but sadly struggle with making a timer showing how long until screen goes off.</p>
<p dir="auto">My MM has python script that controls when to turn on/off screen based on some sensors and time. It starts internal timer 60s when there is nobody in front of the mirror, turn screen off when timer goes off and resets it when it registers movement.</p>
<p dir="auto">Although I’m terrible with JS I have somehow managed to create new module, that simply show remaining time.</p>
<p dir="auto">I’d love to ask for some tips how to get get remaining time from python script to MM module. So far my only idea was to write the number into a file and let the module read it, but I’m sure there must be better way as this just sounds terrible considering I’d like to update it at least once a second.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9134/timer-based-on-python-script</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 11:18:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9134.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Nov 2018 21:10:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Timer based on python script on Wed, 21 Nov 2018 10:56:24 GMT]]></title><description><![CDATA[<p dir="auto">This is perfect!</p>
<p dir="auto">I need few hours on google now, to at least begin to comprehend what you just wrote…</p>
<p dir="auto">Thank you!! :) I’ll post when I get it somehow work (or get stuck :D )</p>
]]></description><link>https://forum.magicmirror.builders/post/47108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47108</guid><dc:creator><![CDATA[scotchi]]></dc:creator><pubDate>Wed, 21 Nov 2018 10:56:24 GMT</pubDate></item><item><title><![CDATA[Reply to Timer based on python script on Wed, 21 Nov 2018 10:51:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scotchi" aria-label="Profile: scotchi">@<bdi>scotchi</bdi></a><br />
Hmmm. I think controlling external script in nodeJs with child-process is better, but choice is yours. :D<br />
As you said, via HTTP could be one solution.</p>
<ul>
<li>Your Python(Python 3) sender sript :</li>
</ul>
<pre><code>import urllib.request
contents = urllib.request.urlopen("http://localhost:8080/GATEWAY?something").read()
<ul>
<li>MM module
<ul>
<li>your module   XXXX.js</li>
</ul>
</li>
</ul>
<pre><code>...
socketNotificationReceived: function(noti, payload) {
  if (noti == "RECEIVED_DATA") {
    console.log(payload)
<ul>
<li>it’s node_helper.js</li>
</ul>
<pre><code>const NodeHelper = require("node_helper")
const bodyParser = require("body-parser")
  start: function() {
    this.expressApp.use(bodyParser.json())
    this.expressApp.use(bodyParser.urlencoded({extended: true}))
    this.expressApp.get("/GATEWAY", (req, res) =&gt; {
      this.sendSocketNotification("RECEIVED_DATA", req.body)
      res.status(200).send({status: 200})
<p dir="auto">If you think handling <code>node_helper.js</code> is somehow difficult, consider <code>MMM-NotificationTrigger</code>. It has already a feature to receive from HTTP request then relay to other module via notification.</p>
]]></description><link>https://forum.magicmirror.builders/post/47107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47107</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 21 Nov 2018 10:51:02 GMT</pubDate></item><item><title><![CDATA[Reply to Timer based on python script on Wed, 21 Nov 2018 10:49:03 GMT]]></title><description><![CDATA[<p dir="auto">Thank for reply, but you can’t used it for <em>already running</em> script, can you? What I understood is, that is runs new py script.</p>
<p dir="auto">Although it would probably work, I was looking for something that can listen/request data from already running script.</p>
<p dir="auto">I was hoping I can call some function <strong>MagicFunction(localhost, port?, data)</strong> from python… and my module could have something like <strong>listen(localhost,port?); .onReceive(){ data = fromPython; }</strong></p>
<p dir="auto">I hope it makes sense.</p>
<p dir="auto">ps: I understand there are better and simpler solutions how to turn on/off monitor, but this is supposed to be only beginning of what I’m trying to accomplish</p>
<p dir="auto">EDIT: I just discovered there is “<a href="http://Socket.IO" target="_blank" rel="noopener noreferrer nofollow ugc">Socket.IO</a>”. It sounds like exactly what I’m looking for. But honestly the more I read about it the more I’m confused how would I used it in my module.</p>
]]></description><link>https://forum.magicmirror.builders/post/47106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47106</guid><dc:creator><![CDATA[scotchi]]></dc:creator><pubDate>Wed, 21 Nov 2018 10:49:03 GMT</pubDate></item><item><title><![CDATA[Reply to Timer based on python script on Tue, 20 Nov 2018 22:21:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scotchi" aria-label="Profile: scotchi">@<bdi>scotchi</bdi></a><br />
I’m not with my pc at this moment, so I cannot<br />
give you the details, but google these;</p>
<ul>
<li>nodejs child-process exec and spawn</li>
</ul>
<p dir="auto">Your python script might spit stdout as a result of running. exec or spawn can control runnig and termination of child-process(e.g your script) and get stdout or stdere from it. You can make to display those in your mm module.</p>
]]></description><link>https://forum.magicmirror.builders/post/47084</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47084</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 20 Nov 2018 22:21:44 GMT</pubDate></item></channel></rss>
