<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM booting to black]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Still getting to know this device.  I had it working exactly the way I wanted to (almost - PIR still isn’t working, but thats another story).<br />
My current problem is I have MMM-NFL in the middle screen and want to use Carousel to change it out to MMM-NHL every 5 minutes or so.  Installed the Carousel module, rebooted and after the ‘road’ picture, instead of opening the   usual screen, it goes to black and I cannot recover from it.  I tried opening the config.js but the screen jumps to black after a few seconds.  I just need to get access to find the error.<br />
Suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9143/mm-booting-to-black</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 22:02:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9143.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Nov 2018 18:13:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM booting to black on Sun, 25 Nov 2018 23:16:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwleo" aria-label="Profile: dwleo">@<bdi>dwleo</bdi></a> Glad it works now. Cheers!</p>
]]></description><link>https://forum.magicmirror.builders/post/47329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47329</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Sun, 25 Nov 2018 23:16:36 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Sun, 25 Nov 2018 19:45:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwleo" aria-label="Profile: dwleo">@<bdi>dwleo</bdi></a> That was a convoluted effort but it did the trick.<br />
Thanks lavolp3</p>
]]></description><link>https://forum.magicmirror.builders/post/47310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47310</guid><dc:creator><![CDATA[dwleo]]></dc:creator><pubDate>Sun, 25 Nov 2018 19:45:37 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Sat, 24 Nov 2018 22:03:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwleo" aria-label="Profile: dwleo">@<bdi>dwleo</bdi></a> OK.  I got in and will try to edit the config.js file somehow.</p>
]]></description><link>https://forum.magicmirror.builders/post/47263</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47263</guid><dc:creator><![CDATA[dwleo]]></dc:creator><pubDate>Sat, 24 Nov 2018 22:03:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Sat, 24 Nov 2018 18:46:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> cannot get pm stop all to work.  It gives ‘process stop all not found’.<br />
As to ssh, all derivatives  of this, either command line or remote, requires some additions to Raspberry and I cannot get that as I cannot get a command line.<br />
All I need is to stop the boot up process just prior to MM booting up.</p>
]]></description><link>https://forum.magicmirror.builders/post/47257</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47257</guid><dc:creator><![CDATA[dwleo]]></dc:creator><pubDate>Sat, 24 Nov 2018 18:46:57 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Fri, 23 Nov 2018 11:12:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwleo" aria-label="Profile: dwleo">@<bdi>dwleo</bdi></a> You need to access the mirror from another device to “ssh into it”. Read the info from the link.<br />
Will make things easier.</p>
<p dir="auto">Regarding pm2, you can find out the name of the process entering</p>
<pre><code>pm2 list
<p dir="auto">or just try killing the process using</p>
<pre><code>pm2 stop all
<p dir="auto">Not sure if this works.</p>
]]></description><link>https://forum.magicmirror.builders/post/47201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47201</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 23 Nov 2018 11:12:46 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Thu, 22 Nov 2018 22:40:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a><br />
Also while booting up, in the ‘road pic’  phase, I got to click at the menu bar for  the cmd screen and typed in pm2 stop mm.  Just before the screen went black I got an error msg stating ‘process mm not found’.  Then it quickly went to black.</p>
]]></description><link>https://forum.magicmirror.builders/post/47182</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47182</guid><dc:creator><![CDATA[dwleo]]></dc:creator><pubDate>Thu, 22 Nov 2018 22:40:22 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Thu, 22 Nov 2018 21:46:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a><br />
OK.  I cannot ssh directly into the mirror.  Once it goes through the bootup process, it goes black and I cannot get out of it.  If I could, I could probably correct the error.</p>
]]></description><link>https://forum.magicmirror.builders/post/47178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47178</guid><dc:creator><![CDATA[dwleo]]></dc:creator><pubDate>Thu, 22 Nov 2018 21:46:41 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Thu, 22 Nov 2018 20:34:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwleo" aria-label="Profile: dwleo">@<bdi>dwleo</bdi></a> Oh boy, you’re really new to this :-)<br />
How can i describe?</p>
<p dir="auto"><a href="https://www.raspberrypi.org/documentation/remote-access/ssh/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/remote-access/ssh/</a></p>
<p dir="auto">You’ve got a lot to learn young padawan</p>
]]></description><link>https://forum.magicmirror.builders/post/47173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47173</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 22 Nov 2018 20:34:21 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Thu, 22 Nov 2018 20:32:48 GMT]]></title><description><![CDATA[<p dir="auto">Thanks lavolp3,<br />
I am too new on this.  What is ssh?</p>
]]></description><link>https://forum.magicmirror.builders/post/47172</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47172</guid><dc:creator><![CDATA[dwleo]]></dc:creator><pubDate>Thu, 22 Nov 2018 20:32:48 GMT</pubDate></item><item><title><![CDATA[Reply to MM booting to black on Thu, 22 Nov 2018 20:31:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwleo" aria-label="Profile: dwleo">@<bdi>dwleo</bdi></a> can you ssh into the mirror?<br />
If you access the mirror directly type in</p>
<pre><code>pm2 stop mm
<p dir="auto">to stop the mirror.<br />
Lokk for a response that the mm fork has been stopped. If you got an error, look for the process name using</p>
<pre><code>pm2 status
<p dir="auto">However I think it’s best to ssh into the mirror.</p>
<p dir="auto">As soon as you have control :-) go into the MagicMirror folder and type</p>
<pre><code>npm run config:check
<p dir="auto">Look if there is an error message, go into the config.js and try to solve it.<br />
If you don’t know what to do, post your config withoit sensitive information</p>
]]></description><link>https://forum.magicmirror.builders/post/47171</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47171</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 22 Nov 2018 20:31:31 GMT</pubDate></item></channel></rss>
