<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hot to set MagicMirror not on top?]]></title><description><![CDATA[<p dir="auto">I need to re-use a VLC window while using MagicMirror, but although I choosed the ‘Always On Top’ option in VLC MM keeps staying in front of it?</p>
<p dir="auto">Can I know please <a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> how to change this setting in MagicMirror? :grimacing_face:</p>
]]></description><link>https://forum.magicmirror.builders/topic/9155/hot-to-set-magicmirror-not-on-top</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 19:07:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9155.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Nov 2018 14:21:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hot to set MagicMirror not on top? on Fri, 25 Jan 2019 15:17:03 GMT]]></title><description><![CDATA[<p dir="auto">the design is the MM owns the screen… so you should open a window and show the vlc thru the mirror, i think there is already something that does this…</p>
]]></description><link>https://forum.magicmirror.builders/post/50816</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50816</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 25 Jan 2019 15:17:03 GMT</pubDate></item><item><title><![CDATA[Reply to Hot to set MagicMirror not on top? on Fri, 25 Jan 2019 14:03:44 GMT]]></title><description><![CDATA[<p dir="auto">…? :thinking_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/50806</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50806</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Fri, 25 Jan 2019 14:03:44 GMT</pubDate></item></channel></rss>
