<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clocks have two different times?]]></title><description><![CDATA[<p dir="auto">When I first got my MagicMirror up and running I wanted to change the clock to 12 hour format<br />
I was able to get the top left clock to 12 hours and right clock with the weather as well. Unfortunately the clock with the weather is about 30 minutes different from each other.  How do I go about fixing that? Also I changed the weather to fahrenheit but the up coming weather is still in celcius. How do I fix these?</p>
<p dir="auto">Thanks for the help</p>
]]></description><link>https://forum.magicmirror.builders/topic/9167/clocks-have-two-different-times</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 13:26:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9167.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Nov 2018 02:37:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clocks have two different times? on Thu, 29 Nov 2018 01:57:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbs86" aria-label="Profile: tbs86">@<bdi>tbs86</bdi></a></p>
<p dir="auto">You’re welcome, mate. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/47476</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47476</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 29 Nov 2018 01:57:41 GMT</pubDate></item><item><title><![CDATA[Reply to Clocks have two different times? on Thu, 29 Nov 2018 01:56:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a> Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/47475</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47475</guid><dc:creator><![CDATA[tbs86]]></dc:creator><pubDate>Thu, 29 Nov 2018 01:56:49 GMT</pubDate></item><item><title><![CDATA[Reply to Clocks have two different times? on Thu, 29 Nov 2018 01:45:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbs86" aria-label="Profile: tbs86">@<bdi>tbs86</bdi></a> said in <a href="/post/47449">Clocks have two different times?</a>:</p>
<p dir="auto">Is there a way to fix the weather forecast to fahrenheit?</p>
<p dir="auto">in your config.js, near the top:</p>
<p dir="auto"><code>units: "imperial",</code> should do it.</p>
]]></description><link>https://forum.magicmirror.builders/post/47473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47473</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 29 Nov 2018 01:45:07 GMT</pubDate></item><item><title><![CDATA[Reply to Clocks have two different times? on Wed, 28 Nov 2018 16:07:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> haha wow i feel like a idiot. Is there a way to fix the weather forecast to fahrenheit?</p>
]]></description><link>https://forum.magicmirror.builders/post/47449</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47449</guid><dc:creator><![CDATA[tbs86]]></dc:creator><pubDate>Wed, 28 Nov 2018 16:07:50 GMT</pubDate></item><item><title><![CDATA[Reply to Clocks have two different times? on Wed, 28 Nov 2018 08:48:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbs86" aria-label="Profile: tbs86">@<bdi>tbs86</bdi></a> said in <a href="/post/47437">Clocks have two different times?</a>:</p>
<p dir="auto">actually the clock above current weather is stuck on the same time and does not change.</p>
<p dir="auto">Current weather shows sunrise / sunset time, not current time ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/47441</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47441</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Wed, 28 Nov 2018 08:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to Clocks have two different times? on Wed, 28 Nov 2018 05:03:39 GMT]]></title><description><![CDATA[<p dir="auto">actually the clock above current weather is stuck on the same time and does not change.</p>
]]></description><link>https://forum.magicmirror.builders/post/47437</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47437</guid><dc:creator><![CDATA[tbs86]]></dc:creator><pubDate>Wed, 28 Nov 2018 05:03:39 GMT</pubDate></item></channel></rss>
