<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PM2 logs]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">when i call pm2 logs mm i get these Errors:<br />
(node:24612) DeprecationWarning: sys is deprecated. Use util instead.<br />
{ Error: listen EADDRINUSE :::8080<br />
at Object.exports._errnoException (util.js:1008:11)<br />
at exports._exceptionWithHostPort (util.js:1031:20)<br />
at Server._listen2 (net.js:1253:14)<br />
at listen (net.js:1289:10)<br />
at Server.listen (net.js:1385:5)<br />
at new Server (/home/pi/MagicMirror/js/server.js:17:9)<br />
at /home/pi/MagicMirror/js/app.js:129:17<br />
at loadConfig (/home/pi/MagicMirror/js/app.js:42:4)<br />
at App.start (/home/pi/MagicMirror/js/app.js:115:3)<br />
at Object. (/home/pi/MagicMirror/js/electron.js:81:6)<br />
code: ‘EADDRINUSE’,<br />
errno: ‘EADDRINUSE’,<br />
syscall: ‘listen’,<br />
address: ‘::’,<br />
port: 8080 }<br />
(node:28564) DeprecationWarning: sys is deprecated. Use util instead.<br />
port: 8080 }<br />
(node:1309) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:18091) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:18949) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:1319) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:2450) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:20215) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:26201) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:23501) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:23793) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:24045) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:29144) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:27949) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:31805) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:1372) DeprecationWarning: sys is deprecated. Use util instead.<br />
(node:1331) DeprecationWarning: sys is deprecated. Use util instead.</p>
<p dir="auto">Is this an error on the pm2 or the MM himself?</p>
<p dir="auto">Thanks for help<br />
Daniel</p>
]]></description><link>https://forum.magicmirror.builders/topic/917/pm2-logs</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 11:15:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/917.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Nov 2016 21:08:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PM2 logs on Mon, 07 Nov 2016 10:47:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostfilinchen" aria-label="Profile: ostfilinchen">@<bdi>ostfilinchen</bdi></a> Working on it, testing as we speak :D</p>
]]></description><link>https://forum.magicmirror.builders/post/7622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7622</guid><dc:creator><![CDATA[RedNax]]></dc:creator><pubDate>Mon, 07 Nov 2016 10:47:20 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 logs on Thu, 03 Nov 2016 11:57:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a>,</p>
<p dir="auto">i have done it and there are no Errors. But is it normal that the mirror stop working, if any module get an error. The module MMM-Soccer produces an error and then the module MMM-WurnderGround stop working.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a>: is it possible to debug the module?</p>
]]></description><link>https://forum.magicmirror.builders/post/7500</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7500</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Thu, 03 Nov 2016 11:57:34 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 logs on Tue, 01 Nov 2016 22:29:48 GMT]]></title><description><![CDATA[<p dir="auto">Flush the logs:<br />
‘<code>pm2 flush</code>’</p>
<p dir="auto">Restart the pi:<br />
‘<code>sudo reboot</code>’</p>
<p dir="auto">Check the pm2 logs again:<br />
‘<code>pm2 logs</code>’</p>
]]></description><link>https://forum.magicmirror.builders/post/7456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7456</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 01 Nov 2016 22:29:48 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 logs on Tue, 01 Nov 2016 21:46:57 GMT]]></title><description><![CDATA[<p dir="auto">U mean to open the mm-webpage?</p>
<p dir="auto">I restart the pi and then i call pm2 logs mm and it shows me this log. The mirror by the way starts.</p>
]]></description><link>https://forum.magicmirror.builders/post/7454</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7454</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Tue, 01 Nov 2016 21:46:57 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 logs on Tue, 01 Nov 2016 21:44:04 GMT]]></title><description><![CDATA[<p dir="auto">Did you try to launch it multiple times? That’s what pm2 is recording.</p>
]]></description><link>https://forum.magicmirror.builders/post/7453</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7453</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 01 Nov 2016 21:44:04 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 logs on Tue, 01 Nov 2016 21:42:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> i only have the mm on Port 8080. How can i check, what Use the Port 8080? If i open the address <a href="http://raspberrypi:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://raspberrypi:8080</a> i only See the MagicMirror…</p>
]]></description><link>https://forum.magicmirror.builders/post/7452</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7452</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Tue, 01 Nov 2016 21:42:36 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 logs on Tue, 01 Nov 2016 21:16:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostfilinchen" aria-label="Profile: ostfilinchen">@<bdi>ostfilinchen</bdi></a> said in <a href="/post/7447">PM2 logs</a>:</p>
<p dir="auto">{ Error: listen EADDRINUSE :::8080<br />
… snip …<br />
port: 8080 }</p>
<p dir="auto">You’re telling Mm to use a port that’s already being used for something else. If you actually have something that’s using port 8080, change Mm to use something else. It’s in the config.js file. For example, set it to 8585 …</p>
<p dir="auto">If you don’t have or know what’s on port 8080, you have a bigger problem than either pm2 or MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/7449</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7449</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 01 Nov 2016 21:16:48 GMT</pubDate></item></channel></rss>
