<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-DarkSkyForecast - Yet ANOTHER weather module]]></title><description><![CDATA[<p dir="auto">Hi folks</p>
<p dir="auto"><strong>UPDATE 28-FEB-2021</strong><br />
This module has been replaced with <a href="https://forum.magicmirror.builders/topic/14717/mmm-openweatherforecast-replacement-for-mmm-darkskyforecast">MMM-OpenWeatherForecast</a>.  Apple bought Dark Sky and decided to stop allowing free access to their weather API (Thanks Apple). OpenWeatherForecast does everything this module does plus a bunch of improvements you’ve all been asking for.</p>
<p dir="auto"><strong>UPDATE 9-Dec-2018</strong><br />
I’ve updated this module to use the Nunjucks HTML templating system, which means as of verison 1.6, this module requires MagicMirror version 2.2.0 or later.  If you are running on an older version of MagicMirror, then please use v1.5 of the module, which you can download here:</p>
<p dir="auto"><a href="https://github.com/jclarke0000/MMM-DarkSkyForecast/releases/tag/v1.5" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jclarke0000/MMM-DarkSkyForecast/releases/tag/v1.5</a></p>
<p dir="auto">Instead of using <code>git clone</code> to get the module code, download the zip file from the link above and extract the contents of the ZIP file to  your modules directory.  This zip puts all of the files into a folder named <code>MMM-DarkSkyForecast-1.5</code>. I don’t know if it’s necessary to rename this directory to just <code>MMM-DarkSkyForecast</code> or if it will work as-is.  Run <code>npm install</code> as normal in the directory to install all of the dependencies.</p>
<p dir="auto"><strong>END UPDATES</strong></p>
<p dir="auto">I had been using my old weather module for quite some time, but now that Weather Underground no longer allows free API access, I’ve needed a replacement.</p>
<p dir="auto">The great news is that there are SO many weather modules available now, but given that each of them behaved a little differently, it would have taken a considerable amount of time to go through and evaluate each one to see if it suited my needs.</p>
<p dir="auto">I instead decided to use that time to write one that exactly matches my needs.  I’ll admit it is quite possible that another weather module does everything mine does and perhaps more, but being the lazy ass that I am, I didn’t take the time to check :)</p>
<p dir="auto">If you find it useful, then here it is.</p>
<p dir="auto">[card:jclarke0000/MMM-DarkSkyForecast]</p>
<p dir="auto">It supports current conditions, hourly and daily forecasts and is highly configurable. It includes a handful of icon sets and even supports Dark Sky’s Skycons animated icon set.</p>
<p dir="auto">If you don’t already have one, you’ll need to get a Dark Sky API key from here:<br />
<a href="https://darksky.net/dev" target="_blank" rel="noopener noreferrer nofollow ugc">https://darksky.net/dev</a></p>
<p dir="auto">You’ll also need the latitude and longitude of the region for which you want to display weather conditions.  You can find that here:<br />
<a href="https://www.latlong.net/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.latlong.net/</a></p>
<p dir="auto">Screenshot:<br />
<img src="/assets/uploads/files/1543586346526-forecast-layouts.png" alt="0_1543586344458_forecast-layouts.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Included Icon sets<br />
<img src="/assets/uploads/files/1543586383621-iconsets-resized.png" alt="0_1543586376325_iconsets.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This does not share any code with my old MMM-MyWeather module.  This is a completely new module from scratch that is a bit more organized code-wise and outputs HTML markup better suited for multiple layouts.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9181/mmm-darkskyforecast-yet-another-weather-module</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Jul 2026 08:03:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9181.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Nov 2018 14:12:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Sun, 28 Feb 2021 14:44:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swvalenti" aria-label="Profile: swvalenti">@<bdi>swvalenti</bdi></a>  <a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a></p>
<p dir="auto">I’ve released the module for everyone. To get the latest code, you’ll need to navigate to your installed MMM-OpenWeatherForecast directory and execute:</p>
<p dir="auto"><code>git pull</code></p>
<p dir="auto">followed by</p>
<p dir="auto"><code>npm install</code><br />
(depencies have changed, so this step is important!)</p>
<p dir="auto">Optionally you can run <code>npm prune</code> to remove old dependencies that are no longer used, but not necessary,</p>
<p dir="auto">Restart MM and you should be good to go.</p>
]]></description><link>https://forum.magicmirror.builders/post/89002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89002</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Sun, 28 Feb 2021 14:44:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Sun, 28 Feb 2021 12:19:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: bkeyport">@<bdi>bkeyport</bdi></a> Glad it’s working for you!  Thanks for pointing out the typo.  Will fix.</p>
]]></description><link>https://forum.magicmirror.builders/post/88996</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88996</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Sun, 28 Feb 2021 12:19:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Sun, 28 Feb 2021 12:18:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swvalenti" aria-label="Profile: swvalenti">@<bdi>swvalenti</bdi></a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swvalenti" aria-label="Profile: swvalenti">@<bdi>swvalenti</bdi></a> said in <a href="/post/88803">MMM-DarkSkyForecast - Yet ANOTHER weather module</a>:</p>
<p dir="auto">Can the throughout the week line up better with the hourly above like the icons and other data sets?</p>
<p dir="auto">You can do this, but you’ll need to do it in your custom CSS.  Here’s why:</p>
<p dir="auto">The old module used a single table for both weekly and hourly forecast.  But with the additions I have made in this module, you can have different columns for your hourly forecast versus what you have for weekly, and therefore they are two separate tables, meaning they might self-adjust to the content in the columns differently, even if you have the same columns in both.</p>
<p dir="auto">I can’t enforce a uniform column width because a) I don’t know how many columns you’ll be using and b) I don’t know the width of the master region in Magic Mirror that you are using.</p>
<p dir="auto">So long winded way of saying that once you have configured your tables just the way you like, if you want them to be uniform, you need to take a the extra step to set explicit pixel widths for your columns  in your custom CSS file.  Here’s an example of what that could look like:</p>
<pre><code>.MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item .time,
.MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item .day-name {
  width: 105px;
.MMM-OpenWeatherForecast .wrapper.table .forecast-container .header-row .weather-icon-header,
.MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item .forecast-icon-container {
  width: 80px;
.MMM-OpenWeatherForecast .wrapper.table .forecast-container .header-row .temperature-header,
.MMM-OpenWeatherForecast .wrapper.table .forecast-container .forecast-item .temperature-container {
  width: 100px;
  white-space: nowrap;
<p dir="auto">Prefixing your CSS with <code>.MMM-OpenWeatherForecast .wrapper.table</code> limits your rules to just the <code>MMM-OpenWeatherForecast</code> module and specifically <code>.wrapper.table</code> will limit your rules to the table layout version.  This way if you change your mind and switch to the tiled layout, it won’t be affected by the rules you set for the table layout.</p>
<p dir="auto">If you take a look at <code>mmm-openweather-forecast.njk</code> you can figure out what the class names are for each specific column, so you can target specific columns.  I’ve given pretty much everything a unique class so you should be able to style everything exactly as you need.  Make sure you style every column in your tables.  If even one column is left unstyled you might get the same problem with them not lining up.</p>
<p dir="auto">I hope this helps!</p>
]]></description><link>https://forum.magicmirror.builders/post/88995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88995</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Sun, 28 Feb 2021 12:18:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Tue, 23 Feb 2021 07:56:15 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f - OpenWeather is looking good here… solid as a rock.</p>
<p dir="auto">Thanks!</p>
<p dir="auto">(suggestions/questions deleted as I’m an idiot that don’t know how to read config instructions completely!)</p>
]]></description><link>https://forum.magicmirror.builders/post/88809</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88809</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 23 Feb 2021 07:56:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 22 Feb 2021 22:40:38 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f Just a FYI for your next update on OpenWeather -</p>
<p dir="auto">“apikey needs to be <strong>secified</strong> as a String, while latitude and longitude can be specified as either a String or a Number. Both work fine.” Minor typo. :)</p>
<p dir="auto">Trying it out myself.</p>
]]></description><link>https://forum.magicmirror.builders/post/88808</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88808</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 22 Feb 2021 22:40:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 22 Feb 2021 19:50:06 GMT]]></title><description><![CDATA[<p dir="auto">Got it up and running looks sharp, I have one minor request as my OCD kicks in.  Can the throughout the week line up better with the hourly above like the icons and other data sets?  See picture, hope I made sense.</p>
<p dir="auto"><img src="/assets/uploads/files/1614023380537-capture.jpg" alt="Capture.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/88803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88803</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Mon, 22 Feb 2021 19:50:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 22 Feb 2021 18:08:14 GMT]]></title><description><![CDATA[<p dir="auto">@j-e-f-f outstanding thanks Jeff I am going to give a go and report back if anything!</p>
]]></description><link>https://forum.magicmirror.builders/post/88796</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88796</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Mon, 22 Feb 2021 18:08:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 22 Feb 2021 18:06:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi folks</p>
<p dir="auto">I’m noticing that many of you are experiencing failures of this module.  It’s very likely that Apple is systematically shutting down the API access for some, but not everyone.  In that light, I’ve made a replacement for it that uses the OpenWeather API instead.</p>
<p dir="auto">I’m not ready to release it to the masses just yet, but if you’d like to try it out, link is here:<br />
<a href="https://github.com/jclarke0000/MMM-OpenWeatherForecast" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jclarke0000/MMM-OpenWeatherForecast</a></p>
<p dir="auto">It works and looks the same, but has a few added features – be sure to read the README to see how to configure it.</p>
<p dir="auto">Let me know if you run into any issues.  I’m currently running it on three separate systems – my laptop for debugging and two raspberry pis, and it’s looking pretty good.</p>
]]></description><link>https://forum.magicmirror.builders/post/88795</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88795</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Mon, 22 Feb 2021 18:06:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Tue, 02 Feb 2021 20:39:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swvalenti" aria-label="Profile: swvalenti">@<bdi>swvalenti</bdi></a> k, reported</p>
]]></description><link>https://forum.magicmirror.builders/post/88091</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88091</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Feb 2021 20:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Tue, 02 Feb 2021 20:10:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/88085">MMM-DarkSkyForecast - Yet ANOTHER weather module</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swvalenti" aria-label="Profile: swvalenti">@<bdi>swvalenti</bdi></a> u getting invalid files?  me too</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yes sir invalid files</p>
]]></description><link>https://forum.magicmirror.builders/post/88090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88090</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Tue, 02 Feb 2021 20:10:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Tue, 02 Feb 2021 15:18:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swvalenti" aria-label="Profile: swvalenti">@<bdi>swvalenti</bdi></a> u getting invalid files?  me too</p>
]]></description><link>https://forum.magicmirror.builders/post/88085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88085</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Feb 2021 15:18:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Tue, 02 Feb 2021 14:37:48 GMT]]></title><description><![CDATA[<p dir="auto">Mine still working just fine…what is not working is uploading a small .jpg file to the forum since update.</p>
]]></description><link>https://forum.magicmirror.builders/post/88084</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88084</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Tue, 02 Feb 2021 14:37:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 20:39:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: egnos">@<bdi>egnos</bdi></a> no, sorry, don’t know weather modules too many, too different</p>
]]></description><link>https://forum.magicmirror.builders/post/88076</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88076</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Feb 2021 20:39:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 20:29:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> can you advise me with similar graphics?<br />
Thanks 😉</p>
]]></description><link>https://forum.magicmirror.builders/post/88074</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88074</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Mon, 01 Feb 2021 20:29:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 20:08:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: egnos">@<bdi>egnos</bdi></a> they said aug 2020.  so, delayed already</p>
]]></description><link>https://forum.magicmirror.builders/post/88073</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88073</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Feb 2021 20:08:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 19:11:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
False alarm!  It works again!  I don’t know why…<br />
From your posts it seems that the end of this API is near … when will it happen can you advise me with similar graphics?</p>
<p dir="auto">Thank you very much</p>
]]></description><link>https://forum.magicmirror.builders/post/88070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88070</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Mon, 01 Feb 2021 19:11:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 15:57:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I was gonna post a 26k png file showing the Darksky api still working but the forum refused.</p>
<p dir="auto">You’re never wrong, Sam. You’re just not always right. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/88065</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88065</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 01 Feb 2021 15:57:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 15:50:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a> hm. i suppose its possible i could be wrong! lol</p>
]]></description><link>https://forum.magicmirror.builders/post/88063</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88063</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Feb 2021 15:50:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 15:40:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/88060">MMM-DarkSkyForecast - Yet ANOTHER weather module</a>:</p>
<p dir="auto">id say the api has finally been turned off as they said would happen</p>
<p dir="auto">Hmm, I don’t know about that, Sammo. My BMW-DS weather is still working using an old Darksky api key. I’ve been waiting for it to fail, knowing the end is near.</p>
]]></description><link>https://forum.magicmirror.builders/post/88062</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88062</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 01 Feb 2021 15:40:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 15:14:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: egnos">@<bdi>egnos</bdi></a> id say the api has finally been turned off as they said would happen</p>
]]></description><link>https://forum.magicmirror.builders/post/88060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88060</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Feb 2021 15:14:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Mon, 01 Feb 2021 12:10:43 GMT]]></title><description><![CDATA[<p dir="auto">hello everyone, from today the module doesn’t work anymore.<br />
The module remains in “Loading” and on the terminal I have this error:</p>
<pre><code>[01.02.2021 12: 56.02.875] [LOG] [MMM-DarkSkyForecast] 1-Feb-21 12:56 ** ERROR ** null
<p dir="auto">Do you know if something has happened?</p>
<p dir="auto">Many Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/88057</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88057</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Mon, 01 Feb 2021 12:10:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Sat, 26 Dec 2020 00:30:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’ve been using MMM-WeatherorNot for so long I seriously didn’t know…</p>
]]></description><link>https://forum.magicmirror.builders/post/86138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86138</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 26 Dec 2020 00:30:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-DarkSkyForecast - Yet ANOTHER weather module on Sat, 26 Dec 2020 00:29:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> u are joking, right?</p>
<p dir="auto">MMM-Climacell-Hourly<br />
MMM-BMW-CC</p>
]]></description><link>https://forum.magicmirror.builders/post/86137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86137</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 26 Dec 2020 00:29:13 GMT</pubDate></item></channel></rss>
