<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM2.5 slow to PM2 start after changing pi password]]></title><description><![CDATA[<p dir="auto">I’ve been working on my MM2.5 for a couple weeks getting it just the way I want it and was all done when I decided I’d better change the default pi password.  I did so and, now, it takes about 3 minutes after a reboot for the MM2.5 screen to appear.  I’ve searched high and low for a solution without success.  Can anyone point me in the right direction???  I’m using a RPi 3 A+ headless.  I use Notepad++ to edit MM2.5 files and then issue a “sudo reboot” via Putty to assess the changes.   The reboot gets back to the GUI fairly quickly (normal time), but stays there for a couple minutes before MM2.5 starts up using pm2.  Can anyone point me to a solution???  Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9189/mm2-5-slow-to-pm2-start-after-changing-pi-password</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 02:43:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9189.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Dec 2018 22:52:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM2.5 slow to PM2 start after changing pi password on Sun, 02 Dec 2018 00:27:24 GMT]]></title><description><![CDATA[<p dir="auto">Looks like I should have looked closer to home than all over the web!  I watched more closely at the boot-up procedure of my RPi and noticed a FAILED step involving dhcpcd.  I looked that up on the web and found that newer distros don’t want you to edit the file /etc/network/interfaces.  See this link for more information:</p>
<p dir="auto"><a href="https://www.raspberrypi.org/forums/viewtopic.php?t=203530" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/forums/viewtopic.php?t=203530</a></p>
<p dir="auto">I followed the directions there and then went back <a href="http://Raspberrypi.org" target="_blank" rel="noopener noreferrer nofollow ugc">Raspberrypi.org</a> to follow the directions for properly (and easily) setting up my wifi.  Once I did all that the dhcpcd error was gone and my MM2.5 reboot issues were resolved.</p>
<p dir="auto">Case closed.</p>
]]></description><link>https://forum.magicmirror.builders/post/47575</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47575</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Sun, 02 Dec 2018 00:27:24 GMT</pubDate></item></channel></rss>
