<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RTSP Stream error since last Update]]></title><description><![CDATA[<p dir="auto">Hallo <a class="plugin-mentions-user plugin-mentions-a" href="/user/shbatm" aria-label="Profile: shbatm">@<bdi>shbatm</bdi></a>, hallo everybody,</p>
<p dir="auto">since I install the last update of your Module I get the following error. Maybe you can help me…</p>
<pre><code>0|mm       |     TypeError: Cannot read property 'omxRestart' of undefined
0|mm       |     at pm2.start (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:155:85)
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1017:21
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1088:19
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:473:16
0|mm       |     at replenish (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:1006:25)
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:1016:9
0|mm       |     at Object.eachLimit$1 (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:3196:24)
0|mm       |     at startApps (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1033:11)
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1015:14
0|mm       |     at iterateeCallback (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:992:24)
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:969:16
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1007:16
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1342:19
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1338:16
0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
0|mm       |     at Parser.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
0|mm       |     at emitOne (events.js:116:13)
0|mm       |     at Parser.emit (events.js:211:7)
<p dir="auto">THX</p>
]]></description><link>https://forum.magicmirror.builders/topic/9204/rtsp-stream-error-since-last-update</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 01:22:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9204.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Dec 2018 15:05:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RTSP Stream error since last Update on Thu, 10 Jan 2019 07:25:45 GMT]]></title><description><![CDATA[<p dir="auto">I’ve updated the <code>develop</code> branch of the module, please see the main <a href="https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/212">MMM-RTSPStream Thread</a> and update to the latest version on the <code>develop</code> branch.</p>
]]></description><link>https://forum.magicmirror.builders/post/49884</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49884</guid><dc:creator><![CDATA[shbatm]]></dc:creator><pubDate>Thu, 10 Jan 2019 07:25:45 GMT</pubDate></item><item><title><![CDATA[Reply to RTSP Stream error since last Update on Fri, 28 Dec 2018 13:54:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tobiv" aria-label="Profile: tobiv">@<bdi>tobiv</bdi></a><br />
did you find any mistakes?</p>
]]></description><link>https://forum.magicmirror.builders/post/48730</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48730</guid><dc:creator><![CDATA[djuscha]]></dc:creator><pubDate>Fri, 28 Dec 2018 13:54:33 GMT</pubDate></item><item><title><![CDATA[Reply to RTSP Stream error since last Update on Thu, 13 Dec 2018 09:21:02 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">i have exact the same problem! I have two RTSP-Streams implemented, the first one doesn’t  start, the second one works!</p>
<p dir="auto">Greetings</p>
]]></description><link>https://forum.magicmirror.builders/post/48122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48122</guid><dc:creator><![CDATA[tobiv]]></dc:creator><pubDate>Thu, 13 Dec 2018 09:21:02 GMT</pubDate></item></channel></rss>
