<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-awesome-alexa Giving me a black screen]]></title><description><![CDATA[<p dir="auto">Hi, I am trying to install MMM-awesome-alexa to my magic mirror, but I am having some issues.</p>
<p dir="auto">I have all of the alexa developer keys, but it ends up to a black screen on my raspberry pi. I have been searching all over the internet to find out why this is happening, but I noticed something on my terminal responding,</p>
<pre><code>Starting MagicMirror: v2.5.0
Loading config ...
Loading module helpers ...
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v2.0-linux-arm/snowboy.node'
App threw an error during load
    at Module._resolveFilename (module.js:543:15)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
    at Function.Module._load (module.js:473:25)
    at Module.require (module.js:586:17)
    at require (internal/module.js:11:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:8:29)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:132:3)
    at Module._compile (module.js:642:30)
    at Object.Module._extensions..js (module.js:653:10)
    at Module.load (module.js:561:32)
{ Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v2.0-linux-arm/snowboy.node'
    at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
Launching application.
<p dir="auto">I looked through it and found that snowboy was not found, and I couldn’t even find it myself with the directory it provided. I looked around and found something saying I needed to use <code>npm run electron-rebuild</code>, but it also gives a error,</p>
<pre><code>Rebuild Failed
An unhandled error occurred inside electron-rebuild
Could not detect abi for version 2.0.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
Error: Could not detect abi for version 2.0.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
    at Object.getAbi (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/node-abi/index.js:43:9)
    at _callee6$ (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:152:37)
    at tryCatch (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:63:40)
    at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:337:22)
    at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:96:21)
    at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/util.js:16:23)
    at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/generators.js:97:49)
    at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/generators.js:201:15
    at _rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:613:18)
    at rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:624:28)
    at _callee$ (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/cli.js:160:45)
npm ERR! code ELIFECYCLE
npm ERR! errno 255
npm ERR! mmm-awesome-alexa@1.0.0 electron-rebuild: electron-rebuild --pre-gyp-fix
npm ERR! Exit status 255
npm ERR!
npm ERR! Failed at the mmm-awesome-alexa@1.0.0 electron-rebuild script.
npm ERR!     /home/pi/.npm/_logs/2018-12-05T14_47_11_588Z-debug.log
<p dir="auto">Is there any fix for this that anyone knows? I want to get this built before the end of the week so I can get it ready for next year.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9207/mmm-awesome-alexa-giving-me-a-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 17:18:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9207.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Dec 2018 14:56:24 GMT</pubDate><ttl>60</ttl></channel></rss>
