<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io)]]></title><description><![CDATA[<h2>Description:</h2>
<p dir="auto">Simple Mirror Control and module notifications from your existing (external) Home Assistant (Alexa/Google Home/HASS.io) with minimal setup using the Wemo protocol.</p>
<p dir="auto">Yes, this is yet-another-Alexa-module; however, I hadn’t found one that did not require setting up some special Alexa skill or configuring an AWS account, etc.</p>
<p dir="auto">This module uses the Belkin Wemo protocol (via <a href="https://github.com/dsandor/fauxmojs" target="_blank" rel="noopener noreferrer nofollow ugc">fauxmojs</a>) to receive on/off notifications from an Amazon Echo (or Google Home Hub, or anything that can discover and control a Wemo device).  It creates “virtual” Wemo devices on your network that the home assistant can find, and then receives ON or OFF commands for those devices.  The module simply takes these, and converts them to module notifications for other modules to work with.</p>
<p dir="auto"><strong>Main Features:</strong></p>
<ul>
<li>Simple setup.  Install the module, then say, “Alexa, discover my devices”.  The virtual devices will populate and you can start controlling them.</li>
<li>Doesn’t add redundant features.
<ul>
<li>I didn’t want to keep baking in the same functions that so many other modules already have, so this module just takes an ON or OFF command, and turns that into whatever notification you need it to be.  Customize all the details in your config file.</li>
</ul>
</li>
</ul>
<p dir="auto">Examples:</p>
<ul>
<li>Create a “Magic Mirror” virtual device, use a module like MMM-OnScreenMenu or MMM-RemoteControl to turn on and off the screen when you say “Alexa, turn on Magic Mirror”. – <a href="https://github.com/shbatm/MMM-AlexaOnOff#example---turn-onoff-monitor-using-an-amazon-echo-and-mmm-onscreenmenu-module" target="_blank" rel="noopener noreferrer nofollow ugc">See detailed example here</a></li>
<li>Create a “device” for each profile in MMM-ProfileSwitcher.  Setup the notification so when you say “Alexa, turn on Mary’s Mirror” it tells MMM-ProfileSwitcher to switch to that profile.</li>
</ul>
<h2>Download:</h2>
<p dir="auto">[card:shbatm/MMM-AlexaOnOff]</p>
<hr />
<h3>Current Version 0.1.<strong>1</strong> – <a href="https://github.com/shbatm/MMM-AlexaOnOff/blob/master/CHANGELOG.md" target="_blank" rel="noopener noreferrer nofollow ugc">CHANGELOG</a></h3>
]]></description><link>https://forum.magicmirror.builders/topic/9211/mmm-alexaonoff-simple-mirror-control-from-external-home-assistant-alexa-google-home-hass-io</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 17:01:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9211.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Dec 2018 02:23:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Tue, 21 Apr 2020 21:13:48 GMT]]></title><description><![CDATA[<p dir="auto">but MMM_AlexaControl works, same concept… I use it for 4 Mirror devices (with alexa devices, not goggle home or GA)</p>
]]></description><link>https://forum.magicmirror.builders/post/73275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73275</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 21 Apr 2020 21:13:48 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Sat, 14 Sep 2019 19:20:32 GMT]]></title><description><![CDATA[<p dir="auto">looking at this app,  I think alexa v2+ devices have removed the builtin support for wemo devices which this depends on.</p>
<p dir="auto">so, you would have to install the belkin wemo skill… which requires actual devices</p>
]]></description><link>https://forum.magicmirror.builders/post/61308</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61308</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 14 Sep 2019 19:20:32 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Sat, 14 Sep 2019 17:14:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/js989" aria-label="Profile: js989">@<bdi>js989</bdi></a> Same situation here.  Have not been able to figure it out.  I found this resource which I believe may be a possible problem but have not been able to work through it.  <a href="https://github.com/n8henrie/fauxmo/issues/38" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/n8henrie/fauxmo/issues/38</a></p>
]]></description><link>https://forum.magicmirror.builders/post/61307</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61307</guid><dc:creator><![CDATA[sbrundage85]]></dc:creator><pubDate>Sat, 14 Sep 2019 17:14:18 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 12 Sep 2019 18:44:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi - I’m struggling with this module too.  I have it installed with the dependencies.  I can see that the ports are opened and listening.  Alexa cannot find the devices.  I’ve tried the examples too which have not been discovered yet either.</p>
<p dir="auto">I have an Echo dot gen 3 in the house, on the same network as the mirror.  I’ve tried searching for the device from the echo and the web portal - neither has worked.  Any tips?</p>
]]></description><link>https://forum.magicmirror.builders/post/61201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61201</guid><dc:creator><![CDATA[js989]]></dc:creator><pubDate>Thu, 12 Sep 2019 18:44:41 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Fri, 02 Aug 2019 14:45:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I did find this line commented out near the top of the MMM-Remote-Control.js which may be where they are working to resolve this.</p>
<pre><code>// Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
]]></description><link>https://forum.magicmirror.builders/post/59686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59686</guid><dc:creator><![CDATA[SubLim3]]></dc:creator><pubDate>Fri, 02 Aug 2019 14:45:42 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Fri, 02 Aug 2019 14:12:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sublim3" aria-label="Profile: SubLim3">@<bdi>SubLim3</bdi></a> that is a bug in remote control.</p>
<p dir="auto">Don’t know how/when it might have got there</p>
]]></description><link>https://forum.magicmirror.builders/post/59684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59684</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Aug 2019 14:12:26 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Fri, 02 Aug 2019 14:04:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Correct. There were 2 instances in the MMM-Remote-Control.js where I changed console.log to Log.log and this did resolve my issue. I was more curious to know if this was an issue with AlexaOnOff not having an update or if it was due to Remote-Control updating to a newer build.</p>
]]></description><link>https://forum.magicmirror.builders/post/59682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59682</guid><dc:creator><![CDATA[SubLim3]]></dc:creator><pubDate>Fri, 02 Aug 2019 14:04:54 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Fri, 02 Aug 2019 13:28:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sublim3" aria-label="Profile: SubLim3">@<bdi>SubLim3</bdi></a> you are supposed to change console.log TO Log.log</p>
<p dir="auto">So currently u will not find it.</p>
<p dir="auto">Log.log is supposed to be used in the module.js file</p>
]]></description><link>https://forum.magicmirror.builders/post/59679</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59679</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Aug 2019 13:28:00 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Fri, 02 Aug 2019 13:24:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Is this something that happened because I updated MMM-Remote-Control and MMM-AlexaOnOff does not have an update? If so, would it be better to update AlexaOnOff to have console.log instead of log.log? That being said, I could not find Log.log in AlexaOnOff.js anyways.</p>
<p dir="auto">Are there other modules that will stop working if I change MMM_Remote_Control to Log.log? I saw it in there a couple of times and changed it. This did resolve the issue but I need to see if there are other Modules throwing red flags now.</p>
<p dir="auto">Thank you for the Help! Hopefully MMM-AlexaOnOff gets an update to help everyone else with 3rd Gen Alexa devices get discovered.</p>
]]></description><link>https://forum.magicmirror.builders/post/59678</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59678</guid><dc:creator><![CDATA[SubLim3]]></dc:creator><pubDate>Fri, 02 Aug 2019 13:24:27 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Fri, 02 Aug 2019 03:07:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sublim3" aria-label="Profile: SubLim3">@<bdi>SubLim3</bdi></a> edit the MMM-Remote-Control.js, and change all</p>
<pre><code>console.log
<p dir="auto">To</p>
<pre><code>Log.log
]]></description><link>https://forum.magicmirror.builders/post/59667</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59667</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Aug 2019 03:07:59 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Fri, 02 Aug 2019 02:13:40 GMT]]></title><description><![CDATA[<p dir="auto">So IF I understand this log correctly, my mirror is receiving the Notification from my Alexa Device but the AlexaOnOff module is not operating correctly. Any suggestions?</p>
<pre><code>
module.js:154 MMM-WatchDog received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
module.js:154 MMM-Screencast received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
module.js:154 MMM-GoogleMapsTraffic received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
MMM-Remote-Control.js:43 Uncaught TypeError: console.log is not a function
    at Class.notificationReceived (MMM-Remote-Control.js:43)
    at sendNotification (main.js:95)
    at Object.sendNotification (main.js:502)
    at Class.sendNotification (module.js:368)
    at config.devices.forEach.d (MMM-AlexaOnOff.js:47)
    at Array.forEach (&lt;anonymous&gt;)
    at Class.socketNotificationReceived (MMM-AlexaOnOff.js:37)
    at module.js:246
    at r.&lt;anonymous&gt; (socketclient.js:25)
    at r.emit (index.js:83)
]]></description><link>https://forum.magicmirror.builders/post/59665</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59665</guid><dc:creator><![CDATA[SubLim3]]></dc:creator><pubDate>Fri, 02 Aug 2019 02:13:40 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 01 Aug 2019 19:56:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> anybody an idea?</p>
]]></description><link>https://forum.magicmirror.builders/post/59650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59650</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 01 Aug 2019 19:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 01 Aug 2019 10:55:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> is there anybody with a working module MMM-AlexaOnOff on Mac?</p>
<p dir="auto">test device is working …but no other device</p>
]]></description><link>https://forum.magicmirror.builders/post/59633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59633</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 01 Aug 2019 10:55:39 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 01 Aug 2019 10:51:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morelinux" aria-label="Profile: MoreLinux">@<bdi>MoreLinux</bdi></a> I have MM running on Mac I think you have a RPI …maybe this can be my problem</p>
]]></description><link>https://forum.magicmirror.builders/post/59632</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59632</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 01 Aug 2019 10:51:40 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 01 Aug 2019 10:41:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sublim3" aria-label="Profile: SubLim3">@<bdi>SubLim3</bdi></a> i tried the app but doesn’t work…no device found</p>
]]></description><link>https://forum.magicmirror.builders/post/59631</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59631</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 01 Aug 2019 10:41:24 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 01 Aug 2019 09:39:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> Yeah, I have been reading that the 3rd Gen Alexa devices are not locating the modules. You might try discovery through the app or web browser <a href="http://alexa.amazon.com" target="_blank" rel="noopener noreferrer nofollow ugc">http://alexa.amazon.com</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/59625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59625</guid><dc:creator><![CDATA[SubLim3]]></dc:creator><pubDate>Thu, 01 Aug 2019 09:39:38 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 01 Aug 2019 03:35:50 GMT]]></title><description><![CDATA[<p dir="auto">for me the test device is working (Office lamp or fan) but can’t find my modules</p>
]]></description><link>https://forum.magicmirror.builders/post/59618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59618</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 01 Aug 2019 03:35:50 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Wed, 31 Jul 2019 21:16:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sublim3" aria-label="Profile: SubLim3">@<bdi>SubLim3</bdi></a> open the developers window, ctrl-shift-i, then select the console tab across the top.</p>
<p dir="auto">U can add text to search the console in the filter field.</p>
<p dir="auto">You should see all the notification events</p>
]]></description><link>https://forum.magicmirror.builders/post/59610</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59610</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 31 Jul 2019 21:16:16 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Wed, 31 Jul 2019 19:11:10 GMT]]></title><description><![CDATA[<p dir="auto">If the REMOTE_ACTION of MONITOROFF works from the remote UI then the notifications are sent and received and executed properly. Does anyone have any recommendations as to how I can test if the Notifications sent from my Alexa device to the module is received? Just trying to hash through this one. Any help is appreciated. Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/59604</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59604</guid><dc:creator><![CDATA[SubLim3]]></dc:creator><pubDate>Wed, 31 Jul 2019 19:11:10 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Mon, 29 Jul 2019 02:02:51 GMT]]></title><description><![CDATA[<p dir="auto">I am running MM version 2.7.1 with the latest MMM-AlexaOnOff module. Below is my config.js details for this module. I get no errors when restarting MM and had no problem with Alexa discovering the devices listed in the module. I get confirmation feedback from Alexa when saying “Turn Magic Mirror Off”, but nothing happens. This used to work on an older build of MM but I wanted to start from scratch with the latest version and this has been the only Mod not working correctly. Any help is appreciated. Thank you.</p>
<pre><code>                {
                        module: 'MMM-AlexaOnOff',
//						classes: 'default everyone',
                                devices: [{
                                        on: {
                                                notification: "REMOTE_ACTION",
                                                payload: { action:'MONITORON' }
                                        off: {
                                                payload: { action:'MONITOROFF' }
                                        name: "Magic Mirror Modules",
                                        on: {
                                                payload: { action:'SHOWALL' }
                                        off: {
                                                payload: { action:'HIDEALL' }
                                        name: "Magic Mirror Maps",
                                        on: {
                                                payload: {action: "SHOW", module: "module_8_MMM-GoogleMapsTraffic"}
                                        off: {
                                                payload: {action: "HIDE", module: "module_8_MMM-GoogleMapsTraffic"}
                                        name: "Magic Mirror Reboot",
                                        on: {
                                                payload: { action:'REBOOT' }
                                        off: {
                                                payload: { action:'SHUTDOWN' }
                                        name: "Magic Mirror Update",
                                        on: {
                                                payload: { action:'UPDATE' }
                                        off: {
                                                payload: { action:'RESTART' }
]]></description><link>https://forum.magicmirror.builders/post/59474</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59474</guid><dc:creator><![CDATA[SubLim3]]></dc:creator><pubDate>Mon, 29 Jul 2019 02:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Fri, 19 Jul 2019 13:48:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shbatm" aria-label="Profile: shbatm">@<bdi>shbatm</bdi></a> Can you help us?</p>
]]></description><link>https://forum.magicmirror.builders/post/59156</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59156</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Fri, 19 Jul 2019 13:48:18 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 18 Jul 2019 18:52:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a>  no 😢</p>
]]></description><link>https://forum.magicmirror.builders/post/59136</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59136</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 18 Jul 2019 18:52:28 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 18 Jul 2019 17:53:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sbrundage85" aria-label="Profile: sbrundage85">@<bdi>sbrundage85</bdi></a> Hello, with my Mirror (2.8.0) an EchoDot 3rd Gen. I’m unable to discover devices, too. I try everything i know, but no solution. You found some solution?</p>
<p dir="auto">Greets Niggich</p>
]]></description><link>https://forum.magicmirror.builders/post/59134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59134</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Thu, 18 Jul 2019 17:53:43 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io) on Thu, 18 Jul 2019 06:45:48 GMT]]></title><description><![CDATA[<p dir="auto">for me not working on MAC…</p>
<pre><code>Patricks-Mini:MMM-AlexaOnOff patrickhahn$ npm install
npm WARN deprecated hapi@16.7.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
npm WARN deprecated boom@4.3.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated ammo@2.0.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated boom@5.2.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated accept@2.1.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated call@4.0.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated catbox@7.1.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated catbox-memory@2.0.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated cryptiles@3.1.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated heavy@4.0.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated items@2.1.2: This module has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version of hapi to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated iron@4.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated hoek@4.2.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated mimos@3.0.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated joi@11.4.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated podium@1.3.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated somever@1.0.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated statehood@5.0.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated shot@3.4.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated joi@12.0.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated topo@2.0.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated subtext@5.0.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated joi@10.6.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated bourne@1.1.2: This module has moved and is now available at @hapi/bourne. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
npm WARN deprecated content@3.0.7: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated pez@2.1.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated wreck@12.5.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated nigel@2.0.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated b64@3.0.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated vise@2.0.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm notice created a lockfile as package-lock.json. You should commit this file.
added 59 packages from 21 contributors and audited 137 packages in 5.801s
found 0 vulnerabilities
]]></description><link>https://forum.magicmirror.builders/post/59108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59108</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 18 Jul 2019 06:45:48 GMT</pubDate></item></channel></rss>
