<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-awesome-alexa snowboy issue]]></title><description><![CDATA[<p dir="auto">Hi, I`m trying to install awesome-alexa but when I try to run the electron rebuild I get a huge error list…</p>
<p dir="auto">I updated electron, node-abi, every single thing that could be updated, ran npm audit-fix and still nothing.</p>
<p dir="auto">Here is the output:</p>
<p dir="auto">An unhandled error occurred inside electron-rebuild<br />
make: Entering directory ‘/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build’<br />
CXX(target) Release/obj.target/snowboy/swig/Node/snowboy.o<br />
In file included from …/…/nan/nan.h:192:0,<br />
from …/swig/Node/snowboy.cc:1:<br />
…/…/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe Nan::ForceSet(v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a>, v8::PropertyAttribute)’:<br />
…/…/nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’<br />
return obj-&gt;ForceSet(isolate-&gt;GetCurrentContext(), key, value, attribs);<br />
^~~~~~~~<br />
In file included from …/swig/Node/snowboy.cc:1:0:<br />
…/…/nan/nan.h: In function ‘v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> Nan::MakeCallback(v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Function</a>, int, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a><em>)’:<br />
…/…/nan/nan.h:835:60: warning: ‘v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> node::MakeCallback(v8::Isolate</em>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Function</a>, int, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a><em>)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]<br />
v8::Isolate::GetCurrent(), target, func, argc, argv);<br />
^<br />
In file included from /home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/node.h:53:0,<br />
from …/…/nan/nan.h:49,<br />
/home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/node.h:94:50: note: declared here<br />
NODE_EXTERN v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> MakeCallback(<br />
^<br />
/home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/core.h:35:42: note: in definition of macro ‘NODE_DEPRECATED’<br />
<strong>attribute</strong>((deprecated(message))) declarator<br />
^~~~~~~~~~<br />
…/…/nan/nan.h: In function ‘v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> Nan::MakeCallback(v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::String</a>, int, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a></em>)’:<br />
…/…/nan/nan.h:850:62: warning: ‘v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> node::MakeCallback(v8::Isolate*, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::String</a>, int, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a><em>)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]<br />
v8::Isolate::GetCurrent(), target, symbol, argc, argv);<br />
^<br />
/home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/node.h:87:50: note: declared here<br />
^<br />
^~~~~~~~~~<br />
…/…/nan/nan.h: In function ‘v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> Nan::MakeCallback(v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, const char</em>, int, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a><em>)’:<br />
…/…/nan/nan.h:865:62: warning: ‘v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> node::MakeCallback(v8::Isolate</em>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, const char*, int, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a><em>)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]<br />
v8::Isolate::GetCurrent(), target, method, argc, argv);<br />
^<br />
/home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/node.h:80:50: note: declared here<br />
^<br />
^~~~~~~~~~<br />
…/…/nan/nan.h: In member function ‘v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> Nan::Callback::Call_(v8::Isolate</em>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, int, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a><em>) const’:<br />
…/…/nan/nan.h:1479:5: warning: ‘v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a> node::MakeCallback(v8::Isolate</em>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Object</a>, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Function</a>, int, v8::Local<a target="_blank" rel="noopener noreferrer nofollow ugc">v8::Value</a>*)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]<br />
));<br />
^<br />
^<br />
^~~~~~~~~~<br />
<a href="http://snowboy.target.mk:107" target="_blank" rel="noopener noreferrer nofollow ugc">snowboy.target.mk:107</a>: recipe for target ‘Release/obj.target/snowboy/swig/Node/snowboy.o’ failed<br />
make: Leaving directory ‘/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build’<br />
make: *** [Release/obj.target/snowboy/swig/Node/snowboy.o] Error 1<br />
gyp ERR! build error<br />
gyp ERR! stack Error: <code>make</code> failed with exit code: 2<br />
gyp ERR! stack     at ChildProcess.onExit (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/node-gyp/lib/build.js:262:23)<br />
gyp ERR! stack     at ChildProcess.emit (events.js:180:13)<br />
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:12)<br />
gyp ERR! System Linux 4.4.132+<br />
gyp ERR! command “/usr/bin/node” “/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/.bin/node-gyp” “rebuild” “–target=3.0.11” “–arch=arm” “–dist-url=<a href="https://atom.io/download/electron" target="_blank" rel="noopener noreferrer nofollow ugc">https://atom.io/download/electron</a>” “–build-from-source” “–module_name=snowboy” “–module_path=/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v3.0-linux-arm” “–remote_path=./snowboy/v1.2.0/Release/” “–package_name=snowboy-v1.2.0-electron-v3.0-linux-arm.tar.gz” “–host=<a href="https://snowboy-release-node.s3-us-west-2.amazonaws.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://snowboy-release-node.s3-us-west-2.amazonaws.com</a>”<br />
gyp ERR! cwd /home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy<br />
gyp ERR! node -v v9.11.2<br />
gyp ERR! node-gyp -v v3.8.0<br />
gyp ERR! not ok</p>
<p dir="auto">Failed with exit code: 1</p>
<p dir="auto">Error: make: Entering directory ‘/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build’<br />
^~~~~~~~<br />
^<br />
^<br />
^~~~~~~~~~<br />
^<br />
^<br />
^~~~~~~~~~<br />
^<br />
^<br />
^~~~~~~~~~<br />
));<br />
^<br />
^<br />
^~~~~~~~~~<br />
gyp ERR! not ok</p>
<p dir="auto">Failed with exit code: 1<br />
at SafeSubscriber._error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/spawn-rx/lib/src/index.js:277:84)<br />
at SafeSubscriber.__tryOrUnsub (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:238:16)<br />
at SafeSubscriber.error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:197:26)<br />
at Subscriber._error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:128:26)<br />
at Subscriber.error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:102:18)<br />
at MapSubscriber.Subscriber._error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:128:26)<br />
at MapSubscriber.Subscriber.error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:102:18)<br />
at SafeSubscriber._next (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/spawn-rx/lib/src/index.js:251:65)<br />
at SafeSubscriber.__tryOrSetError (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:247:16)<br />
at SafeSubscriber.next (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:187:27)<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! errno 255<br />
npm ERR! mmm-awesome-alexa@1.0.0 electron-rebuild: <code>electron-rebuild --pre-gyp-fix</code><br />
npm ERR! Exit status 255<br />
npm ERR!<br />
npm ERR! Failed at the mmm-awesome-alexa@1.0.0 electron-rebuild script.<br />
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:<br />
npm ERR!     /home/linaro/.npm/_logs/2018-12-13T13_18_01_671Z-debug.log</p>
<p dir="auto">If anybody else has encountered this and knows what to do, please help.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9255/mmm-awesome-alexa-snowboy-issue</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 21:06:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9255.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Dec 2018 13:23:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-awesome-alexa snowboy issue on Tue, 08 Jan 2019 01:56:30 GMT]]></title><description><![CDATA[<p dir="auto">Please use <a href="https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#code" target="_blank" rel="noopener noreferrer nofollow ugc">the Markdown features</a> of the board when posting code.</p>
]]></description><link>https://forum.magicmirror.builders/post/49669</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49669</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 08 Jan 2019 01:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa snowboy issue on Mon, 07 Jan 2019 19:08:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattsharp" aria-label="Profile: mattsharp">@<bdi>mattsharp</bdi></a> Thanks mate. I moved to MirrorMirroronthewall and almost got it working flawlessy. So don`t worry too much.</p>
]]></description><link>https://forum.magicmirror.builders/post/49649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49649</guid><dc:creator><![CDATA[Radu_Stancu]]></dc:creator><pubDate>Mon, 07 Jan 2019 19:08:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa snowboy issue on Mon, 07 Jan 2019 19:06:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/radu_stancu" aria-label="Profile: radu_stancu">@<bdi>radu_stancu</bdi></a> Starting fresh with 2.6.0 now, I’ll let you know how it goes, fingers crossed haha</p>
]]></description><link>https://forum.magicmirror.builders/post/49648</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49648</guid><dc:creator><![CDATA[MattSharp]]></dc:creator><pubDate>Mon, 07 Jan 2019 19:06:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa snowboy issue on Sun, 06 Jan 2019 16:48:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattsharp" aria-label="Profile: mattsharp">@<bdi>mattsharp</bdi></a> I`m kind of reluctant to update to 2.6.0 so I do not mess anything. I have modified quite a lot of config files and custom css. This is my college project and I have to present in a few months. The google assistant is working decently, although I was hoping for better, I will have to stick with it until this issue with electron is fixed.</p>
]]></description><link>https://forum.magicmirror.builders/post/49502</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49502</guid><dc:creator><![CDATA[Radu_Stancu]]></dc:creator><pubDate>Sun, 06 Jan 2019 16:48:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa snowboy issue on Sun, 06 Jan 2019 16:40:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/radu_stancu" aria-label="Profile: radu_stancu">@<bdi>radu_stancu</bdi></a> I still can’t seem to get it to work tbf, think I’ll try starting again with version 2.6.0</p>
]]></description><link>https://forum.magicmirror.builders/post/49501</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49501</guid><dc:creator><![CDATA[MattSharp]]></dc:creator><pubDate>Sun, 06 Jan 2019 16:40:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa snowboy issue on Sun, 06 Jan 2019 16:35:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattsharp" aria-label="Profile: mattsharp">@<bdi>mattsharp</bdi></a> Thanks for trying, I will try soon enough, I have tried the google assistant module, but I`ll probably return to alexa soon.</p>
]]></description><link>https://forum.magicmirror.builders/post/49500</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49500</guid><dc:creator><![CDATA[Radu_Stancu]]></dc:creator><pubDate>Sun, 06 Jan 2019 16:35:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa snowboy issue on Sun, 30 Dec 2018 17:01:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattsharp" aria-label="Profile: mattsharp">@<bdi>mattsharp</bdi></a> said in <a href="/post/48873">MMM-awesome-alexa snowboy issue</a>:</p>
<p dir="auto">I’ve got the same issue currently, no idea what’s causing it and I’ve been searching all over.</p>
<p dir="auto">I take that back, I just tried an npm update electron-rebuild and then npm run electron-rebuild and it seems to have worked! give that a try and let me know if it helped</p>
]]></description><link>https://forum.magicmirror.builders/post/48875</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48875</guid><dc:creator><![CDATA[MattSharp]]></dc:creator><pubDate>Sun, 30 Dec 2018 17:01:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa snowboy issue on Sun, 30 Dec 2018 16:54:50 GMT]]></title><description><![CDATA[<p dir="auto">I’ve got the same issue currently, no idea what’s causing it and I’ve been searching all over.</p>
]]></description><link>https://forum.magicmirror.builders/post/48873</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48873</guid><dc:creator><![CDATA[MattSharp]]></dc:creator><pubDate>Sun, 30 Dec 2018 16:54:50 GMT</pubDate></item></channel></rss>
