<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror on the Ceiling]]></title><description><![CDATA[<p dir="auto">Apologies for crossposting from hardware, I didn’t spot this forum.</p>
<p dir="auto">Just showing off!<br />
I recently got a small fanless DLP projector, and wanted to try to find something to do with it. So, couple it with a raspberryPi Zero W and Magic Mirror I now have a status display for my bedroom ceiling! The modules are enabled/disabled on a schedule stored in Google Calendar.</p>
<p dir="auto">The projector is almost silent, though you can just about hear the motor spinning the colour wheel (important because I live in the country and it’s very quiet here).</p>
<p dir="auto">Apologies for the image quality, my phone is old and doesn’t focus well at all in the dark!<br />
What the projector looks like<br />
<img src="http://www.ponies.me.uk/blog/wp-content/uploads/2018/11/Physical2.png" alt="What it looks like" class=" img-fluid img-markdown" /></p>
<p dir="auto">What I see (with the soon to be removed clock)<br />
<img src="http://www.ponies.me.uk/blog/wp-content/uploads/2018/11/OnCeiling.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Just showing off!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9283/magicmirror-on-the-ceiling</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 16:56:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9283.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Dec 2018 11:32:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror on the Ceiling on Thu, 20 Dec 2018 14:31:55 GMT]]></title><description><![CDATA[<p dir="auto">I’m using an evaluation Module - DLPDLCR2000EVM , about £100 UKP.</p>
<p dir="auto">Things to note:</p>
<ul>
<li>I think it was a limited run, Farnell have been sold out for some time, and digikey’s stock is dropping.</li>
<li>Resolution is LOW 640x360</li>
<li>Its designed for a BeagleBone Black, I used a Pi Zero W adapter board from MickMake on tindie, needs soldering though.</li>
<li>It’s powered off a 5v wall-wart, no battery (though I think MickMake may be working on that)</li>
<li>no enclosure</li>
<li>no firmware customization, it boots to a bright splash screen and then you have to fiddle around sending I2C commands.</li>
<li>Soldered in you have NO GPIO left over for anything at all</li>
<li>Soldered in the usb ports are inaccesible</li>
<li>the zero w is somewhat underpowered, currently I’ve got MM running in docker on another Pi while I develop… I <em>think</em> you should be able to run both on the same device</li>
<li>There’s a very faint blue patch visible when all is black, seems to be a design fault, I returned one, but the second is the same.</li>
</ul>
<p dir="auto">All in all not perfect, but I’m used to that.</p>
]]></description><link>https://forum.magicmirror.builders/post/48367</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48367</guid><dc:creator><![CDATA[rummyr]]></dc:creator><pubDate>Thu, 20 Dec 2018 14:31:55 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror on the Ceiling on Thu, 20 Dec 2018 14:19:22 GMT]]></title><description><![CDATA[<p dir="auto">Nice touch. What mini DLP Projector are you using?<br />
I’ve been looking for one to play around with but couldn’t decide on one. I saw one I liked then it turned out you couldn’t use it while it was charging and the battery only lasted less than an hour.</p>
]]></description><link>https://forum.magicmirror.builders/post/48366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48366</guid><dc:creator><![CDATA[joela85]]></dc:creator><pubDate>Thu, 20 Dec 2018 14:19:22 GMT</pubDate></item></channel></rss>
