<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[node clientonly - no sound?]]></title><description><![CDATA[<p dir="auto">running 2.5.0.  When I run everything locally on my rpi b3+, sound notifications work.  Im using the pushbullet module.  However, when I run it in clientonly mode, I don’t get any notification sound.  Any common reason, or something I can look at to troubleshoot?</p>
<p dir="auto">Thank you,</p>
]]></description><link>https://forum.magicmirror.builders/topic/9289/node-clientonly-no-sound</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 01:12:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9289.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Dec 2018 23:39:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to node clientonly - no sound? on Fri, 21 Dec 2018 20:20:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/benderstwin" aria-label="Profile: benderstwin">@<bdi>benderstwin</bdi></a> - It sounds like the notification is using a local (to the Pi) file for the notification sound. When you browse to the web app from another machine, the new machine doesn’t have the notification file in the same file path as the Pi.</p>
<p dir="auto">You could try hunting down where this notification noise is being stored and then rewriting the reference to it to go to a web-accessible location. That’s a fair bit of work for an audible notification.</p>
]]></description><link>https://forum.magicmirror.builders/post/48410</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48410</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 21 Dec 2018 20:20:43 GMT</pubDate></item></channel></rss>
