<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stop the screensaver!]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I really haven’t been able to stop the screensaver on my mirror. I’m using Jessie Lite on a PI and followed the instructions:</p>
<p dir="auto">[code]<br />
sudo nano /etc/xdg/lxsession/LXDE/autostart</p>
<p dir="auto">add the following lines:</p>
<p dir="auto">@xset s noblank<br />
@xset s off<br />
@xset -dpms</p>
<p dir="auto">sudo nano /etc/lightdm/lightdm.conf</p>
<p dir="auto">xserver-command=X -s 0 -dpms<br />
[\code]</p>
<p dir="auto">but the screensaver still kicks in!</p>
<p dir="auto">Can’t find any general info on the internet that is different from the above.</p>
]]></description><link>https://forum.magicmirror.builders/topic/931/stop-the-screensaver</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 21:43:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/931.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Nov 2016 12:35:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stop the screensaver! on Sat, 23 Mar 2019 15:32:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anthony" aria-label="Profile: Anthony">@<bdi>Anthony</bdi></a> - That looks like a network outage. The errors show that the NASA module or whatever can’t pull images from the API. And then you lost connection to your mirror.</p>
<p dir="auto">Of course, it could be the Pi shutting off to disconnect the developer tools. Hrm.</p>
]]></description><link>https://forum.magicmirror.builders/post/54780</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54780</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sat, 23 Mar 2019 15:32:30 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Sat, 16 Mar 2019 13:52:52 GMT]]></title><description><![CDATA[<p dir="auto">This is a screenshot of what happened after about half an hour after restarting magic mirror.<img src="/assets/uploads/files/1552744368448-2019-03-16-154428_1366x768_scrot.png" alt="0_1552744358584_2019-03-16-154428_1366x768_scrot.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/54382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54382</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Sat, 16 Mar 2019 13:52:52 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Fri, 15 Mar 2019 08:12:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a><br />
I will try this as well but 3 days now the problem does not appear. I haven’t touch anything on my MM and I don’t see the black screen. I will try a <code>sudo apt-get update &amp;&amp; sudo apt-get upgrade</code> although. It is always usefull. Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/54309</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54309</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Fri, 15 Mar 2019 08:12:20 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Thu, 14 Mar 2019 16:30:26 GMT]]></title><description><![CDATA[<p dir="auto">At this point, I’m thinking a <code>sudo apt-get update &amp;&amp; sudo apt-get upgrade</code> might be in order. There could be a bug in the Pi’s power management routines.</p>
]]></description><link>https://forum.magicmirror.builders/post/54274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54274</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 14 Mar 2019 16:30:26 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 13 Mar 2019 11:53:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I don’t think that this is the problem but I want to test it just in case.</p>
]]></description><link>https://forum.magicmirror.builders/post/54202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54202</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Wed, 13 Mar 2019 11:53:00 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 13 Mar 2019 10:51:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anthony" aria-label="Profile: Anthony">@<bdi>Anthony</bdi></a> interesting…  neither of my systems has forgotten the screen saver setting, been running for over 2 years now…</p>
]]></description><link>https://forum.magicmirror.builders/post/54201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54201</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Mar 2019 10:51:34 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 13 Mar 2019 10:19:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
In my case when the screen goes to sleep everything is hidden, modules, dev console etc. I see only black screen. Is there any possibility that pi “forgets” the setting to disable the screensaver? I will try to go and change this setting and after put it back again to see if anyhting changes.</p>
]]></description><link>https://forum.magicmirror.builders/post/54199</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54199</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Wed, 13 Mar 2019 10:19:23 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 13 Mar 2019 10:12:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anthony" aria-label="Profile: Anthony">@<bdi>Anthony</bdi></a> when the screen went to sleep was the  developer window hidden too?</p>
<p dir="auto">when my MMM-SleepWake hides all the modules, the Developers console is still on the screen</p>
]]></description><link>https://forum.magicmirror.builders/post/54198</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54198</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Mar 2019 10:12:45 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 13 Mar 2019 09:36:36 GMT]]></title><description><![CDATA[<p dir="auto">This is getting too weird. Yesterday I had the MM running in dev mode and after I saw the screensaver I moved the mouse and everything came back as normal and no errors in the console. I don’t know why this happens not all the time and with different characteristics everytime.</p>
]]></description><link>https://forum.magicmirror.builders/post/54194</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54194</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Wed, 13 Mar 2019 09:36:36 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Tue, 12 Mar 2019 10:40:14 GMT]]></title><description><![CDATA[<p dir="auto">usually when u see that the MM runtime has crashed for some reason… even the debug console is gone</p>
<p dir="auto">I haven’t found a way to debug what has happened… I see this occasionally…</p>
]]></description><link>https://forum.magicmirror.builders/post/54136</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54136</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 Mar 2019 10:40:14 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Tue, 12 Mar 2019 07:52:57 GMT]]></title><description><![CDATA[<p dir="auto">Update.<br />
Last 3-4 days my MM was running just fine without screensaver appears. Last night it happened again so I restart MM in dev mode to see if I find an error after the the screensaver’s black screen. When I moved the mouse (after some time the screensaver had appeared) the screen was white and in dev console I had a message saying websocket disconnected or something like that. Usually when I moved the mouse after the screensaver and without the dev tools enabled the black screen dissapears and I get my MM screen back. This time was different. I’ll try to upload a screenshot when I get home.</p>
]]></description><link>https://forum.magicmirror.builders/post/54124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54124</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Tue, 12 Mar 2019 07:52:57 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Fri, 08 Mar 2019 11:58:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Mine too. If MM is shut down my screen is always on. This also happen if modules with movement are shown in the MM like MMM-ImageSlideShow which have pictures rotating. My screen goes black only when I have modules like clock,calendar,forunecookie,rfacs etc shown. I don’t know if a specific module cause this. For example I now have my MM on for 5 days without black screen and the modules shown are clock, calendar, stats, compliments, news, pictures and weather. If I hide pictures module or replace it with rfacts for example in about half an hour I will get the screensaver black screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/53924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53924</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Fri, 08 Mar 2019 11:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 06 Mar 2019 17:57:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anthony" aria-label="Profile: Anthony">@<bdi>Anthony</bdi></a> and if MM  is not running at all, what happens?</p>
<p dir="auto">I run voice, and imageslideshow and don’t see this. If I shut down MM, screen will stay in forever</p>
]]></description><link>https://forum.magicmirror.builders/post/53774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53774</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Mar 2019 17:57:30 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 06 Mar 2019 17:53:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I agree. But it doesn’t happen when I have voice disabled in my config. And I realized that it also doesn’t happen with voice enabled and MMM-ImageSlideShow showing my pics. Maybe because the pictures change every 10 seconds. But if I have voice enabled and MM shows only clock, calendar, weather etc after 30 minutes screen goes black.</p>
]]></description><link>https://forum.magicmirror.builders/post/53773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53773</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Wed, 06 Mar 2019 17:53:51 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 06 Mar 2019 12:25:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anthony" aria-label="Profile: Anthony">@<bdi>Anthony</bdi></a> said in <a href="/post/53735">Stop the screensaver!</a>:</p>
<p dir="auto">Moved the mouse and evertything showed up.</p>
<p dir="auto">that means screensaver kicked in…  MM doesn’t do module visibility by mouse movement…</p>
]]></description><link>https://forum.magicmirror.builders/post/53748</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53748</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Mar 2019 12:25:59 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 06 Mar 2019 07:31:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
Thank you for your reply. I haven’t try to see if Lucy works when I see the black screen because I can’t see the “Say, ‘Hello Lucy’” message and because of the latency problems I have I don’t know when it recognizes the keyword and wait for commands. My guess is that it will work but when I am finished with my mirrorsetup I will hung it on the wall so I won’t have mouse and keyboard connected to move or press a button for the mirror to show. Also the black screen appears not only in the standby mode. Last night I left the mirror showing my page 1 modules and in the morning I saw the black screen again. Moved the mouse and evertything showed up.</p>
]]></description><link>https://forum.magicmirror.builders/post/53735</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53735</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Wed, 06 Mar 2019 07:31:57 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 06 Mar 2019 02:52:45 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1551840754403-screenshot.png" alt="0_1551840753892_Screenshot.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/53726</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53726</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 06 Mar 2019 02:52:45 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 06 Mar 2019 02:53:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anthony" aria-label="Profile: Anthony">@<bdi>Anthony</bdi></a></p>
<p dir="auto">I’m not seeing this behavior at all. You can clearly see that I have xscreensaver running with the “Screen Saver DIsabled” but I can’t reproduce what it happening to you. Lucy responds normally and no black screen issue. If you say “SHOW  MODULES” does Lucy show them?</p>
<p dir="auto">![0_1551838003790_Screenshot.png](Uploading 100%)</p>
<p dir="auto"><strong>Edit: Something seems to be amiss. The forum isn’t allowing me to post an image at the moment.</strong></p>
<p dir="auto">Picture below.</p>
]]></description><link>https://forum.magicmirror.builders/post/53725</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53725</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 06 Mar 2019 02:53:41 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 06 Mar 2019 01:26:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anthony" aria-label="Profile: Anthony">@<bdi>Anthony</bdi></a></p>
<p dir="auto">Perhaps, but I’ve never seen this behavior or heard about it before this. I will see if I can reproduce that here.</p>
]]></description><link>https://forum.magicmirror.builders/post/53722</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53722</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 06 Mar 2019 01:26:49 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Tue, 05 Mar 2019 21:23:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
Is there any possibillity that Lucy interacts somehow with the screen saver? I am asking this because I have installed xscreensaver and working good but if I have lucy enabled I get the black screen and I must move the mouse to sho the MM again. Just a thought!</p>
]]></description><link>https://forum.magicmirror.builders/post/53713</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53713</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Tue, 05 Mar 2019 21:23:23 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Thu, 10 Jan 2019 00:35:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m0111k" aria-label="Profile: m0111k">@<bdi>m0111k</bdi></a> said in <a href="/post/49859">Stop the screensaver!</a>:</p>
<p dir="auto">ps im newb here, how can i remove xscreensaver when it doesnt work? Thanks</p>
<p dir="auto"><code>sudo apt-get remove xscreensaver</code></p>
<p dir="auto">However, I don’t think xscreensaver is capable of putting your display into standby. That is likely your system or settings.</p>
]]></description><link>https://forum.magicmirror.builders/post/49861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49861</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 10 Jan 2019 00:35:03 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 09 Jan 2019 23:33:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> tried that, screen still went standby… any clue for fix?<br />
]]></description><link>https://forum.magicmirror.builders/post/49859</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49859</guid><dc:creator><![CDATA[m0111k]]></dc:creator><pubDate>Wed, 09 Jan 2019 23:33:19 GMT</pubDate></item><item><title><![CDATA[Reply to Stop the screensaver! on Wed, 18 Apr 2018 11:44:39 GMT]]></title><description><![CDATA[<p dir="auto">I had the same problem where. I stumbled across this thread, check out the answer given by JimmyN… it helped me at least.</p>
]]></description><link>https://forum.magicmirror.builders/post/38578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38578</guid><dc:creator><![CDATA[Gabev]]></dc:creator><pubDate>Wed, 18 Apr 2018 11:44:39 GMT</pubDate></item></channel></rss>
