<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Blank screen after restarting magic mirror?]]></title><description><![CDATA[<p dir="auto">first of all, Merry Christmass to everyone !!<br />
After restarting the magic mirror i see blank screen, is this a common problem?<br />
i am restarting it with the remote module, telegram, pushbullet, but i get the same problem.</p>
<p dir="auto">this is the command that i executing and i get the black screen<br />
<img src="/assets/uploads/files/1545728940559-2018-12-25-2.png" alt="0_1545728948436_2018-12-25 (2).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/9315/blank-screen-after-restarting-magic-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 08:23:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9315.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Dec 2018 07:50:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Wed, 26 Dec 2018 12:02:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sollekram" aria-label="Profile: sollekram">@<bdi>sollekram</bdi></a> Awesome!</p>
]]></description><link>https://forum.magicmirror.builders/post/48575</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48575</guid><dc:creator><![CDATA[idoodler]]></dc:creator><pubDate>Wed, 26 Dec 2018 12:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Wed, 26 Dec 2018 11:55:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/idoodler" aria-label="Profile: idoodler">@<bdi>idoodler</bdi></a> year I saved the currently instances and now the problem solved ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/48574</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48574</guid><dc:creator><![CDATA[sollekram]]></dc:creator><pubDate>Wed, 26 Dec 2018 11:55:33 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Wed, 26 Dec 2018 09:52:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sollekram" aria-label="Profile: sollekram">@<bdi>sollekram</bdi></a> Ok, did you try to reboot your System yet?</p>
]]></description><link>https://forum.magicmirror.builders/post/48570</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48570</guid><dc:creator><![CDATA[idoodler]]></dc:creator><pubDate>Wed, 26 Dec 2018 09:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 21:20:27 GMT]]></title><description><![CDATA[<p dir="auto">To install the mm I had runned the installer automatically from <a href="http://github.com" target="_blank" rel="noopener noreferrer nofollow ugc">github.com</a> with curl,  and  then I have followed the guide for making it auto start at every boot. And then saved the instance</p>
]]></description><link>https://forum.magicmirror.builders/post/48543</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48543</guid><dc:creator><![CDATA[sollekram]]></dc:creator><pubDate>Tue, 25 Dec 2018 21:20:27 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 16:39:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sollekram" aria-label="Profile: sollekram">@<bdi>sollekram</bdi></a> Just make sure you only one method of starting MagicMirror. I prefere <code>pm2</code>. Did you start MagicMirror wit any other method except <code>pm2</code>? prior to <code>pm2 restart mm</code>?</p>
]]></description><link>https://forum.magicmirror.builders/post/48540</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48540</guid><dc:creator><![CDATA[idoodler]]></dc:creator><pubDate>Tue, 25 Dec 2018 16:39:14 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 16:31:18 GMT]]></title><description><![CDATA[<p dir="auto">Yeah it seems that 2 electro instances are open,  how can I avoid that,  what should I do to get away with the conflict?<br />
So every time that I restart it will be 👌?</p>
]]></description><link>https://forum.magicmirror.builders/post/48539</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48539</guid><dc:creator><![CDATA[sollekram]]></dc:creator><pubDate>Tue, 25 Dec 2018 16:31:18 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 10:45:48 GMT]]></title><description><![CDATA[<p dir="auto">It looks like you have multiple instances of MagicMirror running. I am not quite sure about that, but I the <code>pm2</code> mode is set to <code>fork</code> on my Pi.</p>
]]></description><link>https://forum.magicmirror.builders/post/48534</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48534</guid><dc:creator><![CDATA[idoodler]]></dc:creator><pubDate>Tue, 25 Dec 2018 10:45:48 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 10:12:08 GMT]]></title><description><![CDATA[<p dir="auto">it seems there is a conflict, i just kill some pid and now it is fine, but if i dont want to  have them again starting?</p>
]]></description><link>https://forum.magicmirror.builders/post/48533</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48533</guid><dc:creator><![CDATA[sollekram]]></dc:creator><pubDate>Tue, 25 Dec 2018 10:12:08 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 10:01:12 GMT]]></title><description><![CDATA[<p dir="auto">hmm<br />
<img src="/assets/uploads/files/1545732070323-2018-12-25-8.png" alt="0_1545732078005_2018-12-25 (8).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/48532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48532</guid><dc:creator><![CDATA[sollekram]]></dc:creator><pubDate>Tue, 25 Dec 2018 10:01:12 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 09:55:44 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1545731663686-2018-12-25-6.png" alt="0_1545731671345_2018-12-25 (6).png" class=" img-fluid img-markdown" /></p>
<p dir="auto">it seems it is something that produces an error but not fatal one, thats why i see a black screen.<br />
is the adress to listen wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/48530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48530</guid><dc:creator><![CDATA[sollekram]]></dc:creator><pubDate>Tue, 25 Dec 2018 09:55:44 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 09:52:01 GMT]]></title><description><![CDATA[<p dir="auto">hmmmm seems i got something thank you!!<br />
one moment to attach the image</p>
]]></description><link>https://forum.magicmirror.builders/post/48529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48529</guid><dc:creator><![CDATA[sollekram]]></dc:creator><pubDate>Tue, 25 Dec 2018 09:52:01 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 09:47:04 GMT]]></title><description><![CDATA[<p dir="auto">Did you install any new module? Please check the log via <code>pm2 log mm</code>. On the top there is the trailing last 15 lines of the error log, check it you may see some error on the <code>node.js</code> side.</p>
<p dir="auto">If you can’t see anything wrong you may want to look into the Webinterface and check if the browsers developer console throws an error.</p>
]]></description><link>https://forum.magicmirror.builders/post/48528</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48528</guid><dc:creator><![CDATA[idoodler]]></dc:creator><pubDate>Tue, 25 Dec 2018 09:47:04 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after restarting magic mirror? on Tue, 25 Dec 2018 09:13:36 GMT]]></title><description><![CDATA[<p dir="auto">this bug seems to appear after i restart the magic mirror many times</p>
]]></description><link>https://forum.magicmirror.builders/post/48526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48526</guid><dc:creator><![CDATA[sollekram]]></dc:creator><pubDate>Tue, 25 Dec 2018 09:13:36 GMT</pubDate></item></channel></rss>
