<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer]]></title><description><![CDATA[<p dir="auto">Here is my second module.</p>
<p dir="auto"><strong>Description</strong><br />
A module to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror. You can select services of your dreambox and stream them via omxplayer. The module shows some further informations like:</p>
<ul>
<li>model of your dreambox</li>
<li>which service is tuned right now / are there active timer</li>
<li>epg for the services with its starting time</li>
</ul>
<p dir="auto"><img src="https://raw.githubusercontent.com/Ax-LED/MMM-Dreambox/master/MMM-Dreambox_screenshot1.jpg" alt="Magic-Mirror Module MMM-Dreambox screenshot1" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>Download</strong><br />
[card:Ax-LED/MMM-Dreambox]</p>
<p dir="auto">Please let me know what you think.</p>
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/topic/9332/mmm-dreambox-to-connect-a-dreambox-or-a-enigma2-receiver-like-vu-or-vu-to-magicmirror-and-stream-stations-via-omxplayer</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 03:24:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9332.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Dec 2018 17:15:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Thu, 10 Nov 2022 22:13:20 GMT]]></title><description><![CDATA[<p dir="auto">Now I need some help,</p>
<ol>
<li>why doesn’t it show me the EPG info.</li>
<li>can I put it in 2 columns next to each other (to save space) with so many channels?<br />
and last but not least<br />
When you press DB-PLAY it takes about 5-10 seconds until the video comes, can you set a status bar with a sample message until the stream starts: Video coming or similar.</li>
</ol>
<p dir="auto">Thank you very much<br />
And this module is awesome :-)</p>
<p dir="auto"><img src="/assets/uploads/files/1668118385122-mmm-dreambox.png" alt="MMM-Dreambox.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/105747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105747</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Thu, 10 Nov 2022 22:13:20 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Thu, 10 Nov 2022 21:55:05 GMT]]></title><description><![CDATA[<p dir="auto">I solved it myself :-)</p>
<p dir="auto">The problem was that no video was played. With Omxplayer and the direct streamlink it did.</p>
<p dir="auto">But! My VU Solo2 sends 2 streams, one normal and one transcoded. I think the second one is the weakened one for weak players :-)</p>
<p dir="auto">The original stream goes through port 8001 and the transcoded one through 8002, and that was the solution.<br />
I changed that in the node_helper.js at DB-PLAY.</p>
<p dir="auto">It would be great if you could set this individually in the config.</p>
<hr />
<p dir="auto">Deutsch:<br />
Probblem war das kein Video abgespielt wurde. Mit Omxplayer und dem direkten streamlink hat es aber getan.</p>
<p dir="auto">Aber! Meine VU Solo2 sendet 2 streams, einmal den Normalen und einmal den Transkodierten. Ich denke der zweite ist der abgeschwächte für schwache Player :-)</p>
<p dir="auto">Der Original Stream läuft über den port 8001 und er Transkodierte über 8002, und das war die lösung.<br />
Ich habe das in der node_helper.js geändert bei DB-PLAY.</p>
<p dir="auto">Es wäre toll wenn man das in der Config Individuell einstellen könnte.</p>
]]></description><link>https://forum.magicmirror.builders/post/105746</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105746</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Thu, 10 Nov 2022 21:55:05 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Wed, 09 Nov 2022 22:25:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
many thanks<br />
Update:<br />
The list is coming and with <a href="http://192.168.3.140:8080/remote?action=NOTIFICATION&amp;notification=DB-SERVICE-NEXT" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.3.140:8080/remote?action=NOTIFICATION&amp;notification=DB-SERVICE-NEXT</a> i can go up and down in the Favourites.<br />
When i put <a href="http://192.168.3.140:8080/remote?action=NOTIFICATION&amp;notification=DB-PLAY" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.3.140:8080/remote?action=NOTIFICATION&amp;notification=DB-PLAY</a> in a browser,<br />
on the epglist comes the play sign but no video?<br />
The test with: <code>omxplayer http://192.168.3.105:8002/1:0:1:2F1D:441:1:C00000:0:0:0:</code><br />
is fine and the video is playing fine.</p>
<p dir="auto">any tip for me</p>
]]></description><link>https://forum.magicmirror.builders/post/105738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105738</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Wed, 09 Nov 2022 22:25:41 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Wed, 09 Nov 2022 12:16:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robiv8" aria-label="Profile: robiv8">@<bdi>robiv8</bdi></a> back up in the log output about 10 lines is the thing missing</p>
<p dir="auto">see<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105736</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105736</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Nov 2022 12:16:07 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Mon, 07 Nov 2022 22:25:59 GMT]]></title><description><![CDATA[<p dir="auto">Hallo, i installed the module like in github say.</p>
<p dir="auto">After install and restart! this is the log after starting:</p>
<pre><code>pi@InfoTerminal:~ $ tail -fn 20 /home/pi/.pm2/logs/MagicMirror-error.log
    at Module._compile (node:internal/modules/cjs/loader:1118:14)
    at Module._extensions..js (node:internal/modules/cjs/loader:1173:10) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js',
    '/home/pi/MagicMirror/js/app.js',
    '/home/pi/MagicMirror/js/electron.js',
    '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
    undefined
[07.11.2022 23:20.08.526] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[07.11.2022 23:20.08.527] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
MESA-LOADER: failed to retrieve device information
MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
failed to load swrast driver
<p dir="auto">any tip for me?<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/105730</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105730</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Mon, 07 Nov 2022 22:25:59 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Fri, 17 May 2019 07:49:10 GMT]]></title><description><![CDATA[<p dir="auto">Yes, works perfect as you can see on the picture.</p>
<p dir="auto"><img src="/assets/uploads/files/1558079312030-img_6446-resized.jpeg" alt="0_1558079311191_IMG_6446.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now I finally have to build the frame with the mirror ;-).</p>
]]></description><link>https://forum.magicmirror.builders/post/57118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57118</guid><dc:creator><![CDATA[Eisblume]]></dc:creator><pubDate>Fri, 17 May 2019 07:49:10 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Thu, 16 May 2019 15:52:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eisblume" aria-label="Profile: Eisblume">@<bdi>Eisblume</bdi></a><br />
I am glad the module works for you.<br />
Have fun.</p>
<p dir="auto">Greets</p>
]]></description><link>https://forum.magicmirror.builders/post/57081</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57081</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Thu, 16 May 2019 15:52:29 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Thu, 16 May 2019 05:44:09 GMT]]></title><description><![CDATA[<p dir="auto">Hey Guys,</p>
<p dir="auto">thanks a lot for your help. I checked everything you mentioned.</p>
<p dir="auto">But at last the problem was that I did everything which is written in the Tutorial for installing MagicMirror on a Raspberry ;-) !</p>
<p dir="auto">In the Tutorial for “Configuring the Raspberry Pi” is recommended to enable the OpenGL-Driver. I did it before installing anything else.<br />
But this was the Problem, when I disable this driver, omxplayer works fine with this module.</p>
]]></description><link>https://forum.magicmirror.builders/post/57073</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57073</guid><dc:creator><![CDATA[Eisblume]]></dc:creator><pubDate>Thu, 16 May 2019 05:44:09 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Wed, 15 May 2019 17:37:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eisblume" aria-label="Profile: Eisblume">@<bdi>Eisblume</bdi></a><br />
I have some ideas and need your feedback:</p>
<ul>
<li>is there a special reason why you are using the <code>dev branch</code>? If not, try the <code>master branch</code> instead</li>
<li>is streaming of recordings working?</li>
<li>your log shows that omx player is doing something, please consider it takes up to 15 seconds before a stream starts after you send <code>DB-Play</code></li>
<li>are your enigma2 settings on your VU like this (similar, the following screenshot is of a Dreambox DM800SE with a oozoon image):<br />
<img src="/assets/uploads/files/1557941730277-dm800se_screenshot1.jpg" alt="0_1557941727960_DM800SE_Screenshot1.JPG" class=" img-fluid img-markdown" /></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/57053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57053</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Wed, 15 May 2019 17:37:58 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Wed, 15 May 2019 15:48:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">What does <code>pm2 log</code>  say?</p>
<p dir="auto">And do you see omxplayer in the process list ?</p>
<pre><code>$ ps -eaf | grep omxplayer | grep -v grep
<p dir="auto">Finally, can you see if omxplayer works standalone ?</p>
<pre><code>$ omxplayer --vol -6000 --win "0 0 720 576" --live http://192.168.1.50:8001/1:0:19:2B66:3F3:1:C00000:0:0:0:
]]></description><link>https://forum.magicmirror.builders/post/57050</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57050</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Wed, 15 May 2019 15:48:23 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Wed, 15 May 2019 12:01:49 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">i also have a streaming problem, maybe you could help me.</p>
<p dir="auto">I cloned the dev - branch and connected with my Vu+ Ultimo 4K. The Bouquet-List is shown on my MagicMirror, but when i switch to a channel and want to stream, nothing happened. MPG2-License is installed on my RPI3.</p>
<p dir="auto">My config:</p>
<pre><code>	        module: 'MMM-Dreambox',
			header: 'Vu+ Ultimo4K powered by VTi',
			position: 'bottom_left',
				apiBase: 'http://192.168.1.50:90',
				omxargs: ' --genlog --win 320,180,1600,900 -o both ',
				refreshInterval: 1000 * 30, //refresh every 30 seconds
				apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices),
				apiRecordingsID: 0, //which recording folder should be listed
				listmax: 10,
				apiabout: '/web/about',
				apiservices: '/web/getallservices',
				apiepgnow: '/web/epgnow?bRef=',
				apizap: '/web/zap?sRef=',
				apiTimerlist: '/web/timerlist',
				apiServicelistplayable: '/web/servicelistplayable?sRef=',
				apiLocations: '/web/getlocations', //where are the recording folders listed
				apiMovielist: '/web/movielist?dirname=' //link for opening recording folder and list recordings
<p dir="auto">LOG:</p>
<pre><code>11:51:56 T:18446744072748435108   DEBUG: DllBcm: Using omx system library
11:51:56 T:18446744072748437218   DEBUG: DllOMX: Using omx system library
11:51:56 T:18446744072748438188   DEBUG: DllAvFormat: Using libavformat system library
11:51:56 T:18446744072748440537 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
11:51:56 T:18446744072748440974 WARNING: DBus connection failed, trying alternate
11:51:56 T:18446744072748442960   DEBUG: DBus connection succeeded
11:51:56 T:18446744072748444308   DEBUG: Keyboard: DBus connection succeeded
11:51:56 T:18446744072748444536   DEBUG: OMXThread::Create - Thread with id 1855955424 started
11:51:56 T:18446744072748444712   DEBUG: DllAvUtilBase: Using libavutil system library
11:51:56 T:18446744072748444743   DEBUG: DllAvCodec: Using libavcodec system library
11:51:56 T:18446744072748444765   DEBUG: DllAvFormat: Using libavformat system library
11:51:56 T:18446744072748445900   DEBUG: COMXPlayer::OpenFile - avformat_open_input http://192.168.1.50:8001/1:0:19:2B66:3F3:1:C00000:0:0:0:
11:51:59 T:18446744072751434345   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
11:52:02 T:18446744072754462336   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x2108d10
11:52:02 T:18446744072754462735   DEBUG: OMXClock::OMXStop
11:52:02 T:18446744072754462891   DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
11:52:02 T:18446744072754463128   DEBUG: DllAvUtilBase: Using libavutil system library
11:52:02 T:18446744072754463154   DEBUG: DllAvCodec: Using libavcodec system library
11:52:02 T:18446744072754463176   DEBUG: DllAvFormat: Using libavformat system library
11:52:02 T:18446744072754464909   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_decode input port 130 output port 131 m_handle 0x21cb9a0
11:52:02 T:18446744072754466025   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - port(130), nBufferCountMin(1), nBufferCountActual(60), nBufferSize(81920), nBufferAlignmen(16)
11:52:02 T:18446744072754475930   DEBUG: COMXVideo::Open - decoder_component(0x0x21cb9a0), input_port(0x82), output_port(0x83) deinterlace 1 hdmiclocksync 0
11:52:02 T:18446744072754476291   DEBUG: OMXThread::Create - Thread with id 1843392992 started
11:52:02 T:18446744072754476455   DEBUG: OMXThread::Create - Thread with id 1835000288 started
11:52:02 T:18446744072754476561   DEBUG: DllAvUtilBase: Using libavutil system library
11:52:02 T:18446744072754476617   DEBUG: DllAvCodec: Using libavcodec system library
11:52:02 T:18446744072754476649   DEBUG: DllAvFormat: Using libavformat system library
11:52:02 T:18446744072754476683   DEBUG: DllAvUtilBase: Using libavutil system library
11:52:02 T:18446744072754476707   DEBUG: DllAvCodec: Using libavcodec system library
11:52:02 T:18446744072754476739   DEBUG: DllAvFormat: Using libswresample system library
11:52:02 T:18446744072754476943   ERROR: OMXPlayerSubtitles::RenderLoop threw 13Enforce_error (Enforcement failed in SubtitleRenderer.cpp(293))
11:52:02 T:18446744072754477009   DEBUG: OMXThread::Run - Exited thread with  id 1835000288
11:52:02 T:18446744072754477073    INFO: COMXAudioCodecOMX::GetChannelMap - FFmpeg reported 2 channels, but the layout contains 0 ignoring
11:52:02 T:18446744072754477119   DEBUG: DllAvUtilBase: Using libavutil system library
11:52:02 T:18446744072754477149   DEBUG: COMXAudio::SetCodingType OMX_AUDIO_CodingPCM
11:52:02 T:18446744072754477190    INFO: CPCMRemap: I channel map: FL,FR
11:52:02 T:18446744072754477271    INFO: CPCMRemap: O channel map: FL,FR
11:52:02 T:18446744072754477301   DEBUG: CPCMRemap: Downmix normalization is disabled
11:52:02 T:18446744072754477360   DEBUG: CPCMRemap: FL = FL(1.000000*)
11:52:02 T:18446744072754477390   DEBUG: CPCMRemap: FR = FR(1.000000*)
11:52:02 T:18446744072754479069   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_decode input port 120 output port 121 m_handle 0x21cb930
11:52:02 T:18446744072754480288   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_decode) - port(120), nBufferCountMin(4), nBufferCountActual(16), nBufferSize(65536), nBufferAlignmen(16)
11:52:02 T:18446744072754492628   DEBUG: COMXAudio::Initialize Input bps 32 samplerate 48000 channels 2 buffer size 576000 bytes per second 384000
11:52:02 T:18446744072754492747   DEBUG: pcm-&gt;direction      : input
11:52:02 T:18446744072754492777   DEBUG: pcm-&gt;nPortIndex     : 120
11:52:02 T:18446744072754492803   DEBUG: pcm-&gt;eNumData       : 0
11:52:02 T:18446744072754492825   DEBUG: pcm-&gt;eEndian        : 1
11:52:02 T:18446744072754492850   DEBUG: pcm-&gt;bInterleaved   : 1
11:52:02 T:18446744072754492875   DEBUG: pcm-&gt;nBitPerSample  : 32
11:52:02 T:18446744072754492898   DEBUG: pcm-&gt;ePCMMode       : 0
11:52:02 T:18446744072754492920   DEBUG: pcm-&gt;nChannels      : 2
11:52:02 T:18446744072754492944   DEBUG: pcm-&gt;nSamplingRate  : 48000
11:52:02 T:18446744072754492965   DEBUG: OMX_AUDIO_ChannelLF
11:52:02 T:18446744072754492989   DEBUG: OMX_AUDIO_ChannelRF
11:52:02 T:18446744072754493013   DEBUG: COMXAudio::Initialize device omx:both passthrough 0 hwdecode 0
11:52:02 T:18446744072754493239   DEBUG: OMXThread::Create - Thread with id 1826607584 started
11:52:02 T:18446744072754493299  NOTICE: OMXClock using audio as reference
11:52:02 T:18446744072754493559   DEBUG: OMXClock::OMXReset audio / video : 1 / 1 wait mask 0-&gt;3 state : 2-&gt;1
11:52:02 T:18446744072754493965   DEBUG: Popped message member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
11:52:02 T:18446744072754494024 WARNING: Unhandled dbus message, member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
11:52:02 T:18446744072754494181   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:1 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.07)
11:52:02 T:18446744072754494410    INFO: CDVDPlayerVideo::Decode dts:579978 pts:620000 cur:620000, size:38830
11:52:02 T:18446744072754494468   DEBUG: OMXVideo::Decode VDec : setStartTime 0.620000
11:52:02 T:18446744072754495015    INFO: CDVDPlayerAudio::Decode dts:101734 pts:101734 size:782
11:52:02 T:18446744072754495431    INFO: CDVDPlayerVideo::Decode dts:599978 pts:600000 cur:600000, size:22063
11:52:02 T:18446744072754495946   DEBUG: COMXAudioCodecOMX::Decode(0x2130f30,782) format=6(8) chan=2 samples=1152 size=2304 data=0x6c400560,0x6c400f30,(nil),(nil),(nil),(nil),(nil),(nil)
11:52:02 T:18446744072754496546   DEBUG: COMXAudioCodecOMX::GetData size=4608/9216 line=2304/4608 buf=0x6c4018a8, desired=65536
11:52:02 T:18446744072754496794    INFO: CDVDPlayerVideo::Decode dts:619978 pts:640000 cur:640000, size:20976
11:52:02 T:18446744072754496900    INFO: CDVDPlayerAudio::Decode dts:125734 pts:125734 size:768
11:52:02 T:18446744072754497501    INFO: CDVDPlayerVideo::Decode dts:639978 pts:740000 cur:740000, size:49029
11:52:02 T:18446744072754497937    INFO: CDVDPlayerAudio::Decode dts:149734 pts:149734 size:768
11:52:02 T:18446744072754498443    INFO: CDVDPlayerAudio::Decode dts:173734 pts:173734 size:768
11:52:02 T:18446744072754498577    INFO: CDVDPlayerVideo::Decode dts:659978 pts:700000 cur:700000, size:33312
11:52:02 T:18446744072754499257    INFO: CDVDPlayerAudio::Decode dts:197734 pts:197734 size:768
11:52:02 T:18446744072754499877    INFO: CDVDPlayerAudio::Decode dts:221734 pts:221734 size:782
11:52:02 T:18446744072754500450    INFO: CDVDPlayerAudio::Decode dts:245734 pts:245734 size:768
11:52:02 T:18446744072754500879    INFO: CDVDPlayerAudio::Decode dts:269734 pts:269734 size:768
11:52:02 T:18446744072754501563   DEBUG: COMXAudio::Decode ADec : setStartTime 0.101733
11:52:02 T:18446744072754506083    INFO: CDVDPlayerVideo::Decode dts:679978 pts:680000 cur:680000, size:20826
11:52:02 T:18446744072754507862    INFO: CDVDPlayerVideo::Decode dts:699978 pts:720000 cur:720000, size:22291
11:52:02 T:18446744072754509115    INFO: CDVDPlayerVideo::Decode dts:719978 pts:820000 cur:820000, size:48896
11:52:02 T:18446744072754510007    INFO: CDVDPlayerVideo::Decode dts:739978 pts:780000 cur:780000, size:29819
11:52:02 T:18446744072754510702   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231 m_handle 0x6c415f20
11:52:02 T:18446744072754510922    INFO: CDVDPlayerVideo::Decode dts:759978 pts:760000 cur:760000, size:17747
11:52:02 T:18446744072754511602    INFO: CDVDPlayerVideo::Decode dts:779978 pts:800000 cur:800000, size:21012
11:52:02 T:18446744072754512703    INFO: CDVDPlayerVideo::Decode dts:799978 pts:900000 cur:900000, size:55598
11:52:02 T:18446744072754513370    INFO: CDVDPlayerVideo::Decode dts:819978 pts:860000 cur:860000, size:41374
11:52:02 T:18446744072754514202    INFO: CDVDPlayerVideo::Decode dts:839978 pts:840000 cur:840000, size:20662
11:52:02 T:18446744072754514839    INFO: CDVDPlayerVideo::Decode dts:859978 pts:880000 cur:880000, size:20566
11:52:02 T:18446744072754515314   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_splitter input port 261 output port 262 m_handle 0x6c400498
11:52:02 T:18446744072754515406    INFO: CDVDPlayerVideo::Decode dts:879978 pts:980000 cur:980000, size:47687
11:52:02 T:18446744072754515454   DEBUG: Popped message member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
11:52:02 T:18446744072754515597 WARNING: Unhandled dbus message, member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
11:52:02 T:18446744072754516290    INFO: CDVDPlayerVideo::Decode dts:899978 pts:940000 cur:940000, size:29649
11:52:02 T:18446744072754516851    INFO: CDVDPlayerVideo::Decode dts:919978 pts:920000 cur:920000, size:20177
11:52:02 T:18446744072754517306    INFO: CDVDPlayerVideo::Decode dts:939978 pts:960000 cur:960000, size:25105
11:52:02 T:18446744072754517345   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x6c4160f0
11:52:02 T:18446744072754517888    INFO: CDVDPlayerVideo::Decode dts:959978 pts:1000000 cur:1000000, size:79994
11:52:02 T:18446744072754518996    INFO: CDVDPlayerVideo::Decode dts:979978 pts:1080000 cur:1080000, size:56353
11:52:02 T:18446744072754519965    INFO: CDVDPlayerVideo::Decode dts:999978 pts:1040000 cur:1040000, size:41364
11:52:02 T:18446744072754520216   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x6c4161c0
11:52:02 T:18446744072754520520    INFO: COMXAudio::ApplyVolume - Volume=1.00 (* 1.00 * 1.00)
11:52:02 T:18446744072754520617    INFO: CDVDPlayerVideo::Decode dts:1019978 pts:1020000 cur:1020000, size:23672
11:52:02 T:18446744072754521516   DEBUG: COMXAudio::PortSettingsChanged - Output bps 16 samplerate 48000 channels 2 buffer size 576000 bytes per second 192000
11:52:02 T:18446744072754521645    INFO: CDVDPlayerVideo::Decode dts:1039978 pts:1060000 cur:1060000, size:24216
11:52:02 T:18446744072754521706   DEBUG: pcm-&gt;direction      : output
11:52:02 T:18446744072754521737   DEBUG: pcm-&gt;nPortIndex     : 231
11:52:02 T:18446744072754521773   DEBUG: pcm-&gt;eNumData       : 0
11:52:02 T:18446744072754521802   DEBUG: pcm-&gt;eEndian        : 1
11:52:02 T:18446744072754521832   DEBUG: pcm-&gt;bInterleaved   : 1
11:52:02 T:18446744072754521854   DEBUG: pcm-&gt;nBitPerSample  : 16
11:52:02 T:18446744072754521875   DEBUG: pcm-&gt;ePCMMode       : 0
11:52:02 T:18446744072754521897   DEBUG: pcm-&gt;nChannels      : 2
11:52:02 T:18446744072754521918   DEBUG: pcm-&gt;nSamplingRate  : 48000
11:52:02 T:18446744072754521938   DEBUG: OMX_AUDIO_ChannelLF
11:52:02 T:18446744072754521962   DEBUG: OMX_AUDIO_ChannelRF
11:52:02 T:18446744072754522650    INFO: CDVDPlayerVideo::Decode dts:1059978 pts:1160000 cur:1160000, size:52784
11:52:02 T:18446744072754523338    INFO: CDVDPlayerVideo::Decode dts:1079978 pts:1120000 cur:1120000, size:36614
11:52:02 T:18446744072754523817    INFO: CDVDPlayerVideo::Decode dts:1099978 pts:1100000 cur:1100000, size:22682
11:52:02 T:18446744072754524392    INFO: CDVDPlayerVideo::Decode dts:1119978 pts:1140000 cur:1140000, size:23151
11:52:02 T:18446744072754524959    INFO: CDVDPlayerVideo::Decode dts:1139978 pts:1240000 cur:1240000, size:50413
11:52:02 T:18446744072754525560    INFO: CDVDPlayerVideo::Decode dts:1159978 pts:1200000 cur:1200000, size:40547
11:52:02 T:18446744072754526169    INFO: CDVDPlayerVideo::Decode dts:1179978 pts:1180000 cur:1180000, size:22771
11:52:02 T:18446744072754526738    INFO: CDVDPlayerVideo::Decode dts:1199978 pts:1220000 cur:1220000, size:22696
11:52:02 T:18446744072754527309    INFO: CDVDPlayerVideo::Decode dts:1219978 pts:1320000 cur:1320000, size:59286
11:52:02 T:18446744072754527937    INFO: CDVDPlayerVideo::Decode dts:1239978 pts:1280000 cur:1280000, size:34118
11:52:02 T:18446744072754528510    INFO: CDVDPlayerVideo::Decode dts:1259978 pts:1260000 cur:1260000, size:19347
11:52:02 T:18446744072754528967    INFO: CDVDPlayerVideo::Decode dts:1279978 pts:1300000 cur:1300000, size:19724
11:52:02 T:18446744072754529478   DEBUG: COMXAudio::PortSettingsChanged - bits:32 mode:0 channels:2 srate:48000 nopassthrough
11:52:02 T:18446744072754529598    INFO: CDVDPlayerVideo::Decode dts:1299978 pts:1400000 cur:1400000, size:52410
11:52:02 T:18446744072754530353    INFO: CDVDPlayerVideo::Decode dts:1319978 pts:1360000 cur:1360000, size:34922
11:52:02 T:18446744072754530932    INFO: CDVDPlayerVideo::Decode dts:1339978 pts:1340000 cur:1340000, size:19939
11:52:02 T:18446744072754531365    INFO: CDVDPlayerVideo::Decode dts:1359978 pts:1380000 cur:1380000, size:20313
11:52:02 T:18446744072754532419    INFO: CDVDPlayerVideo::Decode dts:1379978 pts:1480000 cur:1480000, size:57283
11:52:02 T:18446744072754533143    INFO: CDVDPlayerVideo::Decode dts:1399978 pts:1440000 cur:1440000, size:36849
11:52:02 T:18446744072754533730    INFO: CDVDPlayerVideo::Decode dts:1419978 pts:1420000 cur:1420000, size:21832
11:52:02 T:18446744072754534664    INFO: CDVDPlayerVideo::Decode dts:1439978 pts:1460000 cur:1460000, size:22125
11:52:02 T:18446744072754535306    INFO: CDVDPlayerVideo::Decode dts:1459978 pts:1560000 cur:1560000, size:60120
11:52:02 T:18446744072754536287    INFO: CDVDPlayerVideo::Decode dts:1479978 pts:1520000 cur:1520000, size:40186
11:52:02 T:18446744072754537186    INFO: CDVDPlayerVideo::Decode dts:1499978 pts:1500000 cur:1500000, size:18653
11:52:02 T:18446744072754538167    INFO: CDVDPlayerVideo::Decode dts:1519978 pts:1540000 cur:1540000, size:19150
11:52:02 T:18446744072754539275    INFO: CDVDPlayerVideo::Decode dts:1539978 pts:1640000 cur:1640000, size:62148
11:52:02 T:18446744072754540425    INFO: CDVDPlayerVideo::Decode dts:1559978 pts:1600000 cur:1600000, size:36130
11:52:02 T:18446744072754541034    INFO: CDVDPlayerVideo::Decode dts:1579978 pts:1580000 cur:1580000, size:25455
11:52:02 T:18446744072754541592    INFO: CDVDPlayerVideo::Decode dts:1599978 pts:1620000 cur:1620000, size:20837
11:52:02 T:18446744072754542309   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.audio_decode - OMX_ErrorInsufficientResources, insufficient resources
11:52:02 T:18446744072754543328    INFO: CDVDPlayerVideo::Decode dts:1619978 pts:1720000 cur:1720000, size:58306
11:52:02 T:18446744072754544626    INFO: CDVDPlayerVideo::Decode dts:1639978 pts:1680000 cur:1680000, size:36670
11:52:02 T:18446744072754545576    INFO: CDVDPlayerVideo::Decode dts:1659978 pts:1660000 cur:1660000, size:27504
11:52:02 T:18446744072754546418    INFO: CDVDPlayerVideo::Decode dts:1679978 pts:1700000 cur:1700000, size:27320
11:52:02 T:18446744072754554347    INFO: CDVDPlayerVideo::Decode dts:1699978 pts:1800000 cur:1800000, size:58452
11:52:02 T:18446744072754555568    INFO: CDVDPlayerVideo::Decode dts:1719978 pts:1760000 cur:1760000, size:39294
11:52:02 T:18446744072754556286    INFO: CDVDPlayerVideo::Decode dts:1739978 pts:1740000 cur:1740000, size:23306
11:52:02 T:18446744072754556955    INFO: CDVDPlayerVideo::Decode dts:1759978 pts:1780000 cur:1780000, size:21371
11:52:02 T:18446744072754557597    INFO: CDVDPlayerVideo::Decode dts:1779978 pts:1820000 cur:1820000, size:77382
11:52:02 T:18446744072754558836    INFO: CDVDPlayerVideo::Decode dts:1799978 pts:1900000 cur:1900000, size:53764
11:52:02 T:18446744072754559861    INFO: CDVDPlayerVideo::Decode dts:1819978 pts:1860000 cur:1860000, size:34809
11:52:02 T:18446744072754560506    INFO: CDVDPlayerVideo::Decode dts:1839978 pts:1840000 cur:1840000, size:20027
11:52:02 T:18446744072754561186    INFO: CDVDPlayerVideo::Decode dts:1859978 pts:1880000 cur:1880000, size:21149
11:52:02 T:18446744072754562100    INFO: CDVDPlayerVideo::Decode dts:1879978 pts:1980000 cur:1980000, size:55266
11:52:02 T:18446744072754562735    INFO: CDVDPlayerVideo::Decode dts:1899978 pts:1940000 cur:1940000, size:35319
11:52:02 T:18446744072754563372    INFO: CDVDPlayerVideo::Decode dts:1919978 pts:1920000 cur:1920000, size:21445
11:52:02 T:18446744072754563904    INFO: CDVDPlayerVideo::Decode dts:1939978 pts:1960000 cur:1960000, size:20460
11:52:02 T:18446744072754564505    INFO: CDVDPlayerVideo::Decode dts:1959978 pts:2060000 cur:2060000, size:59220
11:52:02 T:18446744072754565233    INFO: CDVDPlayerVideo::Decode dts:1979978 pts:2020000 cur:2020000, size:30488
11:52:02 T:18446744072754565902    INFO: CDVDPlayerVideo::Decode dts:1999978 pts:2000000 cur:2000000, size:16162
11:52:02 T:18446744072754566412    INFO: CDVDPlayerVideo::Decode dts:2019978 pts:2040000 cur:2040000, size:17207
11:52:02 T:18446744072754566872    INFO: CDVDPlayerVideo::Decode dts:2039978 pts:2140000 cur:2140000, size:51194
11:52:02 T:18446744072754571047    INFO: CDVDPlayerVideo::Decode dts:2059978 pts:2100000 cur:2100000, size:29320
11:52:02 T:18446744072754572604    INFO: CDVDPlayerVideo::Decode dts:2079978 pts:2080000 cur:2080000, size:16653
11:52:02 T:18446744072754573029    INFO: CDVDPlayerVideo::Decode dts:2099978 pts:2120000 cur:2120000, size:20551
11:52:02 T:18446744072754573458    INFO: CDVDPlayerVideo::Decode dts:2119978 pts:2220000 cur:2220000, size:73307
11:52:02 T:18446744072754574275    INFO: CDVDPlayerVideo::Decode dts:2139978 pts:2180000 cur:2180000, size:29475
11:52:02 T:18446744072754574774    INFO: CDVDPlayerVideo::Decode dts:2159978 pts:2160000 cur:2160000, size:17045
11:52:02 T:18446744072754575155    INFO: CDVDPlayerVideo::Decode dts:2179978 pts:2200000 cur:2200000, size:17053
11:52:02 T:18446744072754575579    INFO: CDVDPlayerVideo::Decode dts:2199978 pts:2300000 cur:2300000, size:55457
11:52:02 T:18446744072754576343    INFO: CDVDPlayerVideo::Decode dts:2219978 pts:2260000 cur:2260000, size:29357
11:52:02 T:18446744072754576825    INFO: CDVDPlayerVideo::Decode dts:2239978 pts:2240000 cur:2240000, size:16611
11:52:02 T:18446744072754577188    INFO: CDVDPlayerVideo::Decode dts:2259978 pts:2280000 cur:2280000, size:17411
11:52:02 T:18446744072754577572    INFO: CDVDPlayerVideo::Decode dts:2279978 pts:2380000 cur:2380000, size:52161
11:52:02 T:18446744072754578129    INFO: CDVDPlayerVideo::Decode dts:2299978 pts:2340000 cur:2340000, size:29740
11:52:02 T:18446744072754578601    INFO: CDVDPlayerVideo::Decode dts:2319978 pts:2320000 cur:2320000, size:19979
11:52:02 T:18446744072754579143    INFO: CDVDPlayerVideo::Decode dts:2339978 pts:2360000 cur:2360000, size:16378
11:52:02 T:18446744072754579548    INFO: CDVDPlayerVideo::Decode dts:2359978 pts:2460000 cur:2460000, size:60321
11:52:02 T:18446744072754580295    INFO: CDVDPlayerVideo::Decode dts:2379978 pts:2420000 cur:2420000, size:35591
11:52:02 T:18446744072754580808    INFO: CDVDPlayerVideo::Decode dts:2399978 pts:2400000 cur:2400000, size:21597
11:52:02 T:18446744072754581226    INFO: CDVDPlayerVideo::Decode dts:2419978 pts:2440000 cur:2440000, size:21746
11:52:02 T:18446744072754582316    INFO: CDVDPlayerVideo::Decode dts:2439978 pts:2480000 cur:2480000, size:99011
11:52:02 T:18446744072754583425    INFO: CDVDPlayerVideo::Decode dts:2459978 pts:2560000 cur:2560000, size:71080
11:52:02 T:18446744072754584093    INFO: CDVDPlayerVideo::Decode dts:2479978 pts:2520000 cur:2520000, size:43871
11:52:02 T:18446744072754584606    INFO: CDVDPlayerVideo::Decode dts:2499978 pts:2500000 cur:2500000, size:17682
11:52:02 T:18446744072754584974    INFO: CDVDPlayerVideo::Decode dts:2519978 pts:2540000 cur:2540000, size:17928
11:52:02 T:18446744072754585329    INFO: CDVDPlayerVideo::Decode dts:2539978 pts:2640000 cur:2640000, size:53824
11:52:02 T:18446744072754585890    INFO: CDVDPlayerVideo::Decode dts:2559978 pts:2600000 cur:2600000, size:30944
11:52:02 T:18446744072754586292    INFO: CDVDPlayerVideo::Decode dts:2579978 pts:2580000 cur:2580000, size:18211
11:52:02 T:18446744072754586662    INFO: CDVDPlayerVideo::Decode dts:2599978 pts:2620000 cur:2620000, size:17724
11:52:02 T:18446744072754587039    INFO: CDVDPlayerVideo::Decode dts:2619978 pts:2720000 cur:2720000, size:63718
11:52:02 T:18446744072754587824    INFO: CDVDPlayerVideo::Decode dts:2639978 pts:2680000 cur:2680000, size:37042
11:52:02 T:18446744072754588438    INFO: CDVDPlayerVideo::Decode dts:2659978 pts:2660000 cur:2660000, size:21339
11:52:02 T:18446744072754588895    INFO: CDVDPlayerVideo::Decode dts:2679978 pts:2700000 cur:2700000, size:15947
11:52:02 T:18446744072754589273    INFO: CDVDPlayerVideo::Decode dts:2699978 pts:2800000 cur:2800000, size:48633
11:52:02 T:18446744072754620090    INFO: CDVDPlayerVideo::Decode dts:2719978 pts:2760000 cur:2760000, size:27974
11:52:02 T:18446744072754620819    INFO: CDVDPlayerVideo::Decode dts:2739978 pts:2740000 cur:2740000, size:11853
11:52:02 T:18446744072754621427    INFO: CDVDPlayerVideo::Decode dts:2759978 pts:2780000 cur:2780000, size:11740
11:52:02 T:18446744072754632560    INFO: CDVDPlayerVideo::Decode dts:2779978 pts:2880000 cur:2880000, size:66130
11:52:02 T:18446744072754633306    INFO: CDVDPlayerVideo::Decode dts:2799978 pts:2840000 cur:2840000, size:33760
11:52:02 T:18446744072754654067    INFO: CDVDPlayerVideo::Decode dts:2819978 pts:2820000 cur:2820000, size:17500
11:52:02 T:18446744072754655142    INFO: CDVDPlayerVideo::Decode dts:2839978 pts:2860000 cur:2860000, size:15348
11:52:02 T:18446744072754655705    INFO: CDVDPlayerVideo::Decode dts:2859978 pts:2960000 cur:2960000, size:72718
11:52:02 T:18446744072754666553    INFO: CDVDPlayerVideo::Decode dts:2879978 pts:2920000 cur:2920000, size:28342
11:52:02 T:18446744072754689129    INFO: CDVDPlayerVideo::Decode dts:2899978 pts:2900000 cur:2900000, size:15326
11:52:02 T:18446744072754690107    INFO: CDVDPlayerVideo::Decode dts:2919978 pts:2940000 cur:2940000, size:17144
11:52:02 T:18446744072754690828    INFO: CDVDPlayerVideo::Decode dts:2939978 pts:3040000 cur:3040000, size:61126
11:52:02 T:18446744072754723108    INFO: CDVDPlayerVideo::Decode dts:2959978 pts:3000000 cur:3000000, size:29458
11:52:02 T:18446744072754726792   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_render input port 90 output port 90 m_handle 0x6df005d0
11:52:02 T:18446744072754726930   DEBUG: COMXVideo::PortSettingsChangedLogger - 1280x720@50.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
11:52:02 T:18446744072754730242   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_scheduler input port 10 output port 11 m_handle 0x6df006e0
11:52:02 T:18446744072754740320    INFO: CDVDPlayerVideo::Decode dts:2979978 pts:2980000 cur:2980000, size:16106
11:52:02 T:18446744072754741709    INFO: CDVDPlayerVideo::Decode dts:2999978 pts:3020000 cur:3020000, size:16905
11:52:02 T:18446744072754742906    INFO: CDVDPlayerVideo::Decode dts:3019978 pts:3120000 cur:3120000, size:47597
11:52:02 T:18446744072754743888    INFO: CDVDPlayerVideo::Decode dts:3039978 pts:3080000 cur:3080000, size:27772
11:52:02 T:18446744072754756172    INFO: CDVDPlayerVideo::Decode dts:3059978 pts:3060000 cur:3060000, size:16047
11:52:02 T:18446744072754757372    INFO: CDVDPlayerVideo::Decode dts:3079978 pts:3100000 cur:3100000, size:23222
11:52:02 T:18446744072754779147    INFO: CDVDPlayerVideo::Decode dts:3099978 pts:3140000 cur:3140000, size:111109
11:52:02 T:18446744072754791345    INFO: CDVDPlayerVideo::Decode dts:3119978 pts:3220000 cur:3220000, size:68499
11:52:02 T:18446744072754793039    INFO: CDVDPlayerVideo::Decode dts:3139978 pts:3180000 cur:3180000, size:39854
11:52:02 T:18446744072754793921    INFO: CDVDPlayerVideo::Decode dts:3159978 pts:3160000 cur:3160000, size:19475
11:52:02 T:18446744072754795805    INFO: CDVDPlayerVideo::Decode dts:3179978 pts:3200000 cur:3200000, size:21175
11:52:04 T:18446744072756530949   ERROR: COMXCoreComponent::WaitForCommand OMX.broadcom.audio_mixer wait timeout event.eEvent 0x00000000 event.command 0x00000000 event.nData2 2
11:52:04 T:18446744072756531115   ERROR: COMXCoreComponent::WaitForCommand - OMX.broadcom.audio_mixer failed with omx_err(0x80001011)
11:52:04 T:18446744072756531149   ERROR: COMXCoreComponent::Establish - Error setting state to idle OMX.broadcom.audio_decode omx_err(0x80001011)
11:52:04 T:18446744072756531175   ERROR: COMXAudio::PortSettingsChanged - m_omx_tunnel_decoder.Establish omx_err(0x80001011)
11:52:04 T:18446744072756531200   ERROR: COMXAudio::AddPackets - error PortSettingsChanged omx_err(0x00000000)
11:52:04 T:18446744072756531370    INFO: COMXAudio::ApplyVolume - Volume=1.00 (* 1.00 * 1.00)
11:52:04 T:18446744072756531426    INFO: CDVDPlayerAudio::Decode dts:293734 pts:293734 size:768
11:52:04 T:18446744072756531529   DEBUG: Normal M:0 (A:269734 V:980000) P:1 A:0.27 V:0.98/T:0.20 (0,0,1,1) A:2% V:41% (0.10,6.07)
11:52:04 T:18446744072756531636   DEBUG: Resume 0.27,0.98 (0,0,1,1) EOF:0 PKT:(nil)
11:52:04 T:18446744072756531665   DEBUG: OMXClock::OMXSetSpeed(1.00) pause_resume:1
11:52:04 T:18446744072756531811    INFO: CDVDPlayerAudio::Decode dts:317734 pts:317734 size:768
11:52:04 T:18446744072756532071    INFO: CDVDPlayerAudio::Decode dts:341734 pts:341734 size:782
11:52:04 T:18446744072756532349    INFO: CDVDPlayerAudio::Decode dts:365734 pts:365734 size:768
11:52:04 T:18446744072756532653    INFO: CDVDPlayerAudio::Decode dts:389734 pts:389734 size:768
11:52:04 T:18446744072756532721   DEBUG: Normal M:0 (A:365734 V:3300000) P:0 A:0.37 V:3.30/T:0.20 (0,0,1,1) A:2% V:2% (0.10,6.07)
11:52:04 T:18446744072756532941    INFO: CDVDPlayerAudio::Decode dts:413734 pts:413734 size:768
11:52:04 T:18446744072756533222    INFO: CDVDPlayerAudio::Decode dts:437734 pts:437734 size:768
11:52:04 T:18446744072756533506   ERROR: COMXAudio::Decode timeout
11:52:04 T:18446744072756533602    INFO: CDVDPlayerAudio::Decode dts:461734 pts:461734 size:782
11:52:04 T:18446744072756533956    INFO: CDVDPlayerAudio::Decode dts:485734 pts:485734 size:768
11:52:04 T:18446744072756534407    INFO: CDVDPlayerAudio::Decode dts:509734 pts:509734 size:768
11:52:04 T:18446744072756534711    INFO: CDVDPlayerAudio::Decode dts:533734 pts:533734 size:768
11:52:04 T:18446744072756535036    INFO: CDVDPlayerAudio::Decode dts:557734 pts:557734 size:768
11:52:04 T:18446744072756535328    INFO: CDVDPlayerAudio::Decode dts:581734 pts:581734 size:782
11:52:04 T:18446744072756535738    INFO: CDVDPlayerAudio::Decode dts:605734 pts:605734 size:768
11:52:04 T:18446744072756536464   ERROR: COMXAudio::Decode timeout
11:52:04 T:18446744072756536717    INFO: CDVDPlayerAudio::Decode dts:629734 pts:629734 size:768
11:52:04 T:18446744072756537743    INFO: CDVDPlayerAudio::Decode dts:653734 pts:653734 size:768
11:52:04 T:18446744072756538317    INFO: CDVDPlayerAudio::Decode dts:677734 pts:677734 size:768
11:52:04 T:18446744072756538868    INFO: CDVDPlayerAudio::Decode dts:701734 pts:701734 size:782
11:52:04 T:18446744072756539324    INFO: CDVDPlayerAudio::Decode dts:725734 pts:725734 size:768
11:52:04 T:18446744072756539682    INFO: CDVDPlayerAudio::Decode dts:749734 pts:749734 size:768
11:52:04 T:18446744072756540051    INFO: CDVDPlayerAudio::Decode dts:773734 pts:773734 size:768
11:52:04 T:18446744072756540417   ERROR: COMXAudio::Decode timeout
11:52:04 T:18446744072756540483    INFO: CDVDPlayerAudio::Decode dts:797734 pts:797734 size:768
11:52:04 T:18446744072756540817    INFO: CDVDPlayerAudio::Decode dts:821734 pts:821734 size:782
11:52:04 T:18446744072756541161    INFO: CDVDPlayerAudio::Decode dts:845734 pts:845734 size:768
11:52:04 T:18446744072756541530    INFO: CDVDPlayerAudio::Decode dts:869734 pts:869734 size:768
11:52:04 T:18446744072756542004    INFO: CDVDPlayerAudio::Decode dts:893734 pts:893734 size:768
11:52:04 T:18446744072756542514    INFO: CDVDPlayerAudio::Decode dts:917734 pts:917734 size:768
11:52:04 T:18446744072756542981    INFO: CDVDPlayerAudio::Decode dts:941734 pts:941734 size:782
11:52:04 T:18446744072756543354   ERROR: COMXAudio::Decode timeout
<p dir="auto">Thx in advance,<br />
Marco</p>
]]></description><link>https://forum.magicmirror.builders/post/57041</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57041</guid><dc:creator><![CDATA[Eisblume]]></dc:creator><pubDate>Wed, 15 May 2019 12:01:49 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Mon, 11 Feb 2019 20:46:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> said in <a href="/post/52066">[MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer</a>:</p>
<p dir="auto">In the meantime thank you very much indeed <a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: AxLed">@<bdi>AxLed</bdi></a> for all the support you gave me!</p>
<p dir="auto">You’re welcome, but still a pity it did not work for you.<br />
Good luck with the rest of your build.<br />
Ciao!</p>
]]></description><link>https://forum.magicmirror.builders/post/52138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52138</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Mon, 11 Feb 2019 20:46:30 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Mon, 11 Feb 2019 09:13:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> nope anyway I have to stop looking further into it.</p>
<p dir="auto">Mirror building is taking more than expected, I’ve got everything needed and my other streaming module is now working so honestly speaking I don’t need MMM-Dreambox anymore. :face_with_stuck-out_tongue_winking_eye:</p>
<p dir="auto">Once I am done with the mirror I might come back at trying it.</p>
<p dir="auto">In the meantime thank you very much indeed <a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: AxLed">@<bdi>AxLed</bdi></a> for all the support you gave me! :flexed_biceps_medium-light_skin_tone:</p>
]]></description><link>https://forum.magicmirror.builders/post/52066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52066</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Mon, 11 Feb 2019 09:13:58 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Sat, 09 Feb 2019 18:00:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> said in <a href="/post/51958">[MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer</a>:</p>
<p dir="auto">so I had the time to try everything</p>
<p dir="auto">So, you do not see the <code>Debug MMM-Dreambox:</code> lines in the pm2 log ?</p>
<p dir="auto">I see this:</p>
<pre><code>0|mm  | Starting node helper for: MMM-Dreambox
0|mm  | Debug MMM-Dreambox: omxplayer  --genlog --vol -6000 --win  600,300,960,940 --live http://192.168.178.47:8001/1:0:1:6DCA:44D:1:C00000:0:0:0:
0|mm  | Debug MMM-Dreambox: zapstate:
<p dir="auto">If not, I still believe DB-PLAY is not working for you, hence MMM-Remote-Control.<br />
Did you de-install the other version ? Perhaps they bite each other.<br />
Did not forget the npm install in the MMM-Remote-Control dir ?l</p>
]]></description><link>https://forum.magicmirror.builders/post/51962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51962</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 09 Feb 2019 18:00:05 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Sat, 09 Feb 2019 17:54:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> cheers going to use it tomorrow. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/51961</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51961</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Sat, 09 Feb 2019 17:54:44 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Sat, 09 Feb 2019 17:49:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> said in <a href="/post/51958">[MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer</a>:</p>
<p dir="auto">what if I want to try a different bouquet?</p>
<p dir="auto">Do:</p>
<pre><code>http://192.168.178.47/web/getservices
<p dir="auto">Then use the <code>FROM BOUQUET</code> part to change the apiepgnow and apiServicelistplayable parameters in config.js.<br />
Best is to copy your original lines, comment out your original line.<br />
For example:</p>
<pre><code>// apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.magicmirror__tv_.tv%22%20ORDER%20BY%20bouquet',
<p dir="auto">Change the <code>apibouquet</code> parameter to the offset of your bouquet.<br />
Meaning, if your magicmirror bouquet is the 3rd bouquet, then use <code>apibouquet: 2,</code> (0 being <a href="http://favourites.tv" target="_blank" rel="noopener noreferrer nofollow ugc">favourites.tv</a>).<br />
And of course restart mm.</p>
]]></description><link>https://forum.magicmirror.builders/post/51960</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51960</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 09 Feb 2019 17:49:55 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Sat, 09 Feb 2019 17:35:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: AxLed">@<bdi>AxLed</bdi></a> so I had the time to try everything you and <a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> suggested me.</p>
<p dir="auto">I also ran the module update and installed MMM-Remote-Control by <a class="plugin-mentions-user plugin-mentions-a" href="/user/jopyth" aria-label="Profile: Jopyth">@<bdi>Jopyth</bdi></a> .</p>
<p dir="auto">I still am getting the same ending (no streaming), BUT this time I noticed an error in console log as soon as I ran the remote DB-PLAY command (note that in the MMM-Remote-Control web page I got the ‘success’ message instead)!</p>
<pre><code>MMM-Dreambox.js:292 Uncaught TypeError: Cannot read property '0' of undefined
    at Class.notificationReceived (MMM-Dreambox.js:292)
    at sendNotification (main.js:95)
    at Object.sendNotification (main.js:498)
    at Class.sendNotification (module.js:368)
    at Class.socketNotificationReceived (MMM-Remote-Control.js:130)
    at module.js:246
    at r.&lt;anonymous&gt; (socketclient.js:25)
    at r.emit (index.js:83)
    at r.onevent (index.js:83)
    at r.MMSocket.self.socket.onevent (socketclient.js:19)
notificationReceived @ MMM-Dreambox.js:292
sendNotification @ main.js:95
sendNotification @ main.js:498
sendNotification @ module.js:368
socketNotificationReceived @ MMM-Remote-Control.js:130
(anonymous) @ module.js:246
(anonymous) @ socketclient.js:25
r.emit @ index.js:83
r.onevent @ index.js:83
MMSocket.self.socket.onevent @ socketclient.js:19
r.onpacket @ index.js:83
(anonymous) @ index.js:83
r.ondecoded @ index.js:83
a.add @ index.js:83
r.ondata @ index.js:83
r.onPacket @ index.js:83
r.onData @ index.js:83
ws.onmessage @ index.js:83
<p dir="auto">Listen what if I want to try a different bouquet?<br />
Let’s say I call it ‘MagicMirror’ and put in just 4-5 TV channels where should I look at then to enter its URL path in the module?</p>
]]></description><link>https://forum.magicmirror.builders/post/51958</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51958</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Sat, 09 Feb 2019 17:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Fri, 08 Feb 2019 19:49:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> yeah definitely a possible reason why I was getting no streams considering that I was using shbatm version!</p>
<p dir="auto">Right now I am not at home, but I will surely try (also what <a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: AxLed">@<bdi>AxLed</bdi></a> said) tomorrow. 👍🏼</p>
]]></description><link>https://forum.magicmirror.builders/post/51884</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51884</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Fri, 08 Feb 2019 19:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Fri, 08 Feb 2019 19:27:28 GMT]]></title><description><![CDATA[<p dir="auto">By coincidence there was a new post regarding the new module:<br />
<a href="https://github.com/shbatm/MMM-Remote-Control" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/shbatm/MMM-Remote-Control</a><br />
I do not use this one.<br />
Neither does AxLed, so we can be on to something.</p>
]]></description><link>https://forum.magicmirror.builders/post/51882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51882</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Fri, 08 Feb 2019 19:27:28 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Fri, 08 Feb 2019 19:20:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a><br />
I think this one<br />
<a href="https://github.com/Jopyth/MMM-Remote-Control" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Jopyth/MMM-Remote-Control</a><br />
Cannot find the one from shbatm…</p>
]]></description><link>https://forum.magicmirror.builders/post/51881</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51881</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Fri, 08 Feb 2019 19:20:55 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Fri, 08 Feb 2019 19:15:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> said in <a href="/post/51856">[MMM-Dreambox]</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: Cr4z33">@<bdi>Cr4z33</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a><br />
You were pretty busy in debugging so far, somehow i had a similar idea as evroom.</p>
<p dir="auto">You can do an <code>git pull</code> in your MMM-Dreambox folder for the <code>dev branch</code>, i added some debugging informations.</p>
<pre><code>$ cd /home/pi/MagicMirror/modules/MMM-Dreambox
$ git pull
<p dir="auto">Maybe “zap” or the “zap” Url isnt working.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: Cr4z33">@<bdi>Cr4z33</bdi></a> can you please update and post the logs, the should look like</p>
<pre><code>Debug MMM-Dreambox: omxplayer  --win 320,180,1600,900  -o both http://dm800se.fritz.box:8001/1:0:19:2B5C:41B:1:FFFF014A:0:0:0:
Debug MMM-Dreambox: zapstate:zap
<p dir="auto">or</p>
<pre><code>Debug MMM-Dreambox: omxplayer  --win 320,180,1600,900  -o both http://dm800se.fritz.box:8001/1:0:1:CBB2:2710:F001:FFFF0000:0:0:0:
<p dir="auto">You can also try to reduce the arguments like mine above to <code>--win 320,180,1600,900  -o both</code>.<br />
I use MMM-Remote-Control of Jopyth.</p>
]]></description><link>https://forum.magicmirror.builders/post/51880</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51880</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Fri, 08 Feb 2019 19:15:34 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Fri, 08 Feb 2019 18:56:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> oh wait what version of MMM-Remote-Control are you using? 🤔</p>
<p dir="auto">The original developer (cannot remember the name sorry) one or the new one made by shbatm?</p>
]]></description><link>https://forum.magicmirror.builders/post/51878</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51878</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Fri, 08 Feb 2019 18:56:01 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Fri, 08 Feb 2019 18:09:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: Cr4z33">@<bdi>Cr4z33</bdi></a><br />
That explains the missing stream.<br />
You are not getting to the DB-PLAY routine.</p>
<p dir="auto">To me it looks like you have an issue with MMM-Remote-Control.<br />
For example, I almost always get success, provide the IP is right, but the notification can be wrong</p>
<pre><code>{"status":"success"}
<p dir="auto">Can you try this:</p>
<pre><code>$ cd /home/pi/MagicMirror/modules/MMM-Remote-Control
$ git pull
$ git status
$ npm install
<p dir="auto">And then restart mm and try again.</p>
<p dir="auto">You can also put a debug line in the DB-STOP call and do</p>
<pre><code>http://&lt; MM_IP &gt;:8080/remote?action=NOTIFICATION&amp;notification=DB-STOP
<pre><code>$ vi node_helper.js
                if (notification === "DB-STOP") {
console.log('DB-STOP: stop the stream');
                        exec('pkill omxplayer', null);
<p dir="auto">If you do not see this in the pm2 logs, then MMM-Remote-Control seems to be the culprit or the communication between the 2 modules.<br />
But as it works for both AxLed and me …</p>
]]></description><link>https://forum.magicmirror.builders/post/51876</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51876</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Fri, 08 Feb 2019 18:09:11 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer on Sat, 09 Feb 2019 17:21:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> said in <a href="/post/51856">[MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer</a>:</p>
<p dir="auto">In my case I see DB-PLAY(2).</p>
<p dir="auto">If you see nothing then it is back to the drawing board.<br />
Need to see what works and what not and where in the code.</p>
<p dir="auto">Nothing reported into PM2 logs. :persevering_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/51873</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51873</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Sat, 09 Feb 2019 17:21:45 GMT</pubDate></item></channel></rss>
