<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[manual Installation on Raspberry Zero - uninterpretable Error..]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">does anybody can “translate” this Error Message when i start MM² with npm start</p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
2 info using npm@6.4.1
3 info using node@v10.15.0
5 info lifecycle magicmirror@2.5.0~prestart: magicmirror@2.5.0
6 info lifecycle magicmirror@2.5.0~start: magicmirror@2.5.0
7 verbose lifecycle magicmirror@2.5.0~start: unsafe-perm in lifecycle true
8 verbose lifecycle magicmirror@2.5.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
9 verbose lifecycle magicmirror@2.5.0~start: CWD: /home/pi/MagicMirror
10 silly lifecycle magicmirror@2.5.0~start: Args: [ '-c', 'sh run-start.sh' ]
11 info lifecycle magicmirror@2.5.0~start: Failed to exec start script
12 verbose stack Error: magicmirror@2.5.0 start: `sh run-start.sh`
12 verbose stack spawn ENOENT
12 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
12 verbose stack     at ChildProcess.emit (events.js:182:13)
12 verbose stack     at maybeClose (internal/child_process.js:962:16)
12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
13 verbose pkgid magicmirror@2.5.0
14 verbose cwd /home/pi/MagicMirror
15 verbose Linux 4.14.90+
16 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
17 verbose node v10.15.0
18 verbose npm  v6.4.1
19 error file sh
20 error code ELIFECYCLE
21 error errno ENOENT
22 error syscall spawn
23 error magicmirror@2.5.0 start: `sh run-start.sh`
23 error spawn ENOENT
24 error Failed at the magicmirror@2.5.0 start script.
24 error This is probably not a problem with npm. There is likely additional logging output above.
25 verbose exit [ 1, true ]
<p dir="auto">thank you…</p>
]]></description><link>https://forum.magicmirror.builders/topic/9349/manual-installation-on-raspberry-zero-uninterpretable-error</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 01:13:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9349.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 29 Dec 2018 14:14:23 GMT</pubDate><ttl>60</ttl></channel></rss>
