<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SleepWake not working]]></title><description><![CDATA[<p dir="auto">Well I’ve got the the module installed, and it puts the display to sleep but doesn’t wake the mirror up via motion I have the PS3eye!  This is how I have my config file for the module, what have I not done?</p>
<pre><code>{
                        module: 'MMM-SleepWake',
                        delay:  15,
                        source: 'external',
                        mode:  'PI',
]]></description><link>https://forum.magicmirror.builders/topic/9374/mmm-sleepwake-not-working</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 17:33:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9374.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Jan 2019 10:10:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SleepWake not working on Sat, 05 Jan 2019 15:37:55 GMT]]></title><description><![CDATA[<p dir="auto">thnx,its just too much reading for me at this time of year,i just need to on/off my display when motion detect.I ll skip that feature for now :)</p>
]]></description><link>https://forum.magicmirror.builders/post/49425</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49425</guid><dc:creator><![CDATA[costascontis]]></dc:creator><pubDate>Sat, 05 Jan 2019 15:37:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Sat, 05 Jan 2019 15:07:06 GMT]]></title><description><![CDATA[<p dir="auto">My readme provides the config info needed to get motion detection reported to my module</p>
]]></description><link>https://forum.magicmirror.builders/post/49423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49423</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 05 Jan 2019 15:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Sat, 05 Jan 2019 15:05:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/costascontis" aria-label="Profile: costascontis">@<bdi>costascontis</bdi></a> I do not supply it. There are lots of config options.</p>
<p dir="auto">See <a href="https://motion-project.github.io/motion_guide.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://motion-project.github.io/motion_guide.html</a></p>
]]></description><link>https://forum.magicmirror.builders/post/49422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49422</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 05 Jan 2019 15:05:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Sat, 05 Jan 2019 15:03:37 GMT]]></title><description><![CDATA[<p dir="auto">is there an install tutorial for motion so i can use it with this module?</p>
]]></description><link>https://forum.magicmirror.builders/post/49421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49421</guid><dc:creator><![CDATA[costascontis]]></dc:creator><pubDate>Sat, 05 Jan 2019 15:03:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Wed, 02 Jan 2019 15:21:13 GMT]]></title><description><![CDATA[<p dir="auto">note that the default motion delay from start to end of motion is 60 seconds… WAY too long, I have mine set at 20 seconds.</p>
]]></description><link>https://forum.magicmirror.builders/post/49118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49118</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Jan 2019 15:21:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Wed, 02 Jan 2019 15:19:57 GMT]]></title><description><![CDATA[<p dir="auto">thanks… fixed</p>
]]></description><link>https://forum.magicmirror.builders/post/49117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49117</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Jan 2019 15:19:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Wed, 02 Jan 2019 15:18:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hi just to let you know the read me is missing the : by config. i really hope i can get this working as it could sort alot of my screen on problems</p>
]]></description><link>https://forum.magicmirror.builders/post/49116</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49116</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Wed, 02 Jan 2019 15:18:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Wed, 02 Jan 2019 03:23:23 GMT]]></title><description><![CDATA[<p dir="auto">When I started working on my mirror project a few years ago, I had all I could do to learn node, angular, JavaScript, a no SQL database, and a ton of other stuff. I was using a pi, but didn’t have a PIR sensor, only a webcam.and the mirror was voice based, so i needed a mic</p>
<p dir="auto">I found motion. And since have changed hardware, running on an odroid single board computer to get network and image display  speed up.<br />
Motion works on lots of platforms.</p>
]]></description><link>https://forum.magicmirror.builders/post/49017</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49017</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Jan 2019 03:23:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Tue, 01 Jan 2019 18:19:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> no. Motion is not related to MM. It can do all sorts of things. Record video, take snapshots, and a lot more. Supports just about every camera.</p>
<p dir="auto">And has exits which can be used to inform others of motion, video files, …</p>
<p dir="auto">So, follow it’s install instructions. Then edit /etc/motion/motion.conf, and update the lines I documented in the readme.  This will call the script I provided to inform my module of motion(start and end)</p>
<p dir="auto">U also customize the motion app on sensitivity, delay, etc etc. All things I have seen people ask about.</p>
]]></description><link>https://forum.magicmirror.builders/post/49014</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49014</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Jan 2019 18:19:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Tue, 01 Jan 2019 18:13:34 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, Do I just install it like a module? Ie in the magic mirror module location</p>
]]></description><link>https://forum.magicmirror.builders/post/49013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49013</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 01 Jan 2019 18:13:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Tue, 01 Jan 2019 14:44:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> u need to install the github motion project, and change its config to execute the sample script i provide. see the readme. my project does not detect the motion itself (some others read the camera data and determine motion), but uses an external  (to MagicMirror) source</p>
]]></description><link>https://forum.magicmirror.builders/post/49008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49008</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Jan 2019 14:44:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Tue, 01 Jan 2019 14:06:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> is there a script that I have to run to make this work?</p>
]]></description><link>https://forum.magicmirror.builders/post/49005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49005</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 01 Jan 2019 14:06:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Tue, 01 Jan 2019 13:31:57 GMT]]></title><description><![CDATA[<p dir="auto">thanks. updated the readme</p>
]]></description><link>https://forum.magicmirror.builders/post/49003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49003</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Jan 2019 13:31:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Tue, 01 Jan 2019 11:45:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> thanks just got to wait till it sleeps now to test it and then find out where I’m going to install it lol</p>
]]></description><link>https://forum.magicmirror.builders/post/49000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49000</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 01 Jan 2019 11:45:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SleepWake not working on Tue, 01 Jan 2019 10:30:18 GMT]]></title><description><![CDATA[<p dir="auto">The readme is wrong.</p>
<pre><code>{
config:
   delay:  15,
   source: 'external',
   mode:  'pi'
]]></description><link>https://forum.magicmirror.builders/post/48995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48995</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 01 Jan 2019 10:30:18 GMT</pubDate></item></channel></rss>
