<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mirror supplier in Ireland]]></title><description><![CDATA[<p dir="auto">Does anyone know of a supplier for a two way mirror (acrylic) in Ireland? If not the uk would be my last option.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/941/mirror-supplier-in-ireland</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 07:47:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/941.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Nov 2016 18:38:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mirror supplier in Ireland on Wed, 14 Mar 2018 13:12:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ceddirr" aria-label="Profile: ceddirr">@<bdi>ceddirr</bdi></a> Yes. Packaging was great. Was a good while ago now since I ordered it though.</p>
<p dir="auto">I’d be careful if you want to cut it though. Make sure you order the right sizes.</p>
]]></description><link>https://forum.magicmirror.builders/post/37013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37013</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Wed, 14 Mar 2018 13:12:50 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror supplier in Ireland on Wed, 14 Mar 2018 12:48:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcsorley" aria-label="Profile: McSorley">@<bdi>McSorley</bdi></a> Hi there,<br />
Quick question about the supplier in the UK: the mirror is 3mm, which is quite thin, did it arrive in a good shape?<br />
thank you in advance<br />
Cedric</p>
]]></description><link>https://forum.magicmirror.builders/post/37009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37009</guid><dc:creator><![CDATA[ceddirr]]></dc:creator><pubDate>Wed, 14 Mar 2018 12:48:29 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror supplier in Ireland on Wed, 31 May 2017 21:51:42 GMT]]></title><description><![CDATA[<p dir="auto">I went with the supplier I linked. Worked a treat.</p>
]]></description><link>https://forum.magicmirror.builders/post/22237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22237</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Wed, 31 May 2017 21:51:42 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror supplier in Ireland on Tue, 30 May 2017 10:48:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ceddirr" aria-label="Profile: ceddirr">@<bdi>ceddirr</bdi></a></p>
<p dir="auto">No problem, its called a “two way mirror” … You need to call them for a quote, they don’t have them online… They also refer to them as “spy mirrors”…</p>
<p dir="auto">Best of luck with the project.</p>
]]></description><link>https://forum.magicmirror.builders/post/22164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22164</guid><dc:creator><![CDATA[Gazzamc]]></dc:creator><pubDate>Tue, 30 May 2017 10:48:33 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror supplier in Ireland on Tue, 30 May 2017 10:16:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gazzamc" aria-label="Profile: Gazzamc">@<bdi>Gazzamc</bdi></a><br />
Thank you very much for your help, please could you tell me the type keyword I should research to have a mirror which can work with this project?</p>
<p dir="auto">Because I think most of those mirrors are reals mirrors so won’t work with a screen behind?</p>
<p dir="auto">Thank you again!</p>
]]></description><link>https://forum.magicmirror.builders/post/22161</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22161</guid><dc:creator><![CDATA[ceddirr]]></dc:creator><pubDate>Tue, 30 May 2017 10:16:44 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror supplier in Ireland on Mon, 29 May 2017 15:15:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ceddirr" aria-label="Profile: ceddirr">@<bdi>ceddirr</bdi></a><br />
I actually went with glass so I found a source locally, for much cheaper too. If you’re interested it’s <a href="http://mirrorzone.ie" target="_blank" rel="noopener noreferrer nofollow ugc">Mirror Zone</a>… Its based in Tipperary.<br />
I got a relatively big piece (to cover a 32") for 150 with delivery to my door. It works really well in the mirror atm.</p>
<p dir="auto">Hopefully that helps you.</p>
]]></description><link>https://forum.magicmirror.builders/post/22141</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22141</guid><dc:creator><![CDATA[Gazzamc]]></dc:creator><pubDate>Mon, 29 May 2017 15:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror supplier in Ireland on Mon, 29 May 2017 14:50:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gazzamc" aria-label="Profile: Gazzamc">@<bdi>Gazzamc</bdi></a><br />
Hi,<br />
I am currently living in Ireland, so I am interested in this link. Did you finally get your order?</p>
]]></description><link>https://forum.magicmirror.builders/post/22140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22140</guid><dc:creator><![CDATA[ceddirr]]></dc:creator><pubDate>Mon, 29 May 2017 14:50:47 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror supplier in Ireland on Tue, 08 Nov 2016 19:29:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcsorley" aria-label="Profile: McSorley">@<bdi>McSorley</bdi></a> said in <a href="/post/7650">Mirror supplier in Ireland</a>:</p>
<p dir="auto">I used this in the UK.</p>
<p dir="auto"><a href="http://www.cutplasticsheeting.co.uk/mirrored-sheeting/two-way-acrylic-mirror" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.cutplasticsheeting.co.uk/mirrored-sheeting/two-way-acrylic-mirror</a></p>
<p dir="auto">I would recommend making sure you have the right size as it isn’t easy to cut yourself.</p>
<p dir="auto">Thank you for the reply, I’ve calculated my dimensions and it seems reasonable enough, only thing is I’m not sure if they ship to Ireland (I’ve shot them an email anyway).</p>
<p dir="auto">Now in the chance they do, how did yours turn out with it?</p>
]]></description><link>https://forum.magicmirror.builders/post/7671</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7671</guid><dc:creator><![CDATA[Gazzamc]]></dc:creator><pubDate>Tue, 08 Nov 2016 19:29:16 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror supplier in Ireland on Mon, 07 Nov 2016 22:51:16 GMT]]></title><description><![CDATA[<p dir="auto">I used this in the UK.</p>
]]></description><link>https://forum.magicmirror.builders/post/7650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7650</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Mon, 07 Nov 2016 22:51:16 GMT</pubDate></item></channel></rss>
