<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM podcast stops working since YQL service was turned off]]></title><description><![CDATA[<p dir="auto">MMM podcast module stops working.<br />
Since this module works with YQL service and this was turned off.<br />
As of Thursday, Jan. 3, 2019, the YQL service at <a href="http://query.yahooapis.com" target="_blank" rel="noopener noreferrer nofollow ugc">query.yahooapis.com</a> will be retired.</p>
<p dir="auto">Is there a possibility that it is otherwise solved.<br />
Or an alternative!<br />
I need podcast for Tagesschau 100sek.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9428/mmm-podcast-stops-working-since-yql-service-was-turned-off</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 04:30:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9428.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Jan 2019 22:23:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM podcast stops working since YQL service was turned off on Tue, 08 Jan 2019 22:11:19 GMT]]></title><description><![CDATA[<p dir="auto">Wohoo Great!<br />
I will try it tomorrow.<br />
Many Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/49733</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49733</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Tue, 08 Jan 2019 22:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM podcast stops working since YQL service was turned off on Tue, 08 Jan 2019 19:28:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">i was annoyed to, that MMM-Podcast stops working, so i made a “quick &amp; dirty” replacement.</p>
<p dir="auto">[card:Ax-LED/MMM-Podcast2]</p>
<p dir="auto"><strong>Difference to MMM-Podcast:</strong></p>
<ul>
<li>no need to download the videofile first</li>
<li>no need of the yahoo YQL service</li>
</ul>
<p dir="auto"><strong>Goodies:</strong></p>
<ul>
<li>i used the same notification <code>BUTTON_PRESSED</code> to use the module, so not much changes in your config.js neccessary</li>
<li>no node dependencies, so <strong>no</strong> <code>npm install</code> is required</li>
</ul>
<p dir="auto"><strong>Note:</strong></p>
<ul>
<li>quick &amp; dirty, need some improvement as i have time</li>
</ul>
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/post/49715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49715</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Tue, 08 Jan 2019 19:28:07 GMT</pubDate></item></channel></rss>
