<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The Italian "dual" Job [Build]]]></title><description><![CDATA[<p dir="auto">Hi to all,<br />
this is my first try, i’m building a dual system magicmirror with garbage things :D.</p>
<p dir="auto">First of all bought an old paint with size that fit my trash monitors:<br />
<img src="https://i.ibb.co/kcjWYzt/7-C45-A852-ED71-4134-A884-3555-AE54-D2-C6.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">disassembled:<br />
<img src="https://i.ibb.co/M6mCfHR/E3-FE7-A5-D-90-A9-48-E8-B70-F-5-D08-F52-BE77-B.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">so a build an electronics frame:<br />
<img src="https://i.ibb.co/BjCYh88/3-C8-DD653-5-CEA-4-B4-D-AF04-63-F4-B4012873.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">And:<br />
<img src="https://i.ibb.co/kGsMfZY/91-DFC577-35-B1-4-ED1-A62-B-9-C62-D2-F5-E6-C5.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Build a bracket for the little amazon echo:<br />
<img src="https://i.ibb.co/XYqB7Vw/E34738-FB-E456-476-E-9651-990-CA6722130.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">So i’ve applied a mirror skin to my old glass (good enough to see how it works)<br />
Sorry no photos about that, i was in work DIY frenzy :)</p>
<p dir="auto">Now it’s time to the first run:<br />
<img src="https://i.ibb.co/s6qwSyY/181507-CF-4-B5-F-46-E3-9667-22-F3-C8-BE0-A42.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">and right side:<br />
<img src="https://i.ibb.co/Jc4WR2p/71-E082-DE-B481-414-F-9-D7-D-725877889475.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Still TO DO:</p>
<ul>
<li>paint frame in white</li>
<li>apply sonoff to the monitors (i will control via Alexa behind the mirror)</li>
<li>buy a real two way mirror (anyone know where in Bologna, IT)</li>
</ul>
<p dir="auto">for any advice, i’m here and glad to know<br />
Bye!!!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9429/the-italian-dual-job-build</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 14:00:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9429.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Jan 2019 13:45:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Sun, 22 Mar 2020 16:13:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ttarzan" aria-label="Profile: ttarzan">@<bdi>ttarzan</bdi></a> the echo is double side taped to the mirror; he can hear me perfectly.<br />
:-)</p>
]]></description><link>https://forum.magicmirror.builders/post/70962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70962</guid><dc:creator><![CDATA[N3fasto]]></dc:creator><pubDate>Sun, 22 Mar 2020 16:13:48 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Fri, 20 Mar 2020 08:06:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n3fasto" aria-label="Profile: N3fasto">@<bdi>N3fasto</bdi></a> You built the Echo Dot right behind the glass? How well does it “hear”? I tried an Echo Input (the small one without its own speaker). It works, but I have to get very close to the mirror so he can hear me.</p>
]]></description><link>https://forum.magicmirror.builders/post/70839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70839</guid><dc:creator><![CDATA[ttarzan]]></dc:creator><pubDate>Fri, 20 Mar 2020 08:06:14 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Thu, 19 Mar 2020 18:00:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> thanks my friend; it was a long ride</p>
]]></description><link>https://forum.magicmirror.builders/post/70800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70800</guid><dc:creator><![CDATA[N3fasto]]></dc:creator><pubDate>Thu, 19 Mar 2020 18:00:44 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Wed, 18 Mar 2020 13:29:23 GMT]]></title><description><![CDATA[<p dir="auto">That looks really sharp! Great work.</p>
]]></description><link>https://forum.magicmirror.builders/post/70734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70734</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 18 Mar 2020 13:29:23 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Wed, 18 Mar 2020 10:48:32 GMT]]></title><description><![CDATA[<p dir="auto">hi to all, i’m really sorry about the delay.<br />
Beacuse family matters the project is ended few months ago…so this is the final result:<br />
<img src="https://i.ibb.co/TLdhjHq/smartmirror.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">as you can see there is a new led strip behind the frame, smart controlled by alexa as the monitors.<br />
You asked how dual monitor with a single raspberry, the answer is that i don’t know :D i’m using a dual raspberry setup :)</p>
<p dir="auto">please let me know what you think about the result!<br />
Ciao!!</p>
]]></description><link>https://forum.magicmirror.builders/post/70731</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70731</guid><dc:creator><![CDATA[N3fasto]]></dc:creator><pubDate>Wed, 18 Mar 2020 10:48:32 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Thu, 21 Feb 2019 11:16:33 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone.<br />
After reading this thread i’ve googled how to set up multiple screens on my device. i use a ORANGE PI PC, so there could be some differences than raspberry.<br />
I <strong>haven’t</strong> tested it, but i share here the <a href="http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&amp;tid=40&amp;page=1" target="_blank" rel="noopener noreferrer nofollow ugc">thread i’ve found</a>.<br />
Maybe more skilled users could find it useful.</p>
<p dir="auto">[I am Italian too]</p>
]]></description><link>https://forum.magicmirror.builders/post/52909</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52909</guid><dc:creator><![CDATA[fermamitiprego]]></dc:creator><pubDate>Thu, 21 Feb 2019 11:16:33 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Sun, 27 Jan 2019 18:00:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cupola" aria-label="Profile: cupola">@<bdi>cupola</bdi></a> i’m writing on Italian cuz (maybe not) I hope that the guy that makes the mirror is Italian. But ok… from now I’ll talk in English! Thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/50931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50931</guid><dc:creator><![CDATA[BDK]]></dc:creator><pubDate>Sun, 27 Jan 2019 18:00:45 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Sun, 27 Jan 2019 17:28:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cupola" aria-label="Profile: cupola">@<bdi>cupola</bdi></a><br />
Maybe he hopes to became a answer.</p>
<p dir="auto">I have asked this guy <a class="plugin-mentions-user plugin-mentions-a" href="/user/n3fasto" aria-label="Profile: N3fasto">@<bdi>N3fasto</bdi></a> aprox. 3 weeks ago to explain me his configuration.</p>
<p dir="auto">No aswer!</p>
]]></description><link>https://forum.magicmirror.builders/post/50927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50927</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Sun, 27 Jan 2019 17:28:55 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Sun, 27 Jan 2019 11:13:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achillealb" aria-label="Profile: achillealb">@<bdi>achillealb</bdi></a> this is an international forum… Why do you use italian?!?<br />
He used two raspberry probably</p>
]]></description><link>https://forum.magicmirror.builders/post/50897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50897</guid><dc:creator><![CDATA[Cupola]]></dc:creator><pubDate>Sun, 27 Jan 2019 11:13:21 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Wed, 23 Jan 2019 08:52:05 GMT]]></title><description><![CDATA[<p dir="auto">Come hai fatto per collegare due monitor al raspberry</p>
]]></description><link>https://forum.magicmirror.builders/post/50642</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50642</guid><dc:creator><![CDATA[achillealb]]></dc:creator><pubDate>Wed, 23 Jan 2019 08:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Mon, 14 Jan 2019 11:25:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdk" aria-label="Profile: bdk">@<bdi>bdk</bdi></a> said in <a href="/post/49898">The Italian "dual" Job [Build]</a>:</p>
<p dir="auto">Bel lavoro!!!</p>
<p dir="auto">ciao, sai che non riesco a trovare la pellicola? (milano)<br />
ho girato Bricoio, leroy merlin ma nulla…</p>
<p dir="auto">grazie mille!!!</p>
<p dir="auto">bricoman<br />
<a href="https://www.bricoman.it/search/?q=pellicola+specchio" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.bricoman.it/search/?q=pellicola+specchio</a></p>
]]></description><link>https://forum.magicmirror.builders/post/50126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50126</guid><dc:creator><![CDATA[achillealb]]></dc:creator><pubDate>Mon, 14 Jan 2019 11:25:04 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Sun, 13 Jan 2019 21:37:16 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.martuzzi2.com/" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.martuzzi2.com/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/50090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50090</guid><dc:creator><![CDATA[achillealb]]></dc:creator><pubDate>Sun, 13 Jan 2019 21:37:16 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Sun, 13 Jan 2019 17:25:22 GMT]]></title><description><![CDATA[<p dir="auto">Hello, please tell us how you use two monitors with one Raspberry</p>
<p dir="auto">Thank you and great job.</p>
]]></description><link>https://forum.magicmirror.builders/post/50064</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50064</guid><dc:creator><![CDATA[tadeus1975]]></dc:creator><pubDate>Sun, 13 Jan 2019 17:25:22 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Sun, 13 Jan 2019 16:24:31 GMT]]></title><description><![CDATA[<p dir="auto">Very nice build!!! i didn’t know you could add a second screen to the pi!!! How did you do it??</p>
]]></description><link>https://forum.magicmirror.builders/post/50060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50060</guid><dc:creator><![CDATA[gh057]]></dc:creator><pubDate>Sun, 13 Jan 2019 16:24:31 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Thu, 10 Jan 2019 13:27:53 GMT]]></title><description><![CDATA[<p dir="auto">Bel lavoro!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/49898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49898</guid><dc:creator><![CDATA[BDK]]></dc:creator><pubDate>Thu, 10 Jan 2019 13:27:53 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Wed, 09 Jan 2019 11:39:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyberphox" aria-label="Profile: cyberphox">@<bdi>cyberphox</bdi></a> said in <a href="/post/49657">The Italian "dual" Job [Build]</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> said in <a href="/post/49628">The Italian "dual" Job [Build]</a>:</p>
<p dir="auto">Why did you prefer to use a REAL Amazon device instead of <a href="https://www.npmjs.com/package/MMM-alexa" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Alexa</a>? :confused_face:</p>
<p dir="auto">I remember all the grief i had trying to get that module working…and then stay working…i would’ve paid the small amount for the spot and be done with it too! LOL</p>
<p dir="auto">OMG… You just brought back all the Nightmares there :-(  So much wasted weeks and weeks for nothing, and all the stress :-D .</p>
]]></description><link>https://forum.magicmirror.builders/post/49797</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49797</guid><dc:creator><![CDATA[johnnyboy]]></dc:creator><pubDate>Wed, 09 Jan 2019 11:39:09 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Wed, 09 Jan 2019 01:09:14 GMT]]></title><description><![CDATA[<p dir="auto">That sir…is beautiful!  Need a video!  I really want to see this thing work.</p>
]]></description><link>https://forum.magicmirror.builders/post/49745</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49745</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 09 Jan 2019 01:09:14 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Wed, 09 Jan 2019 00:58:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi, one thing i want to konw.</p>
<p dir="auto">You use one raspberry pi for both screens?</p>
<p dir="auto">If yes, how do you setup the pi?</p>
]]></description><link>https://forum.magicmirror.builders/post/49743</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49743</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Wed, 09 Jan 2019 00:58:09 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Tue, 08 Jan 2019 01:37:37 GMT]]></title><description><![CDATA[<p dir="auto">This is the release candidate result :-)</p>
<p dir="auto"><img src="https://i.ibb.co/WxjJTXb/19828-EFE-66-F0-4-CAC-BA89-46-BF328139-E5.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Both monitors are connected with a single sonhoff and Alexa can Power On and Off the “mirror”<br />
:-)</p>
]]></description><link>https://forum.magicmirror.builders/post/49663</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49663</guid><dc:creator><![CDATA[N3fasto]]></dc:creator><pubDate>Tue, 08 Jan 2019 01:37:37 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Tue, 08 Jan 2019 01:35:10 GMT]]></title><description><![CDATA[<p dir="auto">A very clever layout. Nice.</p>
]]></description><link>https://forum.magicmirror.builders/post/49662</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49662</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 08 Jan 2019 01:35:10 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Mon, 07 Jan 2019 20:53:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> said in <a href="/post/49628">The Italian "dual" Job [Build]</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/49657</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49657</guid><dc:creator><![CDATA[cyberphox]]></dc:creator><pubDate>Mon, 07 Jan 2019 20:53:32 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Mon, 07 Jan 2019 17:19:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n3fasto" aria-label="Profile: n3fasto">@<bdi>n3fasto</bdi></a> OK…</p>
]]></description><link>https://forum.magicmirror.builders/post/49636</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49636</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Mon, 07 Jan 2019 17:19:30 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Mon, 07 Jan 2019 17:17:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> because of the blu round light when it wake up and because it was on my storage without any utility from a looong time :)</p>
]]></description><link>https://forum.magicmirror.builders/post/49635</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49635</guid><dc:creator><![CDATA[N3fasto]]></dc:creator><pubDate>Mon, 07 Jan 2019 17:17:32 GMT</pubDate></item><item><title><![CDATA[Reply to The Italian "dual" Job [Build] on Mon, 07 Jan 2019 16:44:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/n3fasto" aria-label="Profile: n3fasto">@<bdi>n3fasto</bdi></a> contact Pilkington Italia/Saint-Gobain Italia to know a dealer near to you.</p>
]]></description><link>https://forum.magicmirror.builders/post/49628</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49628</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Mon, 07 Jan 2019 16:44:51 GMT</pubDate></item></channel></rss>
