<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Office365 Calendar load error]]></title><description><![CDATA[<p dir="auto">I’m trying to configure MagicMirror and everything is working pretty well except I can’t get my Office365 calendar do load.  I can confirm that the ICS is accessible and the link works with other similar solutions like Dakboard, but it’s not working with MagicMirror.  Below is the response I get.  I can get the default Holiday calendar working without any issue.  Also, I’ve modified the link below slightly so my calendar isn’t broadcast to the world so the ICS link will most likely not work if you try and download it, but the actual link I’m using does work and downloads a functional ics file.</p>
<hr />
<h2>Starting MagicMirror: v2.6.0<br />
Loading config …<br />
Loading module helpers …<br />
No helper found for module: alert.<br />
Initializing new module helper …<br />
Module helper loaded: updatenotification<br />
No helper found for module: clock.<br />
Module helper loaded: calendar<br />
Module helper loaded: newsfeed<br />
Module helper loaded: MMM-Wallpaper<br />
Module helper loaded: MMM-3Day-Forecast<br />
All module helpers loaded.<br />
Starting server on port 8080 …<br />
Server started …<br />
Connecting socket for: updatenotification<br />
Connecting socket for: calendar<br />
Starting node helper for: calendar<br />
Connecting socket for: newsfeed<br />
Starting module: newsfeed<br />
Connecting socket for: MMM-Wallpaper<br />
Starting node helper for: MMM-Wallpaper<br />
Connecting socket for: MMM-3Day-Forecast<br />
MMM-3Day-Forecast helper, started…<br />
Sockets connected &amp; modules started …<br />
Launching application.<br />
Create new calendar fetcher for url: <a href="https://outlook.office365.com/owa/calendar/b518cb52b20249fda5231010ae758fd2@shop.com/fd2ad49bc3094612b60b2aad2874b0cc16806628755154814078/calendar.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://outlook.office365.com/owa/calendar/b518cb52b20249fda5231010ae758fd2@shop.com/fd2ad49bc3094612b60b2aad2874b0cc16806628755154814078/calendar.ics</a> - Interval: 300000<br />
Create new news fetcher for url: <a href="http://feeds.feedburner.com/TechCrunch/" target="_blank" rel="noopener noreferrer nofollow ugc">http://feeds.feedburner.com/TechCrunch/</a> - Interval: 300000<br />
Whoops! There was an uncaught exception…<br />
TypeError: curr.exdates[i].toISOString is not a function<br />
at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:44:44)<br />
at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:267:41)<br />
at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:308:20)<br />
at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:24)<br />
at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)<br />
at emitTwo (events.js:126:13)<br />
at Request.emit (events.js:214:7)<br />
at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1157:10)<br />
at emitOne (events.js:116:13)<br />
at Request.emit (events.js:211:7)<br />
MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a></h2>
]]></description><link>https://forum.magicmirror.builders/topic/9445/office365-calendar-load-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 07:36:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9445.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Jan 2019 16:37:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Office365 Calendar load error on Wed, 09 Jan 2019 16:13:31 GMT]]></title><description><![CDATA[<p dir="auto">Glad to help, have a nice day</p>
]]></description><link>https://forum.magicmirror.builders/post/49826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49826</guid><dc:creator><![CDATA[Nilnik]]></dc:creator><pubDate>Wed, 09 Jan 2019 16:13:31 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar load error on Wed, 09 Jan 2019 16:07:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for that reference.  That worked.  Basically use Microsoft Flow to sync your O365 calendar to a Google Calendar and then tie the Google Calendar into MM.  It would be great if at some point in the future we could find a way to sort out the date format issue so the ICS link direct from O365 could work.</p>
<p dir="auto">Thanks again for the response and the tutorial!</p>
]]></description><link>https://forum.magicmirror.builders/post/49823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49823</guid><dc:creator><![CDATA[fennemaj]]></dc:creator><pubDate>Wed, 09 Jan 2019 16:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar load error on Tue, 08 Jan 2019 19:17:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello, look at this link: <a href="https://github.com/MichMich/MagicMirror/wiki/Apple-Google-MicroSoft-Calendar-Support" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Apple-Google-MicroSoft-Calendar-Support</a></p>
]]></description><link>https://forum.magicmirror.builders/post/49714</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49714</guid><dc:creator><![CDATA[Nilnik]]></dc:creator><pubDate>Tue, 08 Jan 2019 19:17:45 GMT</pubDate></item></channel></rss>
