<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror is hanging over night]]></title><description><![CDATA[<p dir="auto">Hello everybody</p>
<p dir="auto">I have the following problem. My two MagicMirrors (RPi2 &amp; RPi3) work smoothly throughout the day. However, the MagicMirror V 2.6.0 hangs up overnight. The Pi is still running every morning and with <em>pm2 restart MagicMirror</em> can i  restart the MagicMirror. Memory and CPU are not overloaded. Somebody can help me with this problem?<br />
The following modules are installed:</p>
<p dir="auto">MMM-bernwordclock<br />
MMM-Carousel<br />
MMM-Cursor<br />
MMM-GoogleMapsTraffic<br />
MMM-page-indicator<br />
MMM-pages<br />
MMM-Remote-Control<br />
MMM-SimpleLogo<br />
MMM-SwissCommute<br />
MMM-SwissStationboard<br />
MMM-SystemStats<br />
MMM-WatchDog</p>
]]></description><link>https://forum.magicmirror.builders/topic/9459/magicmirror-is-hanging-over-night</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 06:22:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9459.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Jan 2019 07:06:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror is hanging over night on Mon, 14 Jan 2019 10:00:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skorpionbird" aria-label="Profile: skorpionbird">@<bdi>skorpionbird</bdi></a> after about 12hours memory says it’s only got 2/3 percent left so I suspect it to be a memory leak issue with module as when MM first starts it says I have 32-38 percent ram free</p>
]]></description><link>https://forum.magicmirror.builders/post/50123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50123</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Mon, 14 Jan 2019 10:00:30 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror is hanging over night on Mon, 14 Jan 2019 08:43:37 GMT]]></title><description><![CDATA[<p dir="auto">i use also the GoogleMapsTrafficModule…</p>
]]></description><link>https://forum.magicmirror.builders/post/50121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50121</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Mon, 14 Jan 2019 08:43:37 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror is hanging over night on Sun, 13 Jan 2019 15:11:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi I’ve had/have the same problem with MMM-GoogleMapTraffic module I think it uses too much ram, I’ve got a cron to run every 12hrs to get round it</p>
]]></description><link>https://forum.magicmirror.builders/post/50055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50055</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Sun, 13 Jan 2019 15:11:14 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror is hanging over night on Sun, 13 Jan 2019 14:37:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pakmann" aria-label="Profile: pakmann">@<bdi>pakmann</bdi></a> Thank you for testing and sharing your results. I already had the suspicion that it was the  MMM-GoogleMapsTraffic module as it was used by a lot of users that faced the very same problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/50051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50051</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Sun, 13 Jan 2019 14:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror is hanging over night on Sun, 13 Jan 2019 14:23:39 GMT]]></title><description><![CDATA[<p dir="auto">I had the same Problem. I disabled all Modules and Test which one make the problems. It was the Google Maps Traffic Module.</p>
]]></description><link>https://forum.magicmirror.builders/post/50049</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50049</guid><dc:creator><![CDATA[Pakmann]]></dc:creator><pubDate>Sun, 13 Jan 2019 14:23:39 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror is hanging over night on Thu, 10 Jan 2019 09:46:36 GMT]]></title><description><![CDATA[<p dir="auto">Edit:</p>
<p dir="auto">I found a solution for me. I have generated a daily task with crontab (<a href="https://www.raspberrypi.org/documentation/linux/usage/cron.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/linux/usage/cron.md</a>), which restarts the MagicMirror with <em>pm2 restart <a href="http://MagicMirror.sh" target="_blank" rel="noopener noreferrer nofollow ugc">MagicMirror.sh</a></em> every morning at 5 o’clock.</p>
<p dir="auto">open crontab with <em>crontab -e</em> add   0 5 * * * <em>pm2 restart <a href="http://MagicMirror.sh" target="_blank" rel="noopener noreferrer nofollow ugc">MagicMirror.sh</a></em>  to the end off the file.</p>
]]></description><link>https://forum.magicmirror.builders/post/49890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49890</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Thu, 10 Jan 2019 09:46:36 GMT</pubDate></item></channel></rss>
