<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[3rd party Modules won&#x27;t show up - (expect standard ones)]]></title><description><![CDATA[<p dir="auto">Hi there,<br />
Build my mirror time ago, rebooted it lately, all standard modules are working fine but i can’t add any 3rd part modules…for instance MMM-globe from <a class="plugin-mentions-user plugin-mentions-a" href="/user/lukecodewalker" aria-label="Profile: LukeCodewalker">@<bdi>LukeCodewalker</bdi></a> …  they just won’t show up, don’t know why :( config file is ok (i assume) as the standard modules are showing up.<br />
css custom file was modified to only stretch the content to the edges of the screen as below:</p>
<p dir="auto">body {<br />
margin: 0px;<br />
height: 100%;<br />
width: 100%;</p>
<p dir="auto">}</p>
<p dir="auto">System:<br />
Upgraded to v.2.6<br />
Running on Jessie<br />
RPI3</p>
<p dir="auto">Please let me know if any additional info is needed :)</p>
<p dir="auto">Thx in advance for your time if anybody can help me.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9481/3rd-party-modules-won-t-show-up-expect-standard-ones</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 00:30:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9481.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Jan 2019 18:19:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 3rd party Modules won&#x27;t show up - (expect standard ones) on Sat, 12 Jan 2019 23:39:50 GMT]]></title><description><![CDATA[<p dir="auto">would this ring a bell to anyone?<br />
0 info it worked if it ends with ok<br />
1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]<br />
2 info using npm@3.10.8<br />
3 info using node@v6.9.1<br />
4 verbose stack Error: missing script: start<br />
4 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:151:19)<br />
4 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:61:5<br />
4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:356:5<br />
4 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:320:45)<br />
4 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:354:3)<br />
4 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:124:5)<br />
4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:311:12<br />
4 verbose stack     at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16<br />
4 verbose stack     at tryToString (fs.js:455:3)<br />
4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:442:12)<br />
5 verbose cwd /home/pi/MagicMirror/modules/MMM-Globe<br />
6 error Linux 4.4.26-v7+<br />
7 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start” “dev”<br />
8 error node v6.9.1<br />
9 error npm  v3.10.8<br />
10 error missing script: start<br />
11 error If you need help, you may report this error at:<br />
11 error     <a href="https://github.com/npm/npm/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/npm/npm/issues</a><br />
12 verbose exit [ 1, true ]</p>
]]></description><link>https://forum.magicmirror.builders/post/50017</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50017</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sat, 12 Jan 2019 23:39:50 GMT</pubDate></item><item><title><![CDATA[Reply to 3rd party Modules won&#x27;t show up - (expect standard ones) on Sat, 12 Jan 2019 20:56:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> looks like MMM-Globe is having a problem… after you did the git clone, did you change to the MMM-Globe folder and do,</p>
<pre><code>npm install
]]></description><link>https://forum.magicmirror.builders/post/50011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50011</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Jan 2019 20:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to 3rd party Modules won&#x27;t show up - (expect standard ones) on Sat, 12 Jan 2019 20:14:01 GMT]]></title><description><![CDATA[<p dir="auto">I could make it work by uninstal the module and git clone it again… no idea why it was not working but the answer should be in the pics i assume :)</p>
<p dir="auto">Nevertheless, i have red few issues regarding how to display 2 calendars.<br />
I just can’t figure it out how to display 2 of them… my config file :<br />
<img src="/assets/uploads/files/1547323430061-capture-d-e-cran-2019-01-12-a-20.55.06.png" alt="0_1547323429467_Capture d’écran 2019-01-12 à 20.55.06.png" class=" img-fluid img-markdown" /><br />
If someone can share his/her config file for this, pls, it would be great!</p>
]]></description><link>https://forum.magicmirror.builders/post/50009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50009</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sat, 12 Jan 2019 20:14:01 GMT</pubDate></item><item><title><![CDATA[Reply to 3rd party Modules won&#x27;t show up - (expect standard ones) on Sat, 12 Jan 2019 19:20:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thx for the tip but honestly i don’t know how to analyze the console output… :( here are 2 pics that i took just now (sorry for bad quality) ! <img src="/assets/uploads/files/1547320779517-img_7536.jpg" alt="0_1547320777816_IMG_7536.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1547320795343-img_7537.jpg" alt="0_1547320793399_IMG_7537.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/50007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50007</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sat, 12 Jan 2019 19:20:07 GMT</pubDate></item><item><title><![CDATA[Reply to 3rd party Modules won&#x27;t show up - (expect standard ones) on Sat, 12 Jan 2019 19:01:10 GMT]]></title><description><![CDATA[<p dir="auto">start the mirror in dev mode</p>
<p dir="auto">npm start dev</p>
<p dir="auto">and select the console tab, look for errors…</p>
]]></description><link>https://forum.magicmirror.builders/post/50004</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50004</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Jan 2019 19:01:10 GMT</pubDate></item><item><title><![CDATA[Reply to 3rd party Modules won&#x27;t show up - (expect standard ones) on Sat, 12 Jan 2019 18:57:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> Thank you very much for your prompt feedback help. The problem is not MMM-globe module itself ;-) (was just an example) but a general like problem with all 3rd part modules so far.</p>
]]></description><link>https://forum.magicmirror.builders/post/50002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50002</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sat, 12 Jan 2019 18:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to 3rd party Modules won&#x27;t show up - (expect standard ones) on Sat, 12 Jan 2019 18:40:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">for all modules nomaly you can find a installation guide like this one  at MMM-globe<br />
github page:</p>
<p dir="auto"><a href="https://github.com/LukeSkywalker92/MMM-Globe" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/LukeSkywalker92/MMM-Globe</a></p>
<p dir="auto">Installation</p>
<p dir="auto">Navigate into your MagicMirror’s modules folder and execute <code> //git clone https://github.com/LukeSkywalker92/MMM-Globe.git.</code></p>
<p dir="auto">The entry in config.js can include the following options</p>
<p dir="auto">Follow the instructions.</p>
]]></description><link>https://forum.magicmirror.builders/post/50000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50000</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Sat, 12 Jan 2019 18:40:17 GMT</pubDate></item></channel></rss>
