<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Start without internet connection and restart with, make modul work?]]></title><description><![CDATA[<p dir="auto">Prehistory:<br />
I’ve been trying for weeks to switch pages with Real Buttons. This works quite well with MMM Page Selector.<br />
Now I wanted to press the button to display the Tagesschau 100sek with the module Podcast2.<br />
For days I try to integrate and it just does not start.<br />
Today:<br />
By a stupid coincidence, I discovered something.<br />
I went to work and took my Raspi to test by the way. Raspi started, desktop stays black! Aaaah! OK No internet. I put F11 so that I come to the desktop, then Turn on the W-LAN because otherwise no Internet possible. Terminal opened and MM restarted. “pm2 restart mm”<br />
MM comes. I think I’ll push the 2 buttons if the two sides are still changing, and YES it still does. Wy not ;-) Press the 3 button and behold! Podcast starts to run. I’m amazed. But why? What the hell is going on.<br />
I think, and do some tests.<br />
The following, if I start the computer without Internet, then shrink MM to get to the wi-fi switch ,. Turn on W-Lan and restart MM, the button works and podcast starts.<br />
But if I restart MM now it does not work anymore. So i must Start without Internet connection then restart MM and its Going.<br />
Very Strange!</p>
<p dir="auto">Now I’m not sure why that is and where to ask for help?<br />
MMM-Buttons<br />
MMM-Page-Selector,<br />
MMM-Podcast2<br />
or<br />
on the MagicMirror itself</p>
]]></description><link>https://forum.magicmirror.builders/topic/9482/start-without-internet-connection-and-restart-with-make-modul-work</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 21:29:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9482.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Jan 2019 18:41:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Thu, 17 Jan 2019 21:27:55 GMT]]></title><description><![CDATA[<p dir="auto">Werde ich gleich morgen Nachmittag testen, das wäre ja der große Knaller.<br />
Danke fürs recherchieren.<br />
Ich werde auf jedenfall Rückmelden.</p>
<p dir="auto">Will I test the same tomorrow afternoon, that would be the big bang.<br />
Thanks for researching.<br />
I will definitely confirm.</p>
]]></description><link>https://forum.magicmirror.builders/post/50344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50344</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Thu, 17 Jan 2019 21:27:55 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Thu, 17 Jan 2019 19:51:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robiv8" aria-label="Profile: robiv8">@<bdi>robiv8</bdi></a><br />
I guess i found the solution of your problem, it is the combination of MMM-Page-Selector and MMM-Podcast2 the way you used it in your config.js</p>
<p dir="auto">Details see <a href="https://github.com/Ax-LED/MMM-Podcast2/issues/3#issuecomment-455306957" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Podcast2/issues</a></p>
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/post/50335</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50335</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Thu, 17 Jan 2019 19:51:33 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Tue, 15 Jan 2019 23:21:30 GMT]]></title><description><![CDATA[<p dir="auto">OK i do my best</p>
]]></description><link>https://forum.magicmirror.builders/post/50226</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50226</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Tue, 15 Jan 2019 23:21:30 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Tue, 15 Jan 2019 22:40:05 GMT]]></title><description><![CDATA[<p dir="auto">go back to the dev console, npm start dev, or ctrl-shift-i, then select console tab, and see if there is an error on the browser side, where the video will actually play…</p>
<p dir="auto">looks like its state is out of sync… (thinks its neither playing nor stopped)…<br />
getting stop fixes it…</p>
]]></description><link>https://forum.magicmirror.builders/post/50225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50225</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 15 Jan 2019 22:40:05 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Tue, 15 Jan 2019 22:33:31 GMT]]></title><description><![CDATA[<p dir="auto">I experimented a lot and read a lot.<br />
This “streamurl is not defined” has made me curious.<br />
So i put a new entry in the MMM podcast2.js under line 12 with:</p>
<pre><code>var streamurl = '';
<p dir="auto">then it will work after a reboot, but not right after the first press.<br />
You have to press again and next time it will come.<br />
So page is set up, then Press Button for Play, Press Button for Stop, Press Button for Play and then comes the video. Very Strange.</p>
<pre><code>Server started ...
Connecting socket for: MMM-Remote-Control
Starting node helper for: MMM-Remote-Control
Connecting socket for: MMM-Buttons
Starting node helper for: MMM-Buttons
Connecting socket for: MMM-Page-Selector
Connecting socket for: MMM-Podcast2
Starting module: newsfeed
Sockets connected &amp; modules started ...
Launching application.
Initialize button Hauptseite on PIN 17
Initialize button Podcast on PIN 24
Starting node helper for: MMM-Podcast2
Create new news fetcher for url: http://www.stuttgarter-nachrichten.de/stuttgart.rss.feed - Interval: 300000
Use existing news fetcher for url: http://www.stuttgarter-nachrichten.de/stuttgart.rss.feed
The site has now fully built up.
Now i press the button:
MMM-Podcast2 PLAY: &lt; -- Nothing! Also do not wait for a longer time
MMM-Podcast2 STOP:
MMM-Podcast2 PLAY: &lt; -- now comes the Video
MMM-Podcast2 STOP:
<p dir="auto">Does anyone have a tip what this can still be?<br />
For that I have no idea about the programming I am proud that I have managed it so :-) lol</p>
]]></description><link>https://forum.magicmirror.builders/post/50224</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50224</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Tue, 15 Jan 2019 22:33:31 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Mon, 14 Jan 2019 22:46:26 GMT]]></title><description><![CDATA[<p dir="auto">OK i understand!  :winking_face:</p>
<p dir="auto">That leaves us mortals, only hope.<br />
So bleibt uns Sterblichen, nur noch die Hoffnung.</p>
]]></description><link>https://forum.magicmirror.builders/post/50170</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50170</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Mon, 14 Jan 2019 22:46:26 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Mon, 14 Jan 2019 22:42:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robiv8" aria-label="Profile: robiv8">@<bdi>robiv8</bdi></a> right. In many cases the authors hope that users will jump in and modify the code and submit it back…  as this is all volunteer work.</p>
<p dir="auto">welcome to open source</p>
]]></description><link>https://forum.magicmirror.builders/post/50169</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50169</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 14 Jan 2019 22:42:17 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Mon, 14 Jan 2019 22:14:53 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the information,<br />
That means I can only hope and ask that the makers of the modules fix that? If that’s even possible!</p>
]]></description><link>https://forum.magicmirror.builders/post/50167</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50167</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Mon, 14 Jan 2019 22:14:53 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Mon, 14 Jan 2019 04:17:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robiv8" aria-label="Profile: robiv8">@<bdi>robiv8</bdi></a>  yep, as I said…   lots of errors…  most not recoverable due to the modules individual designs…</p>
<pre><code>MMM-Podcast-xml2json.js:65,    dies as no xml came back.. oops..
MMM-Page-Selector.js:116 ,   oops.. the target page doesn't exist (cause the prior module failed to build it..)
MMM-Podcast2.js:72,
etc
]]></description><link>https://forum.magicmirror.builders/post/50111</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50111</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 14 Jan 2019 04:17:33 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Sat, 12 Jan 2019 23:15:44 GMT]]></title><description><![CDATA[<p dir="auto">So I have do it and here is the log file.</p>
<pre><code>main.js:450 Initializing MagicMirror.
translator.js:201 Loading core translation file: translations/de.json
translator.js:224 Loading core translation fallback file: translations/en.json
loader.js:182 Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js
module.js:469 Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.1.0 - Current version: 2.6.0
module.js:471 Version is ok!
module.js:477 Module registered: MMM-Remote-Control
loader.js:152 Bootstrapping module: MMM-Remote-Control
loader.js:157 Scripts loaded for: MMM-Remote-Control
loader.js:197 Load stylesheet: modules/MMM-Remote-Control/remote-control.css
loader.js:159 Styles loaded for: MMM-Remote-Control
loader.js:161 Translations loaded for: MMM-Remote-Control
loader.js:182 Load script: modules/MMM-Buttons//MMM-Buttons.js
module.js:469 Check MagicMirror version for module 'MMM-Buttons' - Minimum version:  2.1.0 - Current version: 2.6.0
module.js:477 Module registered: MMM-Buttons
loader.js:152 Bootstrapping module: MMM-Buttons
loader.js:157 Scripts loaded for: MMM-Buttons
loader.js:159 Styles loaded for: MMM-Buttons
loader.js:161 Translations loaded for: MMM-Buttons
loader.js:182 Load script: modules/MMM-Page-Selector//MMM-Page-Selector.js
module.js:469 Check MagicMirror version for module 'MMM-Page-Selector' - Minimum version:  2.1.0 - Current version: 2.6.0
module.js:477 Module registered: MMM-Page-Selector
loader.js:152 Bootstrapping module: MMM-Page-Selector
loader.js:182 Load script: modules/MMM-Page-Selector/resources/numConvert.js
loader.js:157 Scripts loaded for: MMM-Page-Selector
loader.js:197 Load stylesheet: modules/MMM-Page-Selector/MMM-Page-Selector.css
loader.js:159 Styles loaded for: MMM-Page-Selector
loader.js:161 Translations loaded for: MMM-Page-Selector
loader.js:182 Load script: modules/default/alert//alert.js
module.js:477 Module registered: alert
loader.js:152 Bootstrapping module: alert
loader.js:182 Load script: modules/default/alert/classie.js
loader.js:182 Load script: modules/default/alert/modernizr.custom.js
loader.js:182 Load script: modules/default/alert/notificationFx.js
loader.js:157 Scripts loaded for: alert
loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
loader.js:159 Styles loaded for: alert
translator.js:172 alert - Load translation: translations/de.json
/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:128 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure protocols. This exposes users of this app to unnecessary security risks. Consider loading the following resources over HTTPS or FTPS.
- http://0.0.0.0:8080/css/main.css
- http://0.0.0.0:8080/fonts/roboto.css
- http://0.0.0.0:8080/socket.io/socket.io.js
- http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
- http://0.0.0.0:8080/js/defaults.js
- http://0.0.0.0:8080/config/config.js
- http://0.0.0.0:8080/vendor/vendor.js
- http://0.0.0.0:8080/modules/default/defaultmodules.js
- http://0.0.0.0:8080/js/logger.js
- http://0.0.0.0:8080/translations/translations.js
- http://0.0.0.0:8080/js/translator.js
- http://0.0.0.0:8080/js/class.js
- http://0.0.0.0:8080/js/module.js
- http://0.0.0.0:8080/js/loader.js
- http://0.0.0.0:8080/js/socketclient.js
- http://0.0.0.0:8080/js/main.js
- http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
- http://0.0.0.0:8080/translations/de.json
- http://0.0.0.0:8080/translations/en.json
- http://0.0.0.0:8080/modules/MMM-Remote-Control//MMM-Remote-Control.js
- http://0.0.0.0:8080/modules/MMM-Remote-Control/remote-control.css
- http://0.0.0.0:8080/modules/MMM-Buttons//MMM-Buttons.js
- http://0.0.0.0:8080/modules/MMM-Page-Selector//MMM-Page-Selector.js
- http://0.0.0.0:8080/modules/MMM-Page-Selector/resources/numConvert.js
- http://0.0.0.0:8080/modules/MMM-Page-Selector/MMM-Page-Selector.css
- http://0.0.0.0:8080/modules/default/alert//alert.js
- http://0.0.0.0:8080/modules/default/alert/classie.js
- http://0.0.0.0:8080/modules/default/alert/modernizr.custom.js
- http://0.0.0.0:8080/modules/default/alert/notificationFx.js
- http://0.0.0.0:8080/modules/default/alert/ns-default.css
For more information and help, consult https://electronjs.org/docs/tutorial/security.
This warning will not show up once the app is packaged.
warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:128
/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:188 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security Policy set or a policy with "unsafe-eval" enabled. This exposes users of this app to unnecessary security risks.
warnAboutInsecureCSP @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:188
translator.js:174 alert - Load translation fallback: translations/en.json
loader.js:161 Translations loaded for: alert
loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
module.js:477 Module registered: updatenotification
loader.js:152 Bootstrapping module: updatenotification
loader.js:157 Scripts loaded for: updatenotification
loader.js:159 Styles loaded for: updatenotification
loader.js:161 Translations loaded for: updatenotification
loader.js:182 Load script: modules/default/clock//clock.js
module.js:477 Module registered: clock
loader.js:152 Bootstrapping module: clock
loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
loader.js:157 Scripts loaded for: clock
loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
loader.js:159 Styles loaded for: clock
loader.js:161 Translations loaded for: clock
loader.js:182 Load script: modules/default/currentweather//currentweather.js
module.js:477 Module registered: currentweather
loader.js:152 Bootstrapping module: currentweather
loader.js:237 File already loaded: moment.js
loader.js:157 Scripts loaded for: currentweather
loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
loader.js:197 Load stylesheet: modules/default/currentweather/currentweather.css
loader.js:159 Styles loaded for: currentweather
loader.js:161 Translations loaded for: currentweather
loader.js:182 Load script: modules/MMM-Podcast2//MMM-Podcast2.js
module.js:477 Module registered: MMM-Podcast2
loader.js:152 Bootstrapping module: MMM-Podcast2
loader.js:182 Load script: modules/MMM-Podcast2/MMM-Podcast-xml2json.js
loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
loader.js:157 Scripts loaded for: MMM-Podcast2
loader.js:197 Load stylesheet: modules/MMM-Podcast2/MMM-Podcast2.css
loader.js:159 Styles loaded for: MMM-Podcast2
loader.js:161 Translations loaded for: MMM-Podcast2
loader.js:182 Load script: modules/default/newsfeed//newsfeed.js
module.js:477 Module registered: newsfeed
loader.js:152 Bootstrapping module: newsfeed
loader.js:157 Scripts loaded for: newsfeed
loader.js:159 Styles loaded for: newsfeed
loader.js:161 Translations loaded for: newsfeed
loader.js:197 Load stylesheet: css/custom.css
MMM-Remote-Control.js:21 Starting module: MMM-Remote-Control
MMM-Buttons.js:25 Starting module: MMM-Buttons
alert.js:153 Starting module: alert
updatenotification.js:10 Start updatenotification
clock.js:40 Starting module: clock
currentweather.js:96 Starting module: currentweather
MMM-Podcast2.js:38 Starting module: MMM-Podcast2
newsfeed.js:59 Starting module: newsfeed
main.js:468 All modules started!
module.js:156 MMM-Buttons received a system notification: ALL_MODULES_STARTED
module.js:156 clock received a system notification: ALL_MODULES_STARTED
newsfeed.js:340 newsfeed - received notification: ALL_MODULES_STARTED
newsfeed.js:391 newsfeed - unknown notification, ignoring: ALL_MODULES_STARTED
module.js:198 MMM-Remote-Control is suspended.
module.js:198 MMM-Buttons is suspended.
module.js:198 alert is suspended.
module.js:198 MMM-Podcast2 is suspended.
module.js:156 clock received a system notification: MODULE_DOM_CREATED
newsfeed.js:340 newsfeed - received notification: MODULE_DOM_CREATED
newsfeed.js:391 newsfeed - unknown notification, ignoring: MODULE_DOM_CREATED
module.js:156 MMM-Buttons received a system notification: DOM_OBJECTS_CREATED
module.js:156 clock received a system notification: DOM_OBJECTS_CREATED
newsfeed.js:340 newsfeed - received notification: DOM_OBJECTS_CREATED
newsfeed.js:391 newsfeed - unknown notification, ignoring: DOM_OBJECTS_CREATED
module.js:198 MMM-Page-Selector is suspended.
module.js:198 clock is suspended.
module.js:198 newsfeed is suspended.
module.js:198 updatenotification is suspended.
module.js:198 currentweather is suspended.
currentweather.js:338 GET https://api.openweathermap.org/data/2.5/weather?id=2825297&amp;units=metric&amp;lang=de&amp;APPID=mypersonalid net::ERR_INTERNET_DISCONNECTED
updateWeather @ currentweather.js:338
(anonymous) @ currentweather.js:499
setTimeout (async)
scheduleUpdate @ currentweather.js:498
start @ currentweather.js:112
startModules @ loader.js:55
(anonymous) @ loader.js:40
stylesheet.onload @ loader.js:203
currentweather.js:330 currentweather: Could not load weather.
weatherRequest.onreadystatechange @ currentweather.js:330
XMLHttpRequest.send (async)
setTimeout (async)
MMM-Podcast-xml2json.js:65 Uncaught TypeError: xmlStr.replace is not a function
    at cleanXML (MMM-Podcast-xml2json.js:65)
    at xml2json (MMM-Podcast-xml2json.js:11)
    at Class.socketNotificationReceived (MMM-Podcast2.js:88)
    at module.js:246
    at r.&lt;anonymous&gt; (socketclient.js:25)
    at r.emit (index.js:83)
    at r.onevent (index.js:83)
    at r.MMSocket.self.socket.onevent (socketclient.js:19)
    at r.onpacket (index.js:83)
    at r.&lt;anonymous&gt; (index.js:83)
cleanXML @ MMM-Podcast-xml2json.js:65
xml2json @ MMM-Podcast-xml2json.js:11
socketNotificationReceived @ MMM-Podcast2.js:88
(anonymous) @ module.js:246
(anonymous) @ socketclient.js:25
r.emit @ index.js:83
r.onevent @ index.js:83
MMSocket.self.socket.onevent @ socketclient.js:19
r.onpacket @ index.js:83
(anonymous) @ index.js:83
r.ondecoded @ index.js:83
a.add @ index.js:83
r.ondata @ index.js:83
r.onPacket @ index.js:83
n @ index.js:83
e.decodePayload @ index.js:83
r.onData @ index.js:83
i.onData @ index.js:83
i.onLoad @ index.js:83
hasXDR.n.onreadystatechange @ index.js:83
i.create @ index.js:83
i @ index.js:83
o.request @ index.js:83
o.doPoll @ index.js:83
r.poll @ index.js:83
i @ index.js:83
i @ index.js:83
i @ index.js:83
i @ index.js:83
r.doOpen @ index.js:83
r.open @ index.js:83
r @ index.js:83
r @ index.js:83
r.open.r.connect @ index.js:83
r @ index.js:83
r @ index.js:83
r @ index.js:83
MMSocket @ socketclient.js:11
socket @ module.js:241
sendSocketNotification @ module.js:378
sendConfig @ MMM-Buttons.js:49
start @ MMM-Buttons.js:27
setTimeout (async)
weatherRequest.onreadystatechange @ currentweather.js:334
setTimeout (async)
setTimeout (async)
setTimeout (async)
MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: PAGE_SELECT from sender: MMM-Buttons
MMM-Page-Selector.js:116 Uncaught TypeError: Cannot read property 'haupt' of undefined
    at Class.setUpPage (MMM-Page-Selector.js:116)
    at Class.changePage (MMM-Page-Selector.js:174)
    at selectPage (MMM-Page-Selector.js:187)
    at Class.notificationReceived (MMM-Page-Selector.js:191)
    at sendNotification (main.js:95)
    at Object.sendNotification (main.js:498)
    at Class.sendNotification (module.js:368)
    at Class.sendAction (MMM-Buttons.js:88)
    at Class.buttonUp (MMM-Buttons.js:77)
    at Class.socketNotificationReceived (MMM-Buttons.js:120)
setUpPage @ MMM-Page-Selector.js:116
changePage @ MMM-Page-Selector.js:174
selectPage @ MMM-Page-Selector.js:187
notificationReceived @ MMM-Page-Selector.js:191
sendNotification @ main.js:95
sendNotification @ main.js:498
sendNotification @ module.js:368
sendAction @ MMM-Buttons.js:88
buttonUp @ MMM-Buttons.js:77
socketNotificationReceived @ MMM-Buttons.js:120
a.add @ index.js:83
ws.onmessage @ index.js:83
setTimeout (async)
MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: BUTTON_PRESSED from sender: MMM-Buttons
module.js:154 clock received a module notification: BUTTON_PRESSED from sender: MMM-Buttons
MMM-Podcast2.js:72 Uncaught ReferenceError: streamurl is not defined
    at Class.notificationReceived (MMM-Podcast2.js:72)
    at module.js:246
notificationReceived @ MMM-Podcast2.js:72
a.add @ index.js:83
setTimeout (async)
module.js:205 currentweather is resumed.
main.js:275 Will not show currentweather. LockStrings active: module_2_MMM-Page-Selector
MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: CURRENTWEATHER_DATA from sender: currentweather
module.js:154 MMM-Buttons received a module notification: CURRENTWEATHER_DATA from sender: currentweather
module.js:154 clock received a module notification: CURRENTWEATHER_DATA from sender: currentweather
newsfeed.js:340 newsfeed - received notification: CURRENTWEATHER_DATA
newsfeed.js:391 newsfeed - unknown notification, ignoring: CURRENTWEATHER_DATA
a.add @ index.js:83
MMM-Page-Selector.js:116 Uncaught TypeError: Cannot read property 'zweite' of undefined
a.add @ index.js:83
MMM-Podcast2.js:76 Uncaught ReferenceError: streamurl is not defined
    at Class.notificationReceived (MMM-Podcast2.js:76)
    at module.js:246
notificationReceived @ MMM-Podcast2.js:76
a.add @ index.js:83
MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
module.js:154 MMM-Buttons received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
module.js:154 clock received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
newsfeed.js:340 newsfeed - received notification: MAX_PAGES_CHANGED
newsfeed.js:391 newsfeed - unknown notification, ignoring: MAX_PAGES_CHANGED
MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
module.js:154 MMM-Buttons received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
module.js:154 clock received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
newsfeed.js:340 newsfeed - received notification: PAGE_CHANGED
newsfeed.js:391 newsfeed - unknown notification, ignoring: PAGE_CHANGED
module.js:205 MMM-Page-Selector is resumed.
module.js:205 clock is resumed.
module.js:154 clock received a module notification: PAGE_SELECT from sender: MMM-Buttons
newsfeed.js:340 newsfeed - received notification: PAGE_SELECT
newsfeed.js:391 newsfeed - unknown notification, ignoring: PAGE_SELECT
MMM-Page-Selector.js:83 Uncaught Module was selected, but not found in the DOM. Make sure that a position for the module is set in the config.js!
getModuleRef @ MMM-Page-Selector.js:83
MM.getModules.enumerate.module @ MMM-Page-Selector.js:143
(anonymous) @ main.js:433
enumerate @ main.js:432
setTimeout @ MMM-Page-Selector.js:137
setTimeout (async)
setUpPage @ MMM-Page-Selector.js:136
a.add @ index.js:83
    at module.js:246
a.add @ index.js:83
setTimeout (async)
]]></description><link>https://forum.magicmirror.builders/post/50016</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50016</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Sat, 12 Jan 2019 23:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Sat, 12 Jan 2019 19:03:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the tip.<br />
I am going now home and will try it.</p>
]]></description><link>https://forum.magicmirror.builders/post/50006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50006</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Sat, 12 Jan 2019 19:03:35 GMT</pubDate></item><item><title><![CDATA[Reply to Start without internet connection and restart with, make modul work? on Sat, 12 Jan 2019 18:59:33 GMT]]></title><description><![CDATA[<p dir="auto">start the mirror without internet, but open the dev console (npm start dev),<br />
select the console tab… look for errors…</p>
<p dir="auto">most of the modules do not recover from system issues like this from startup… they might AFTER successfully starting, if the internet were to go out and come back…</p>
]]></description><link>https://forum.magicmirror.builders/post/50003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50003</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Jan 2019 18:59:33 GMT</pubDate></item></channel></rss>
