<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt2 not working with MMM-Carousel]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I tried to use the CalendarExt2 with MMM-Carousel. But all modules specified in MMM-Carousel will be shown on one page and the change of pages is not possible (but the dots are shown). With MMM-CalendarExt it is working, I just changed to CalendarExt2 within the MMM-Carousel-Configuration, if I change back it is working.<br />
Has anybody faced the same problem?</p>
<p dir="auto">Best regards<br />
sworrs</p>
]]></description><link>https://forum.magicmirror.builders/topic/9486/mmm-calendarext2-not-working-with-mmm-carousel</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 17:33:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9486.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Jan 2019 13:37:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt2 not working with MMM-Carousel on Sun, 27 Jan 2019 19:08:10 GMT]]></title><description><![CDATA[<p dir="auto">@sean +1!  Works great, thank you.  Only issue I’ve noticed is some sort of race condition where if CalendarExt2 had started to refresh right when Carousel is changing slides, the CalendarExt2 is drawn out anyway.  Not sure if this will be a “real” problem for me once I set the refresh intervals to something longer than used for testing, but I have noticed it.</p>
]]></description><link>https://forum.magicmirror.builders/post/50938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50938</guid><dc:creator><![CDATA[gregp]]></dc:creator><pubDate>Sun, 27 Jan 2019 19:08:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 not working with MMM-Carousel on Sun, 13 Jan 2019 14:41:58 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
Thank you, now it works :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/50052</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50052</guid><dc:creator><![CDATA[sworrs]]></dc:creator><pubDate>Sun, 13 Jan 2019 14:41:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 not working with MMM-Carousel on Sun, 13 Jan 2019 14:02:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sworrs" aria-label="Profile: sworrs">@<bdi>sworrs</bdi></a><br />
I made an urgent fix for that. If MMM-CalendarExt2 is not in <code>main</code> page of MMM-Carousel (or at start of MM), it couldn’t draw itself under hidden state. That might be the reason of your issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/50048</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50048</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 13 Jan 2019 14:02:43 GMT</pubDate></item></channel></rss>
