<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Hotword, x86 and invalid pointer]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’ve installed Debian Stretch on my laptop, and tried to run MMM-Hotword.<br />
Installation is successful without errors, but when trying to run ‘npm start’, I get an error:</p>
<pre><code>../../third_party/tcmalloc/chromium/src/tcmalloc.cc:289] Attempt to free invalid pointer 0x7ffeaef7b090
<p dir="auto">I’ve asked the developer, and he assumes it is snowboy that causes the issue, as snowboy git states:</p>
<pre><code>Currently Snowboy supports (look into the lib folder):
all versions of Raspberry Pi (with Raspbian based on Debian Jessie 8.0)
64bit Mac OS X
64bit Ubuntu 14.04
iOS
Android
ARM64 (aarch64, Ubuntu 16.04)
<p dir="auto">My questions is; what platforms, types of linux and versions have you guys been able to run Hotword on?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9496/mmm-hotword-x86-and-invalid-pointer</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 04:14:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9496.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Jan 2019 11:36:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Hotword, x86 and invalid pointer on Mon, 14 Jan 2019 13:25:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thestigh" aria-label="Profile: thestigh">@<bdi>thestigh</bdi></a><br />
I think this could be one of alternatives;</p>
<ul>
<li>MMM-Voice<br />
<a href="https://github.com/fewieden/MMM-voice" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fewieden/MMM-voice</a></li>
</ul>
<p dir="auto">It has features simple voice commands in itself. You can use this standalone or Waker for MMM-AssistantMk2 (I haven’t tried but I have a will to help you)</p>
]]></description><link>https://forum.magicmirror.builders/post/50136</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50136</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 14 Jan 2019 13:25:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword, x86 and invalid pointer on Mon, 14 Jan 2019 13:19:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi @sean<br />
Thanks for your prompt reply, really appreciate it :)</p>
<p dir="auto">My ‘issue’ is trying to put a lot of info on my MM, including video streams which makes the RPi to slow. So I’m searching for other ways of getting more power = miniPC etc running a linux variant compatible with Hotword and AssistantMk2.</p>
<p dir="auto">I can see that Ubuntu 14.04 are supported on 64 bit, but was hoping there are something ‘newer’ available which has been achieved by geniuses like you.</p>
<p dir="auto">My developer skills are not good, though I can read and quite understand .js</p>
]]></description><link>https://forum.magicmirror.builders/post/50135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50135</guid><dc:creator><![CDATA[THeStigh]]></dc:creator><pubDate>Mon, 14 Jan 2019 13:19:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword, x86 and invalid pointer on Mon, 14 Jan 2019 12:11:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thestigh" aria-label="Profile: thestigh">@<bdi>thestigh</bdi></a><br />
Usually, MM is executed on Raspberry Pi.(Raspbian Stretch). It is based on Debian Stretch but ARM based.<br />
For other unsupported platform, you cannot use Hotword detector based Snowboy. But there might be alternatives.</p>
<ul>
<li>PocketSphinx</li>
<li>Google Speech API</li>
<li>PicoVoice<br />
and so more.<br />
Some are already implemented to MM modules, or you can make your own for your platform if you have some experiences for programming.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/50133</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50133</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 14 Jan 2019 12:11:06 GMT</pubDate></item></channel></rss>
