<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[rotate screen with display object in electron]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">there are a lot of (heavy) gpu performance issues with <code>display_rotate</code> or <code>xrandr</code> since electron (MM2). It seems like the fps drops from 30fps to 5fps after the rotation. CPU stays the same. Checked that with <code>nmon</code>. I tested a lot of boards (raspberry 2, 3, 3+, Tinker Board, odroid) ,a lot of OS (raspbian, tinker os, xubuntu, lubuntu) and some configurations (OpenGL, amount of modules, electron versions, …). Still the same; more or less.</p>
<p dir="auto">As I can see, there is an display object in electron which can handle an rotate option. Does anybody have experience in it? Or perhaps another solution for rotating?</p>
<p dir="auto">I’m curious about the answers ;).</p>
]]></description><link>https://forum.magicmirror.builders/topic/9497/rotate-screen-with-display-object-in-electron</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 13:48:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9497.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Jan 2019 11:43:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to rotate screen with display object in electron on Tue, 19 Feb 2019 22:25:07 GMT]]></title><description><![CDATA[<p dir="auto">Try this thread <a href="https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi">save-performance-when-rotating-screen-e-g-on-raspberry-pi</a></p>
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/post/52777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52777</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Tue, 19 Feb 2019 22:25:07 GMT</pubDate></item></channel></rss>
