<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help new users with config syntax errors, proposal]]></title><description><![CDATA[<p dir="auto">we see a LOT of new users having trouble with unintended syntax errors in config.js.<br />
they don’t know, and MM is running happily without their changes…</p>
<p dir="auto">so, I want to propose adding the call to tests/configs/check_config.js as part of the error handling…</p>
<p dir="auto">this was easy, except… MM keeps running with the default config… which it shouldn’t…</p>
<p dir="auto">I’ve tried all kind of things…  process.exit(0); is quick death… except the output of the tests/configs/check_config.js isn’t flushed, so the messages don’t show up…</p>
<p dir="auto">they took out process.stdout.flush() a long time ago…</p>
<p dir="auto">none of the workarounds appear to work…</p>
<p dir="auto">anyone got any ideas?</p>
<p dir="auto">thanks…</p>
]]></description><link>https://forum.magicmirror.builders/topic/9498/help-new-users-with-config-syntax-errors-proposal</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 01:32:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9498.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Jan 2019 13:35:34 GMT</pubDate><ttl>60</ttl></channel></rss>
