<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR debouncing implementation?]]></title><description><![CDATA[<p dir="auto">So I am attempting to use a mini-pir sensor with the MMM-PIR module. I am able to successfully use a full size SR-501 PIR sensor but when I try to use the mini SR-505 sensor the sensor triggers a wake cycle every 40 ish seconds regardless of motion. I’m positive this is because the operating range of the smaller sensor is a slightly higher voltage (4.5V minimum to 20V max) and is causing it to have occasional peaks when it is running at only 5V. Is there a way to implement debouncing in this module? I have zero programming experience but have looked into this issue and seen debouncing used in other applications. Any recommendations?</p>
]]></description><link>https://forum.magicmirror.builders/topic/950/mmm-pir-debouncing-implementation</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:14:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/950.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Nov 2016 01:44:11 GMT</pubDate><ttl>60</ttl></channel></rss>
