<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error PVOutput widget module]]></title><description><![CDATA[<p dir="auto">PVOutput widget module</p>
<p dir="auto">Hi all i have install to day the PV output widget. I have the following error " Bad request 400: No status found.<br />
Cane some help with this error</p>
]]></description><link>https://forum.magicmirror.builders/topic/9500/error-pvoutput-widget-module</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 08:37:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9500.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Jan 2019 14:17:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error PVOutput widget module on Mon, 14 Jan 2019 20:53:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ernst-jan" aria-label="Profile: ernst-jan">@<bdi>ernst-jan</bdi></a> - Is your error when you are trying to install the module or when you’re trying to run the module?</p>
<p dir="auto">Assuming the install went wrong, what command did you use to install it? Remember to use the markdown features when you reply.</p>
]]></description><link>https://forum.magicmirror.builders/post/50161</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50161</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 14 Jan 2019 20:53:04 GMT</pubDate></item></channel></rss>
