<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[abnormal cpu usage.]]></title><description><![CDATA[<p dir="auto">after i rebuild my MM the cpu usage was 20 to max 30 % and ofcource the heat was very low.After a week or so ,without changing anything,the cpu usage went up to 60-65%.I did a reboot and a complete shutdown but nothing changed.With cpu usage around 65% the cpu temp is 65 to 68 C.What is wrong?Iam monitoring cpu stats with the Tools module.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9512/abnormal-cpu-usage</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 03:51:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9512.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Jan 2019 18:54:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to abnormal cpu usage. on Tue, 15 Jan 2019 20:39:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/costascontis" aria-label="Profile: costascontis">@<bdi>costascontis</bdi></a> - Are all of your modules working correctly? Some modules may have an infinite and very short retry on API calls. Multiple internet calls take up a fair amount of processing power.</p>
<p dir="auto">Do you notice anything in the logs?</p>
]]></description><link>https://forum.magicmirror.builders/post/50218</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50218</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 15 Jan 2019 20:39:17 GMT</pubDate></item></channel></rss>
