<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MONITORON on does not work in schedule]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I’ve installed MMM-Remote-Control and MMM-ModuleScheduler.  I basically want the MM to be off all night, it should then start up at 9:15, the monitor turn on at 9:30, then off at 11:30 and MM down at 11:45.  The global_schedule works fine and the monitor shuts off correctly.  However, the monitor does not come on in the morning. I can use the power on menu choice from the remote web page to turn the monitor on.  It just won’t come on via the notification_schedule.  Can someone suggest what is incorrect in my config.js entry?</p>
<pre><code>module: 'MMM-ModuleScheduler',
	    // Show all modules at 9:15 every day and hide at 11:45
	   global_schedule: {from: '15 9 * * *', to: '45 23 * * *'},
            notification_schedule: [
                // TURN THE MONITOR/SCREEN ON AT 09:30 EVERY DAY
                {notification: 'REMOTE_ACTION', schedule: '30 9 * * *', payload: {action: "MONITORON"}},
                // TURN THE MONITOR/SCREEN OFF AT 11:30pm EVERY DAY
                {notification: 'REMOTE_ACTION', schedule: '30 23 * * *', payload: {action: "MONITOROFF"}},
                // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9528/monitoron-on-does-not-work-in-schedule</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 02:26:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9528.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Jan 2019 17:05:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MONITORON on does not work in schedule on Tue, 29 Jan 2019 15:22:30 GMT]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/9528/monitoron-on-does-not-work-in-schedule">MONITORON on does not work in schedule</a></p>
<p dir="auto">So for the last two days, this has been working correctly.  I think it may be a combination of <a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> fix to my config, not messing with the pi for a full 2 days to let it fully run through it’s schedule, and removing openGL.</p>
]]></description><link>https://forum.magicmirror.builders/post/51076</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51076</guid><dc:creator><![CDATA[rts58]]></dc:creator><pubDate>Tue, 29 Jan 2019 15:22:30 GMT</pubDate></item><item><title><![CDATA[Reply to MONITORON on does not work in schedule on Fri, 18 Jan 2019 16:13:49 GMT]]></title><description><![CDATA[<p dir="auto">It still did not come on this morning :frowning_face: .  I just ran <code> tail -130 ~/.pm2/logs/mm-out.log</code> and found these results:</p>
<pre><code>MMM-ModuleScheduler is removing all scheduled jobs
MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
MMM-ModuleScheduler is scheduling REMOTE_ACTION using "30 9 * * *
MMM-ModuleScheduler has scheduled REMOTE_ACTION
MMM-ModuleScheduler will next send REMOTE_ACTION at Fri Jan 18 2019 09:30:00 GMT-0500 (EST)
MMM-ModuleScheduler is scheduling REMOTE_ACTION using "30 23 * * *
MMM-ModuleScheduler will next send REMOTE_ACTION at Thu Jan 17 2019 23:30:00 GMT-0500 (EST)
MMM-ModuleScheduler is scheduling REMOTE_ACTION using "0 2 * * SUN
MMM-ModuleScheduler will next send REMOTE_ACTION at Sun Jan 20 2019 02:00:00 GMT-0500 (EST)
MMM-ModuleScheduler received CREATE_GLOBAL_SCHEDULE
MMM-ModuleScheduler is creating a global schedule for all modules using "15 9 * * *" and "45 23 * * *" with dim level undefined
MMM-ModuleScheduler has created the global schedule for all modules
MMM-ModuleScheduler will next show all modules at Fri Jan 18 2019 09:15:00 GMT-0500 (EST)
MMM-ModuleScheduler will next hide all modules at Thu Jan 17 2019 23:45:00 GMT-0500 (EST)
<p dir="auto">Again later in the output I found:</p>
<pre><code>MMM-ModuleScheduler is sending SEND_NOTIFICATION to REMOTE_ACTION
MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Fri Jan 18 2019 23:30:00 GMT-0500 (EST) based on "30 23 * * *"
Powering off HDMI
MMM-ModuleScheduler is sending HIDE_MODULES to undefined
MMM-ModuleScheduler will next send HIDE_MODULES to undefined at Fri Jan 18 2019 23:45:00 GMT-0500 (EST) based on "45 23 * * *"
MMM-ModuleScheduler is sending SHOW_MODULES to undefined
MMM-ModuleScheduler will next send SHOW_MODULES to undefined at Sat Jan 19 2019 09:15:00 GMT-0500 (EST) based on "15 9 * * *"
MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Sat Jan 19 2019 09:30:00 GMT-0500 (EST) based on "30 9 * * *"
Powering on HDMI with preferred settings
<p dir="auto">So it looks like the schedule works and it is trying to turn the monitor on, it just didn’t work.  (Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> I don’t think the schedule was working before.) This morning when the monitor didn’t come on per the schedule, I used the remote web page, it came on fine.  How can I find out why the monitor did not come on with the schedule??</p>
]]></description><link>https://forum.magicmirror.builders/post/50368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50368</guid><dc:creator><![CDATA[rts58]]></dc:creator><pubDate>Fri, 18 Jan 2019 16:13:49 GMT</pubDate></item><item><title><![CDATA[Reply to MONITORON on does not work in schedule on Thu, 17 Jan 2019 18:59:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a>  Thanks, I did not have the “,” after the last “}” because it is the last module in the config.  I thought the extra “,” would cause a config error.  But it does not.  Hopeful for success in the morning!</p>
]]></description><link>https://forum.magicmirror.builders/post/50331</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50331</guid><dc:creator><![CDATA[rts58]]></dc:creator><pubDate>Thu, 17 Jan 2019 18:59:16 GMT</pubDate></item><item><title><![CDATA[Reply to MONITORON on does not work in schedule on Thu, 17 Jan 2019 18:30:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rts58" aria-label="Profile: rts58">@<bdi>rts58</bdi></a> so whole code should be</p>
                {notification:
                {notification:
                {notification:
]]></description><link>https://forum.magicmirror.builders/post/50326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50326</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Thu, 17 Jan 2019 18:30:14 GMT</pubDate></item><item><title><![CDATA[Reply to MONITORON on does not work in schedule on Thu, 17 Jan 2019 18:24:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rts58" aria-label="Profile: rts58">@<bdi>rts58</bdi></a> ok Looking at the read me it’s these at the end from my basic understanding</p>
<pre><code>]
]]></description><link>https://forum.magicmirror.builders/post/50325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50325</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Thu, 17 Jan 2019 18:24:08 GMT</pubDate></item></channel></rss>
