<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Optimal Mirror - Light Transmission]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am looking in different mirrors with different light transmissions. I was wondering if is there any standard % of the light transmission for the “optimum” smart mirror? Maybe people which they have opinion on this matter they can advice, post pictures and comment in order to create a kind of standard for the optimum solution.</p>
<p dir="auto">Cheers,</p>
<p dir="auto">Lee!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9532/optimal-mirror-light-transmission</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 04:39:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9532.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Jan 2019 09:56:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Optimal Mirror - Light Transmission on Fri, 18 Jan 2019 16:42:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdhenriksen" aria-label="Profile: mdhenriksen">@<bdi>mdhenriksen</bdi></a> all depends what you are after if the op has a weak back light display and is a bright room and also wants to play movies and so on then 50/50 for anything other than the above 70/30 would be fine and ok for watching videos</p>
]]></description><link>https://forum.magicmirror.builders/post/50370</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50370</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Fri, 18 Jan 2019 16:42:54 GMT</pubDate></item><item><title><![CDATA[Reply to Optimal Mirror - Light Transmission on Fri, 18 Jan 2019 16:10:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meobeou" aria-label="Profile: meobeou">@<bdi>meobeou</bdi></a> I’m not sure about the %. I’ve seen some say 50/50 is the best. You could also check the difference in <a href="https://forum.magicmirror.builders/topic/9518/window-foil-plastic-film-for-magicmirror">mirrors vs. foils here</a> - there is pictures and video about it :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/50367</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50367</guid><dc:creator><![CDATA[mdhenriksen]]></dc:creator><pubDate>Fri, 18 Jan 2019 16:10:53 GMT</pubDate></item><item><title><![CDATA[Reply to Optimal Mirror - Light Transmission on Fri, 18 Jan 2019 16:06:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meobeou" aria-label="Profile: meobeou">@<bdi>meobeou</bdi></a> - The smart mirror glass from <a href="http://www.twowaymirrors.com" target="_blank" rel="noopener noreferrer nofollow ugc">www.twowaymirrors.com</a> is 30% transparent and works really well.</p>
]]></description><link>https://forum.magicmirror.builders/post/50365</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50365</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 18 Jan 2019 16:06:50 GMT</pubDate></item></channel></rss>
