<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-google-route error "over query limit"]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">I always get an error “over query limit” at the module MMM-google-route after some hours of running the MM.<br />
If I restart it everything works fine again.</p>
<p dir="auto">I know it is a problem with google but I can’t find a solution.</p>
<p dir="auto">I use MMM-google-route with default settings.</p>
<p dir="auto">activated APIs:<br />
Directions API (if I disable it nothing works anymore)<br />
Geocoding API<br />
Maps JavaScript API</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/9550/mmm-google-route-error-over-query-limit</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 13:22:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9550.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Jan 2019 10:59:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-google-route error "over query limit" on Mon, 21 Jan 2019 12:54:41 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried adjust the refresh frequency to make it not query the API so often?</p>
]]></description><link>https://forum.magicmirror.builders/post/50527</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50527</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 21 Jan 2019 12:54:41 GMT</pubDate></item></channel></rss>
