<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror finally complete--PIR issue solved]]></title><description><![CDATA[<p dir="auto"><img src="https://lh3.googleusercontent.com/ZNUZWHBZ2hkVNLq6Cyke1FYrE-0rI2snqwA0G-IyPgg4oAQyzb2A-rSNyxishIddrVJ0R3dtk96VtOwxAR8rLGD0FU8t26b-XDZtyV6FrNfVl4esdgfEygz3VVjcN5WrEBkqKpsk=w2400" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">After working for some time, I finally eliminated the random PIR triggering by using doorbell wire wrapped in aluminum foil to extend the distance between the PIR and the Pi itself. I’m happy with the build. and would only change a couple of things. Next time, I will probably get the microwave motion sensors, and I’ll definitely use a real glass mirror as the acrylic mirror already has some minor scratches.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9558/magic-mirror-finally-complete-pir-issue-solved</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 16:59:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9558.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Jan 2019 23:17:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror finally complete--PIR issue solved on Mon, 21 Jan 2019 02:29:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> Thanks! I got the bend mostly fixed by adding supports that ran the length and width of the frame. It’s still nowhere near as perfect as glass would be. This was mainly a proof of concept, so I know what tweaks to make when it comes time to build another.</p>
]]></description><link>https://forum.magicmirror.builders/post/50493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50493</guid><dc:creator><![CDATA[uatuba]]></dc:creator><pubDate>Mon, 21 Jan 2019 02:29:03 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror finally complete--PIR issue solved on Mon, 21 Jan 2019 02:23:30 GMT]]></title><description><![CDATA[<p dir="auto">That’s a good looking mirror! The acrylic is showing just a slight amount of bend, but only just. I think you did quite well.</p>
]]></description><link>https://forum.magicmirror.builders/post/50490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50490</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 21 Jan 2019 02:23:30 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror finally complete--PIR issue solved on Mon, 21 Jan 2019 01:58:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uatuba" aria-label="Profile: uatuba">@<bdi>uatuba</bdi></a> said in <a href="/post/50485">Magic Mirror finally complete--PIR issue solved</a>:</p>
<p dir="auto">we will use a plant stand and plant of some kind to at least make it less noticeable.</p>
<p dir="auto">That’s what I meant by “hide or disguise”. I put a bookcase under this one and a toy bear to hide the little bit of power cord that was still exposed.</p>
<p dir="auto"><img src="/assets/uploads/files/1548035902979-hide.jpg" alt="0_1548035898892_hide.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/50487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50487</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 21 Jan 2019 01:58:37 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror finally complete--PIR issue solved on Mon, 21 Jan 2019 01:11:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a> I’m not sure that fully hiding the power cord in this instance is going to be possible. Location and the layout of what’s on the other side of the wall has kind of dictated the power cord dangling as it is, although we will use a plant stand and plant of some kind to at least make it less noticeable.</p>
]]></description><link>https://forum.magicmirror.builders/post/50485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50485</guid><dc:creator><![CDATA[uatuba]]></dc:creator><pubDate>Mon, 21 Jan 2019 01:11:57 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror finally complete--PIR issue solved on Mon, 21 Jan 2019 00:25:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uatuba" aria-label="Profile: uatuba">@<bdi>uatuba</bdi></a> said in <a href="/post/50480">Magic Mirror finally complete--PIR issue solved</a>:</p>
<p dir="auto">I finally eliminated the random PIR triggering by using doorbell wire wrapped in aluminum foil</p>
<p dir="auto">Nice, clean looking mirror. Lovely frame. (I’m partial to wood). I applaud your ingenuity in solving the PIR issue. Now, hide or disguise the power cord and you’ll be golden. :thumbup:</p>
]]></description><link>https://forum.magicmirror.builders/post/50481</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50481</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 21 Jan 2019 00:25:21 GMT</pubDate></item></channel></rss>
