<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A module like WB-Weather with support for other weather APIs such as BOM.]]></title><description><![CDATA[<p dir="auto">I recently saw the amazing weather plugin <a href="https://github.com/delightedCrow/WallberryTheme/tree/master/WB-weather" target="_blank" rel="noopener noreferrer nofollow ugc">WB-Weather</a> but its hard coded to use DarkSky I was wondering if anyone would be interested in adding support for other weather APIs such as <a href="http://www.bom.gov.au/" target="_blank" rel="noopener noreferrer nofollow ugc">BOM</a>?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/9562/a-module-like-wb-weather-with-support-for-other-weather-apis-such-as-bom</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 00:28:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9562.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Jan 2019 05:22:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A module like WB-Weather with support for other weather APIs such as BOM. on Sun, 15 May 2022 08:41:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Finally got the 7 day forecast showing with this modification from <a class="plugin-mentions-user plugin-mentions-a" href="/user/anobleperson" aria-label="Profile: anobleperson">@<bdi>anobleperson</bdi></a></p>
<p dir="auto"><a href="https://github.com/frebbles/MMM-bomweather/compare/main...anobleperson:bugfix/header-update" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/frebbles/MMM-bomweather/compare/main...anobleperson:bugfix/header-update</a></p>
]]></description><link>https://forum.magicmirror.builders/post/101847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101847</guid><dc:creator><![CDATA[Nalmo]]></dc:creator><pubDate>Sun, 15 May 2022 08:41:18 GMT</pubDate></item><item><title><![CDATA[Reply to A module like WB-Weather with support for other weather APIs such as BOM. on Sat, 30 Apr 2022 11:42:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nalmo" aria-label="Profile: Nalmo">@<bdi>Nalmo</bdi></a> sorry  I don’t know anything about the module itself.</p>
<p dir="auto">in the modulename.js  is a define for defaults:{}</p>
<p dir="auto">all of those are config options.  sometimes modules don’t list a config option for various reasons…</p>
<p dir="auto">so I look thru the code for .config. to find them<br />
and the node_helper.js too…</p>
]]></description><link>https://forum.magicmirror.builders/post/101560</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101560</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 30 Apr 2022 11:42:53 GMT</pubDate></item><item><title><![CDATA[Reply to A module like WB-Weather with support for other weather APIs such as BOM. on Sat, 30 Apr 2022 10:22:18 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1651314124529-3593260e-3d73-43aa-93be-48b0ed7b965f-image.png" alt="3593260e-3d73-43aa-93be-48b0ed7b965f-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/101559</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101559</guid><dc:creator><![CDATA[Nalmo]]></dc:creator><pubDate>Sat, 30 Apr 2022 10:22:18 GMT</pubDate></item><item><title><![CDATA[Reply to A module like WB-Weather with support for other weather APIs such as BOM. on Sat, 30 Apr 2022 08:14:27 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1651306456146-c7ace21e-cb65-4376-ad88-b15f9f1d9a56-image.png" alt="c7ace21e-cb65-4376-ad88-b15f9f1d9a56-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/101556</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101556</guid><dc:creator><![CDATA[Nalmo]]></dc:creator><pubDate>Sat, 30 Apr 2022 08:14:27 GMT</pubDate></item><item><title><![CDATA[Reply to A module like WB-Weather with support for other weather APIs such as BOM. on Sat, 30 Apr 2022 06:46:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks for a quick response.</p>
<p dir="auto">I have not configured any options for bomweather in config.js  other than location  and locationState</p>
<p dir="auto">The log  file shows it fetched the correct URL; next line says “BomForecast Forecast received”</p>
<p dir="auto">MM is showing the (correct)  location (“Melbourne”) with a line under it, but not the forecast.</p>
<p dir="auto">When I set radarImage to true, I get a small square under the line.</p>
<p dir="auto">Can you advise what the configuration options are for this module.  I have looked through the bomweather.js file but am not sure what the config options are (still a bit of a noob at this).<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/101555</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101555</guid><dc:creator><![CDATA[Nalmo]]></dc:creator><pubDate>Sat, 30 Apr 2022 06:46:59 GMT</pubDate></item><item><title><![CDATA[Reply to A module like WB-Weather with support for other weather APIs such as BOM. on Fri, 29 Apr 2022 13:46:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nalmo" aria-label="Profile: Nalmo">@<bdi>Nalmo</bdi></a> also, in the place u start MagicMirror, via npm start or pm2, there will be messages output by the modules node_helper (which gets the data)</p>
<p dir="auto">if using pm2, then the command</p>
<p dir="auto">pm2 logs --lines=50</p>
<p dir="auto">will output the last 50 lines of messages saved</p>
]]></description><link>https://forum.magicmirror.builders/post/101551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101551</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 29 Apr 2022 13:46:37 GMT</pubDate></item><item><title><![CDATA[Reply to A module like WB-Weather with support for other weather APIs such as BOM. on Fri, 29 Apr 2022 11:55:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nalmo" aria-label="Profile: Nalmo">@<bdi>Nalmo</bdi></a> if u look at the code, it’s looking for your state abbreviation, config option locationState</p>
<p dir="auto"><img src="/assets/uploads/files/1651233267567-screenshot_20220429-065334_chrome.jpg" alt="Screenshot_20220429-065334_Chrome.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/101550</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101550</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 29 Apr 2022 11:55:25 GMT</pubDate></item><item><title><![CDATA[Reply to A module like WB-Weather with support for other weather APIs such as BOM. on Fri, 29 Apr 2022 03:47:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uskompuf" aria-label="Profile: Uskompuf">@<bdi>Uskompuf</bdi></a></p>
<p dir="auto">I found this but am having trouble configuring it as documentation of options is missing.<br />
<a href="https://github.com/frebbles/MMM-bomweather" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/frebbles/MMM-bomweather</a></p>
<p dir="auto">All I get is  the location name with a line under it.<br />
Would appreciate any help.<br />
Alan</p>
]]></description><link>https://forum.magicmirror.builders/post/101544</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101544</guid><dc:creator><![CDATA[Nalmo]]></dc:creator><pubDate>Fri, 29 Apr 2022 03:47:08 GMT</pubDate></item></channel></rss>
