<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Controlling Magic Mirror from Alexa]]></title><description><![CDATA[<p dir="auto">Just wanted to share how I use Alexa to control the mirror.  I use Home Assistant together with Node Red. With the MMM remote module I can restart, hide or do whatever I want. I send the coammand via HTTP get from Node Red.</p>
<p dir="auto"><a href="https://www.youtube.com/watch?v=9szW-2Sy7-4!%5B0_1548058900483_mmmthumb.jpg%5D(/assets/uploads/files/1548058902880-mmmthumb.jpg)" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=9szW-2Sy7-4![0_1548058900483_mmmthumb.jpg](/assets/uploads/files/1548058902880-mmmthumb.jpg)</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/9564/controlling-magic-mirror-from-alexa</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 23:07:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9564.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Jan 2019 08:16:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Controlling Magic Mirror from Alexa on Mon, 01 Feb 2021 19:25:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jasondreher" aria-label="Profile: jasondreher">@<bdi>jasondreher</bdi></a> I understood that you used GA to send commands to the MM.<br />
So what do you use?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/88072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88072</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Mon, 01 Feb 2021 19:25:57 GMT</pubDate></item><item><title><![CDATA[Reply to Controlling Magic Mirror from Alexa on Sun, 31 Jan 2021 03:06:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: egnos">@<bdi>egnos</bdi></a><br />
I don’t know much about google home, you will have to read up or find out how to share Home Assistant <a href="https://www.home-assistant.io/integrations/google_assistant/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.home-assistant.io/integrations/google_assistant/</a> with google home. Once you can do that you can create a switch (like above) then turn the switch on and off.</p>
<p dir="auto">My suggestion would be…</p>
<ol>
<li>Grab that Raspberry Pi that is lying around and install Home Assistant.</li>
<li>Learn a little about HA and how it runs</li>
<li>Add <a href="https://www.home-assistant.io/integrations/google_assistant/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.home-assistant.io/integrations/google_assistant/</a></li>
<li>Create switch like above.</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/88016</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88016</guid><dc:creator><![CDATA[jasondreher]]></dc:creator><pubDate>Sun, 31 Jan 2021 03:06:53 GMT</pubDate></item><item><title><![CDATA[Reply to Controlling Magic Mirror from Alexa on Fri, 29 Jan 2021 22:02:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jasondreher" aria-label="Profile: jasondreher">@<bdi>jasondreher</bdi></a> said in <a href="/post/87832">Controlling Magic Mirror from Alexa</a>:</p>
<p dir="auto">I do the same thing without node red. Using the MMM-Remote-Control module.</p>
<p dir="auto">Here is the switch in HomeAssistant to turn on/off MMM-Snow</p>
<pre><code>    mmsnow:
      command_on: 'curl "http://192.168.0.163:8090/remote?action=SHOW&amp;module=module_0_MMM-Snow"'
      command_off: 'curl "http://192.168.0.163:8090/remote?action=HIDE&amp;module=module_0_MMM-Snow"'
<p dir="auto">Mine just turns on off based on the weather, but you could expose this to Alexa and tell her to turn it on and off.</p>
<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/jasondreher" aria-label="Profile: jasondreher">@<bdi>jasondreher</bdi></a> could you tell me the steps to give a command to MM using GoogleHome through MMM-Remote-Control?<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/87981</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87981</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Fri, 29 Jan 2021 22:02:36 GMT</pubDate></item><item><title><![CDATA[Reply to Controlling Magic Mirror from Alexa on Tue, 26 Jan 2021 13:38:43 GMT]]></title><description><![CDATA[<p dir="auto">I do the same thing without node red. Using the MMM-Remote-Control module.</p>
<pre><code>    mmsnow:
]]></description><link>https://forum.magicmirror.builders/post/87832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87832</guid><dc:creator><![CDATA[jasondreher]]></dc:creator><pubDate>Tue, 26 Jan 2021 13:38:43 GMT</pubDate></item><item><title><![CDATA[Reply to Controlling Magic Mirror from Alexa on Mon, 25 Jan 2021 22:19:29 GMT]]></title><description><![CDATA[<p dir="auto">Nice, very nice.<br />
Nice control with your Alexa integration but<br />
i am amazed before the bright and very realistic reflection of your mirror.<br />
I use a mirror Pilkington MirroView and the reflection is too dark, impossible for my wife to imagine using makeup before.<br />
Is it my room that is too dark or the black background behind the mirror not adapted, or just this mirror that is not a good choice ?</p>
<p dir="auto">Can you give us some information on the mirror you used ? Are the color like a random mirror ?<br />
Your integration in the wall is also very successful.<br />
Very good job.<br />
Just an observation, for me, your work on this mirror deserves a more beautiful frame ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/87808</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87808</guid><dc:creator><![CDATA[Graingalet]]></dc:creator><pubDate>Mon, 25 Jan 2021 22:19:29 GMT</pubDate></item><item><title><![CDATA[Reply to Controlling Magic Mirror from Alexa on Mon, 25 Jan 2021 11:14:31 GMT]]></title><description><![CDATA[<p dir="auto">Very nice!</p>
<p dir="auto">Can you tell More about your project?<br />
I want to build the same feature with Alexa. How do you implement this?</p>
]]></description><link>https://forum.magicmirror.builders/post/87783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87783</guid><dc:creator><![CDATA[matze86]]></dc:creator><pubDate>Mon, 25 Jan 2021 11:14:31 GMT</pubDate></item></channel></rss>
