<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[About to build for the first time, dont understand the point of the OS.]]></title><description><![CDATA[<p dir="auto">When I first starting seeing these projects, they all just pointed to a custom web page. I can imagine that not having to throw some HTML together and not having to host a web server is slightly advantageous. What is the true value of the OS? (Also, super stoked to find this group, subscribed) <a href="https://appsync.biz/speed-test/" target="_blank" rel="noopener noreferrer nofollow ugc">Speed Test</a> <a href="https://appsync.biz/scrabble-word-finder/" target="_blank" rel="noopener noreferrer nofollow ugc">Scrabble Word Finder</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/9580/about-to-build-for-the-first-time-dont-understand-the-point-of-the-os</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 11:34:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9580.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Jan 2019 05:42:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to About to build for the first time, dont understand the point of the OS. on Tue, 22 Jan 2019 17:56:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/seedhe" aria-label="Profile: seedhe">@<bdi>seedhe</bdi></a> - The module framework that <a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> created is where the technique of hosting the mirror on a Pi really shines. While the Magic Mirror is more-or-less a customizable web page, the ability for the modules to call background processes adds a level of utility.</p>
<p dir="auto">For example, I can put a static web page up on an Amazon cloud IP and just hit that from my mirror. It will display static data and maybe some things from various APIs, if I code it cleverly enough. But that’s about it.</p>
<p dir="auto">With the OS working behind the scenes, I can display anything behind my firewall (IP cameras, weather stations, temperature sensors, PIR sensors, etc.). I can also plug in a camera and/or microphone and use the data from those devices in my modules.</p>
<p dir="auto">It also allows you to scale up if you need to. A Raspi is pretty slick for its size and cost. But if you put something like a NUC behind it, you can use that processing power for some really cool features. Voice recognition, facial recognition, complex animations, etc.</p>
]]></description><link>https://forum.magicmirror.builders/post/50611</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50611</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 22 Jan 2019 17:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to About to build for the first time, dont understand the point of the OS. on Tue, 22 Jan 2019 10:23:19 GMT]]></title><description><![CDATA[<p dir="auto">As <a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> said: Freedom! You can do anything and you can use the OS itself for any further Raspbian things you would like. (A mirror as a jdownloader host? possible… Measuring temp in bath room directly using the mirror? possible…)<br />
There are so many possibilities…</p>
<p dir="auto">Also, you don’t necessarily have to throw any html or setup a web server. It’s all done automatically at the installation.<br />
Yes, if you want to go forward there’s a lot to learn, but I have contributed / played with a lot of modules already and not written more than 3 lines of html (albeit lots of JS)</p>
]]></description><link>https://forum.magicmirror.builders/post/50593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50593</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 22 Jan 2019 10:23:19 GMT</pubDate></item><item><title><![CDATA[Reply to About to build for the first time, dont understand the point of the OS. on Tue, 22 Jan 2019 09:32:54 GMT]]></title><description><![CDATA[<p dir="auto">Free? Open source?</p>
<p dir="auto">The fact that you can have a lot more background services then just with a regular webpage?</p>
<p dir="auto">Just the fact that you can easily connect the gpio of a pie to a MM2 module.</p>
]]></description><link>https://forum.magicmirror.builders/post/50589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50589</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 22 Jan 2019 09:32:54 GMT</pubDate></item></channel></rss>
