<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alert of Notification sounds - how to disable?]]></title><description><![CDATA[<p dir="auto">Hi All - I recently enabled audio on my mirror in order to get the MMM-Hotword and MMM-AssistantMk2 to work. However, I now hear random (notification, alert?) sounds at times. I can’t pinpoint what is causing this, or which module is sending the alert. Is anyone familiar with this system behaviour? I won’t be able to mute the mirror unfortunately, as that will result in the Assistant module not working.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9589/alert-of-notification-sounds-how-to-disable</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 19:42:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9589.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Jan 2019 01:34:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alert of Notification sounds - how to disable? on Fri, 25 Jan 2019 14:18:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> Thanks - I did not. The mirror was working fine, and no notifications were visible on the screen. I’ll investigate further whether these sounds could be generated by Raspbian OS.</p>
]]></description><link>https://forum.magicmirror.builders/post/50809</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50809</guid><dc:creator><![CDATA[kasperb]]></dc:creator><pubDate>Fri, 25 Jan 2019 14:18:23 GMT</pubDate></item><item><title><![CDATA[Reply to Alert of Notification sounds - how to disable? on Wed, 23 Jan 2019 02:11:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kasperb" aria-label="Profile: kasperb">@<bdi>kasperb</bdi></a> might it be something with the Raspbian operating system? A brief network outage may produce a notification noise when it automatically reconnects, for example. I’m not certain of the Raspbian default settings, but it may be worth looking into.</p>
<p dir="auto">Do you see anything amiss on the mirror when you hear the notifications?</p>
]]></description><link>https://forum.magicmirror.builders/post/50635</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50635</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 23 Jan 2019 02:11:47 GMT</pubDate></item></channel></rss>
