<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can someone Make a module to show iTunes playing]]></title><description><![CDATA[<p dir="auto">Is it possible that some bright spark ⚡️ can make a module similar to the Spotify now playing, so you could see what was playing on iTunes?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9613/can-someone-make-a-module-to-show-itunes-playing</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 18:54:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9613.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 26 Jan 2019 15:11:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can someone Make a module to show iTunes playing on Sun, 27 Jan 2019 19:09:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ganget" aria-label="Profile: ganget">@<bdi>ganget</bdi></a> yep checked it out nope doesn’t do that. The main idea was to hook it to my account so when I AirPlayed stuff it ie music it would show up, but guess I’ll have to look at something other than MM for that bit</p>
]]></description><link>https://forum.magicmirror.builders/post/50939</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50939</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Sun, 27 Jan 2019 19:09:15 GMT</pubDate></item><item><title><![CDATA[Reply to Can someone Make a module to show iTunes playing on Sun, 27 Jan 2019 17:43:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> You should check out the <a href="http://last.fm" target="_blank" rel="noopener noreferrer nofollow ugc">last.fm</a> site for that and google ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/50928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50928</guid><dc:creator><![CDATA[ganget]]></dc:creator><pubDate>Sun, 27 Jan 2019 17:43:37 GMT</pubDate></item><item><title><![CDATA[Reply to Can someone Make a module to show iTunes playing on Sun, 27 Jan 2019 01:32:03 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/ganget" aria-label="Profile: ganget">@<bdi>ganget</bdi></a> how does it connect to LastFm? Does this display iTunes music that play from iCloud too?</p>
]]></description><link>https://forum.magicmirror.builders/post/50885</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50885</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Sun, 27 Jan 2019 01:32:03 GMT</pubDate></item><item><title><![CDATA[Reply to Can someone Make a module to show iTunes playing on Sat, 26 Jan 2019 21:45:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> <a href="https://forum.magicmirror.builders/topic/43/mmm-scrobbler-last-fm-music-scrobbler">MMM-Scrobbler</a> would do that if you connect your iTunes to <a href="http://last.fm" target="_blank" rel="noopener noreferrer nofollow ugc">last.fm</a></p>
]]></description><link>https://forum.magicmirror.builders/post/50880</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50880</guid><dc:creator><![CDATA[ganget]]></dc:creator><pubDate>Sat, 26 Jan 2019 21:45:51 GMT</pubDate></item></channel></rss>
