<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspberry Pi 3&#x2F;Zero eInk (epaper) MagicMirror]]></title><description><![CDATA[<p dir="auto">[card:benroe/rpi-magicmirror-eink]</p>
<p dir="auto">Hi,<br />
i created a node.js script to display a MagicMirror site on a 7.5 eInk Display.<br />
You can find the script on <a href="https://github.com/BenRoe/rpi-magicmirror-eink" target="_blank" rel="noopener noreferrer nofollow ugc">github</a> with a minimal install instruction.</p>
<p dir="auto">A detailed german tutorial can you find on my blog.<br />
<a href="https://maker-tutorials.com/7-5-eink-epaper-bilderrahmen-magicmirror-display-raspberry-pi-zero-w/" target="_blank" rel="noopener noreferrer nofollow ugc">https://maker-tutorials.com/7-5-eink-epaper-bilderrahmen-magicmirror-display-raspberry-pi-zero-w/</a></p>
<p dir="auto">If you are interested to help, i have some open task.</p>
<ul>
<li>translate detailed german tutorial to english</li>
<li>for every MMM a custom css is needed</li>
<li>support more display sizes (4.2 / 5.83 / 9.7)</li>
</ul>
<p dir="auto"><img src="https://github.com/BenRoe/rpi-magicmirror-eink/raw/master/screenshot.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/9617/raspberry-pi-3-zero-eink-epaper-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 07:36:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9617.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 26 Jan 2019 19:12:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Raspberry Pi 3&#x2F;Zero eInk (epaper) MagicMirror on Thu, 08 Apr 2021 01:33:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/akrlfix" aria-label="Profile: akrlfix">@<bdi>akrlfix</bdi></a> hi. Can you share your script that updates screen? Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/90412</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90412</guid><dc:creator><![CDATA[uros76]]></dc:creator><pubDate>Thu, 08 Apr 2021 01:33:28 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi 3&#x2F;Zero eInk (epaper) MagicMirror on Sat, 23 Jan 2021 12:18:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
ich habe eine andere (bessere) Lösung gefunden mit Hilfe von Xvfb. Mit Xvfb wird eine virtuelle X11 session gestartet und MM darauf angezeigt. Dann wird ein Screenshot vom framebuffer gemacht und auf dem ePaper angezeigt.</p>
<pre><code># Create Virtual MagicMirror Display
sudo apt update
sudo apt install xvfb
Xvfb :1 -screen 0 800x480x24 -fbdir /home/pi &amp;
cd /home/pi/MagicMirror
DISPLAY=:1 nohup npm start &amp;
# Create Screenshot
cat /home/pi/Xvfb_screen0 | convert xwd:- bmp:/home/pi/screenshot.bmp
# Run Python Script to update ePaper Display
python3 /home/pi/Workspace/ePaper/epd_7in5_V2_test.py
]]></description><link>https://forum.magicmirror.builders/post/87679</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87679</guid><dc:creator><![CDATA[akrlfix]]></dc:creator><pubDate>Sat, 23 Jan 2021 12:18:57 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi 3&#x2F;Zero eInk (epaper) MagicMirror on Sun, 10 Jan 2021 12:48:01 GMT]]></title><description><![CDATA[<p dir="auto">Hallo BenRoe,</p>
<p dir="auto">ich habe das Projekt bei mir einmal ausprobiert, da ich es sehr spannend finde.<br />
Im Prinzip funktioniert es auch, aber der Raspi W hängt sich sehr schnell auf.<br />
Chromium startet viele Instanzen und dadurch hängt sich der PI auf. Meistens funktioniert somit nur ein Durchlauf je Neustart.</p>
<p dir="auto">Hat jemand eine Idee woran dies liegen kann? Die MagicMirror Installation liegt schon auf einem anderen Pi (bzw. es wird nur eine Website von einem Rapsi 4 mit iobroker VIS aufgerufen), aber das solle ja nicht das Problem darstellen.</p>
]]></description><link>https://forum.magicmirror.builders/post/87003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87003</guid><dc:creator><![CDATA[nick21]]></dc:creator><pubDate>Sun, 10 Jan 2021 12:48:01 GMT</pubDate></item></channel></rss>
