<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stuck at Unable to install dependencies!]]></title><description><![CDATA[<p dir="auto">So this is my first time working with a R Pi, or even any programming really. I got the Raspberry Pi 3 B+ and a 32gb micro sd card so I could finally build a smart mirror.<br />
I’ve been following the EASY SMART MIRROR SETUP video by Grensom on Youtube.</p>
<p dir="auto">But when I try to install Magic Mirror, it gets stuck at this line.<br />
<img src="https://imgur.com/a/1ZCbOwO" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any help would be very much appreciated. Also as I mentioned, I really have little clue what I’m doing so please talk to me like I’m an idiot who called up technical support haha.</p>
<p dir="auto">TIA</p>
]]></description><link>https://forum.magicmirror.builders/topic/9636/stuck-at-unable-to-install-dependencies</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 18:24:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9636.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Jan 2019 04:19:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 23:31:24 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the much needed help, ive been reading everything possible to get things going.</p>
]]></description><link>https://forum.magicmirror.builders/post/51051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51051</guid><dc:creator><![CDATA[fulmik]]></dc:creator><pubDate>Mon, 28 Jan 2019 23:31:24 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 16:20:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> IT WORKED!!! Thank you so much for all your guidance! I found so many people online stuck with same issue, so I’ll link this topic page so everyone else can benefit from your genius too!</p>
]]></description><link>https://forum.magicmirror.builders/post/51009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51009</guid><dc:creator><![CDATA[DæmonEyes]]></dc:creator><pubDate>Mon, 28 Jan 2019 16:20:10 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 16:12:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/d%C3%A6moneyes" aria-label="Profile: dæmoneyes">@<bdi>dæmoneyes</bdi></a>  looks good (node/npm)… let us know how it goes</p>
]]></description><link>https://forum.magicmirror.builders/post/51007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51007</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Jan 2019 16:12:24 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 16:08:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> node v8.15.0<br />
npm v6.4.1</p>
<p dir="auto">Ok going to try to erase MM with your script now! Thank you so much for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/51006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51006</guid><dc:creator><![CDATA[DæmonEyes]]></dc:creator><pubDate>Mon, 28 Jan 2019 16:08:36 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 16:06:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/d%C3%A6moneyes" aria-label="Profile: dæmoneyes">@<bdi>dæmoneyes</bdi></a>  yes… best to  erase the MM folder and start again</p>
<pre><code>cd ~
rm -rf MagicMirror
<p dir="auto">then run the install script again</p>
<p dir="auto">what versions of node and npm were installed</p>
<pre><code>node -v
<p dir="auto">and</p>
<pre><code>npm -v
]]></description><link>https://forum.magicmirror.builders/post/51005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51005</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Jan 2019 16:06:25 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 16:02:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks! I’ve installed nodejs and npm according to that.<br />
Now do I try installing MagicMirror with that curl script again?</p>
]]></description><link>https://forum.magicmirror.builders/post/51004</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51004</guid><dc:creator><![CDATA[DæmonEyes]]></dc:creator><pubDate>Mon, 28 Jan 2019 16:02:20 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 14:13:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/d%C3%A6moneyes" aria-label="Profile: dæmoneyes">@<bdi>dæmoneyes</bdi></a> said in <a href="/post/50998">Stuck at Unable to install dependencies!</a>:</p>
<p dir="auto">fresh rasbian stretch</p>
<p dir="auto">yes, stretch doesn’t install npm or node, which are required…</p>
<p dir="auto">follow this<br />
<a href="https://linuxhint.com/install_npm_debian/" target="_blank" rel="noopener noreferrer nofollow ugc">https://linuxhint.com/install_npm_debian/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/51001</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51001</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Jan 2019 14:13:20 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 13:41:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Well on a fresh rasbian stretch R Pi 3 B+, I typed this in the terminal:<br />
curl -sL <a href="https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh</a> | bash</p>
<p dir="auto">And then it runs that install until the line<br />
“unable to install dependencies!”</p>
<p dir="auto">Hmmm I’m not sure if you can see the pic I uploaded in my post (it’s not showing up when i look at my post), but it right click in the blank spot on my original post, below the word ‘But’ and above the word ‘Any’ you can open the image in a new tab to see everything I did and where I get stuck</p>
]]></description><link>https://forum.magicmirror.builders/post/50998</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50998</guid><dc:creator><![CDATA[DæmonEyes]]></dc:creator><pubDate>Mon, 28 Jan 2019 13:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 13:05:41 GMT]]></title><description><![CDATA[<p dir="auto">How are you installing?  Manually?  Using the install script?</p>
]]></description><link>https://forum.magicmirror.builders/post/50997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50997</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 28 Jan 2019 13:05:41 GMT</pubDate></item><item><title><![CDATA[Reply to Stuck at Unable to install dependencies! on Mon, 28 Jan 2019 15:44:20 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://i.imgur.com/XYRlRLL.jpg?1" alt="Here is a pic of the terminal screen" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/50988</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50988</guid><dc:creator><![CDATA[DæmonEyes]]></dc:creator><pubDate>Mon, 28 Jan 2019 15:44:20 GMT</pubDate></item></channel></rss>
