<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CANNOT ADD MODULES]]></title><description><![CDATA[<p dir="auto">For the mother fucking life of me, I have been working on this for 8 hours now trying to upload different modules. Every time I do, it either doesn’t show up on the screen or says I need to a config, which I already have.</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 12,
	units: "metric",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "US Holidays",
						symbol: "calendar-check",
						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
			module: "compliments",
			position: "lower_third"
  			  module: 'MMM-lyft',
   			 position: 'top_left',
			   header: 'Lyft (DC)',
        lat: 47.3025085,  // use your exact pickup loaction
        lng: -122.3361409, // use your exact pickup loaction
        clientId: '&lt;_n-YCNuBuJRV&gt;',
        clientSecret: '&lt;Wcoq_0QSQFcinV8Al_aKjfMB4dAz9oQJ&gt;',
        module: 'MMM-NOAA3',
		    provider: "accuweather", // From list above
		    apiKey: "GFT6iF5ELpZ7pBYxzWabkEDAd8ZrK1HD",        // From one of the providers listed above
		    airKey: "AyY8mD8jWGvFrgBv8",
	        css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
		userlat: "47.302604", //MUST HAVE BOTH
	        userlon: "-122.33621"  //MUST HAVE BOTH
		zip: "98023"
]]></description><link>https://forum.magicmirror.builders/topic/9712/cannot-add-modules</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 17:15:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9712.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Feb 2019 10:35:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 21:56:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">For beginners, the catchphrase is “JSON syntax”.<br />
There are many articles to be found, both short and lengthy.<br />
A small article would be:<br />
<a href="https://restfulapi.net/json-syntax/" target="_blank" rel="noopener noreferrer nofollow ugc">https://restfulapi.net/json-syntax/</a></p>
<p dir="auto">The main things to look for in your config.js file are:</p>
<ul>
<li>does every [ have a matching ]</li>
<li>are all arrays separated by a , (the last array does not need a ,)</li>
<li>does every { have a matching }</li>
<li>are all objects separated by a , (the last object does not need a ,)</li>
<li>is every name value pair separated by a ,</li>
</ul>
<p dir="auto">The syntax checker will try to find out if this syntax is correct and tries to predict where the error could be.<br />
So, when it says it saw a [ and it cannot find a matching ] it tells you what was expected and what it saw.</p>
<p dir="auto">Try to format you config.js to make it more visible.<br />
For example this:</p>
<pre><code>[{},{}],[{},{[]}]
<p dir="auto">is better written like this:</p>
<pre><code>[
<p dir="auto">Pairs of [ ]and { } are better visible like this.</p>
<p dir="auto">Good luck :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/51718</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51718</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Wed, 06 Feb 2019 21:56:01 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 21:05:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anhanyoung" aria-label="Profile: anhanyoung">@<bdi>anhanyoung</bdi></a> means u are missing comma, " or something…  confused the parser…</p>
]]></description><link>https://forum.magicmirror.builders/post/51716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51716</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Feb 2019 21:05:49 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 20:57:48 GMT]]></title><description><![CDATA[<p dir="auto">What does Expected ‘]’ to match ‘[’ from line 45 and instead saw ‘:’.<br />
75	Expected ‘}’ to match ‘{’ from line 28 and instead saw 'MMM-lyft mean?</p>
]]></description><link>https://forum.magicmirror.builders/post/51715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51715</guid><dc:creator><![CDATA[anhanyoung]]></dc:creator><pubDate>Wed, 06 Feb 2019 20:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 17:10:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a></p>
<p dir="auto">Thank you. I have been using your tutorials all night. It has helped me get to where I am. I tried folllowing these steps for different modules and it didn’t seem to work for me</p>
]]></description><link>https://forum.magicmirror.builders/post/51694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51694</guid><dc:creator><![CDATA[anhanyoung]]></dc:creator><pubDate>Wed, 06 Feb 2019 17:10:07 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 16:42:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anhanyoung" aria-label="Profile: anhanyoung">@<bdi>anhanyoung</bdi></a> said in <a href="/post/51686">CANNOT ADD MODULES</a>:</p>
<p dir="auto">when I change it in the config, do I have to change it in the module folder as well? Adding more compliments and such?</p>
<p dir="auto">No, you only need to change it in the config.js, or in the external json. The module file contains default values that will be overwritten by the values in the config.js or external files (e.g. for compliments)</p>
]]></description><link>https://forum.magicmirror.builders/post/51689</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51689</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 06 Feb 2019 16:42:21 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 16:40:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anhanyoung" aria-label="Profile: anhanyoung">@<bdi>anhanyoung</bdi></a> Every module is designed in a way that you don’t have to mess with the module files (MMM-*.js, node_helper.js) themselves.<br />
Otherwise, if you’re not common with git, you will run into problems as soon as you want/need to update the module.<br />
So always try to use config/config.js, css/customs.css or external files for tpurposes like these. In most caeses it’s described in the Readme of the config or here in the forum.</p>
]]></description><link>https://forum.magicmirror.builders/post/51688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51688</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 06 Feb 2019 16:40:57 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 16:28:22 GMT]]></title><description><![CDATA[<p dir="auto">Thank you guys! I will try using those sites. Didn’t know they existed. Oh man. Would that be a help. Another question, for d ample, the compliments and weather module, when I change it in the config, do I have to change it in the module folder as well? Adding more compliments and such?</p>
]]></description><link>https://forum.magicmirror.builders/post/51686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51686</guid><dc:creator><![CDATA[anhanyoung]]></dc:creator><pubDate>Wed, 06 Feb 2019 16:28:22 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 15:38:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> said in <a href="/post/51674">CANNOT ADD MODULES</a>:</p>
<p dir="auto">I prefer <a href="http://jshint.com" target="_blank" rel="noopener noreferrer nofollow ugc">jshint.com</a></p>
<p dir="auto">This really is way better! Great! Doesn’t complain about tabs for indentation which is annoying with the other tool.</p>
]]></description><link>https://forum.magicmirror.builders/post/51676</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51676</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 06 Feb 2019 15:38:59 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 14:36:53 GMT]]></title><description><![CDATA[<p dir="auto">I prefer <a href="http://jshint.com" target="_blank" rel="noopener noreferrer nofollow ugc">jshint.com</a><br />
In this case you missed a single comma in line <code>userlon</code>, so it should be:</p>
<pre><code>		userlat: "47.302604", //MUST HAVE BOTH
	        userlon: "-122.33621",  //MUST HAVE BOTH
		zip: "98023"
]]></description><link>https://forum.magicmirror.builders/post/51674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51674</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Wed, 06 Feb 2019 14:36:53 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 11:55:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anhanyoung" aria-label="Profile: anhanyoung">@<bdi>anhanyoung</bdi></a></p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners">https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners</a></p>
]]></description><link>https://forum.magicmirror.builders/post/51666</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51666</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 06 Feb 2019 11:55:22 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 11:53:18 GMT]]></title><description><![CDATA[<p dir="auto">and your indentation is messed up making it more difficult to find errors.<br />
You may have too much curled brackets.</p>
]]></description><link>https://forum.magicmirror.builders/post/51663</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51663</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 06 Feb 2019 11:53:18 GMT</pubDate></item><item><title><![CDATA[Reply to CANNOT ADD MODULES on Wed, 06 Feb 2019 11:51:19 GMT]]></title><description><![CDATA[<p dir="auto">Try finding errors with</p>
<pre><code>npm run config:check
<p dir="auto">to find errors in the config.</p>
<p dir="auto">You can also use online tools like <a href="http://jslint.com" target="_blank" rel="noopener noreferrer nofollow ugc">jslint.com</a> (past your code  there)</p>
<p dir="auto">You need to remove commas in line 19 and 54<br />
and need to add one in line 59.</p>
<p dir="auto">…and maybe even more.</p>
]]></description><link>https://forum.magicmirror.builders/post/51662</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51662</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 06 Feb 2019 11:51:19 GMT</pubDate></item></channel></rss>
