<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotating Module in Fullscreen (100%)]]></title><description><![CDATA[<p dir="auto">Hi All,<br />
I am using the module carousel and I would like to show each rotating module (for example, MMM-MyCalendar) in fullscreen (100%).<br />
I tried modifying the custom.css to define a custom region, without success.<br />
Could you please suggest me how to achieve this?<br />
Thank you in advance.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9753/rotating-module-in-fullscreen-100</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 18:26:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9753.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Feb 2019 22:21:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotating Module in Fullscreen (100%) on Mon, 11 Feb 2019 00:20:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/userloris" aria-label="Profile: userloris">@<bdi>userloris</bdi></a></p>
<p dir="auto">You might try changing the config position of each module to fullscreen_above, as such:<br />
<code>position: 'fullscreen_above',</code></p>
<p dir="auto">I don’t know how each module will react to such a setting. You might see some odd formatting in the display of modules that were not designed/intended to be displayed this way.</p>
]]></description><link>https://forum.magicmirror.builders/post/52051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52051</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 11 Feb 2019 00:20:39 GMT</pubDate></item></channel></rss>
