<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR-Sensor brightness]]></title><description><![CDATA[<p dir="auto">I installed Pir sensor module and not everything is going well. The on/off of screen works well but my problem is when i walk in front of my mirror, the brightness is very low and little by little continues to rise slowly and i don’t know why this happen.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9754/mmm-pir-sensor-brightness</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:16:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9754.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Feb 2019 22:39:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-PIR-Sensor brightness on Tue, 12 Feb 2019 00:08:06 GMT]]></title><description><![CDATA[<p dir="auto">if I don’t have the sensor activated, the brightness goes perfectly. But if it is activated and I leave a few minutes without passing in front of it, when passing has a fairly low brightness, it takes a few long seconds to regain the brightness. In a beginning I opened this thread to know if the module towards something with the brightness etc.<br />
But it looks like it belongs to my (old) screen, I’ll try it on a newer screen.<br />
Thanks you</p>
]]></description><link>https://forum.magicmirror.builders/post/52150</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52150</guid><dc:creator><![CDATA[Quesada]]></dc:creator><pubDate>Tue, 12 Feb 2019 00:08:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor brightness on Mon, 11 Feb 2019 11:14:09 GMT]]></title><description><![CDATA[<p dir="auto">There are some monitors (TV mainly) which have automatic control of the brightness (based on a sensor). Maybe it’s that.<br />
Was it present before PIR instalation Y/N? this can guide you.</p>
<p dir="auto">From MHO, PIR sensor has Nothing to do with that (but not 100% Sure).</p>
<p dir="auto">Regards</p>
]]></description><link>https://forum.magicmirror.builders/post/52077</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52077</guid><dc:creator><![CDATA[bolish]]></dc:creator><pubDate>Mon, 11 Feb 2019 11:14:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor brightness on Mon, 11 Feb 2019 09:58:01 GMT]]></title><description><![CDATA[<p dir="auto">that’s sounding like you monitor is going bad, honestly.</p>
<p dir="auto">PIR-Sensor just turns on and off your monitor… The rest sounds like a failing backlight.</p>
]]></description><link>https://forum.magicmirror.builders/post/52071</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52071</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 11 Feb 2019 09:58:01 GMT</pubDate></item></channel></rss>
