<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Glossy or Non-Glossy Display]]></title><description><![CDATA[<p dir="auto">I will try my best to write in understandable english :)</p>
<p dir="auto">Hey guys.<br />
Saw the project, ordered some parts and now i have a Mirropane 4mm and notebook display non-glossy in use.<br />
I’m not satisfied with the result. I can see the Display shining throw the glas.</p>
<p dir="auto">So i’ve read a little bit about displays. Some are sayin that glossy Displays are better, cause of the better contrast and other say that non-glossy Displays are better. But why?<br />
Coult somebody explain it to me what ist the better choice?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9768/glossy-or-non-glossy-display</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 10:28:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9768.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Feb 2019 20:51:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Sun, 17 Feb 2019 15:23:57 GMT]]></title><description><![CDATA[<p dir="auto">To end this. I tried both, you dont really see any different.</p>
]]></description><link>https://forum.magicmirror.builders/post/52547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52547</guid><dc:creator><![CDATA[thedk]]></dc:creator><pubDate>Sun, 17 Feb 2019 15:23:57 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Fri, 15 Feb 2019 11:06:39 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for tbe advice. Didnt know this till now.</p>
]]></description><link>https://forum.magicmirror.builders/post/52412</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52412</guid><dc:creator><![CDATA[thedk]]></dc:creator><pubDate>Fri, 15 Feb 2019 11:06:39 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Fri, 15 Feb 2019 10:43:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedk" aria-label="Profile: thedk">@<bdi>thedk</bdi></a> said in <a href="/post/52405">Glossy or Non-Glossy Display</a>:</p>
<p dir="auto">The Mirastar is way darker, looks like you cant see everything when i have the light on. But you can see everything and, very imporant for me, you cant see the Display anymore.</p>
<p dir="auto">In case you haven’t and for completeness: Keep in mind as well that the css colors are set to quite dark greys, so additionally to mirror transmission, monitor brightness, you can as well maipulate the brightness of the texts using css.<br />
I have the feeling that lots of people don’t think abou that.</p>
]]></description><link>https://forum.magicmirror.builders/post/52410</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52410</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 15 Feb 2019 10:43:44 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Fri, 15 Feb 2019 10:40:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedk" aria-label="Profile: thedk">@<bdi>thedk</bdi></a> I have a Mirastar from Brigla as well. And they are indeed the cheapest. I found it a bit too dark and too brownish/yellowish. But the mirror is in a small room without natural lighting. That may be my problem.<br />
Now trying out the Mirropane Chromespy 4mm in a better lit  room.</p>
]]></description><link>https://forum.magicmirror.builders/post/52409</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52409</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 15 Feb 2019 10:40:45 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Fri, 15 Feb 2019 08:54:53 GMT]]></title><description><![CDATA[<p dir="auto">Bought at <a href="http://Brigla-shop.de" target="_blank" rel="noopener noreferrer nofollow ugc">Brigla-shop.de</a>. Cheapest shop i found.<br />
Both are 4mm glas. The Mirastar is way darker, looks like you cant see everything when i have the light on. But you can see everything and, very imporant for me, you cant see the Display anymore.</p>
]]></description><link>https://forum.magicmirror.builders/post/52405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52405</guid><dc:creator><![CDATA[thedk]]></dc:creator><pubDate>Fri, 15 Feb 2019 08:54:53 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Fri, 15 Feb 2019 07:54:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedk" aria-label="Profile: thedk">@<bdi>thedk</bdi></a> So what’s your conclusion?<br />
It’s difficult to really see the difference from the pictures.<br />
And what types of Mirastar and Mirropane have you chosen and where have you bought them (I’m from germany as well)</p>
]]></description><link>https://forum.magicmirror.builders/post/52398</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52398</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 15 Feb 2019 07:54:33 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Thu, 14 Feb 2019 21:08:51 GMT]]></title><description><![CDATA[<p dir="auto">Uploaded again. A lil bit big, but have a look.</p>
]]></description><link>https://forum.magicmirror.builders/post/52376</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52376</guid><dc:creator><![CDATA[thedk]]></dc:creator><pubDate>Thu, 14 Feb 2019 21:08:51 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Thu, 14 Feb 2019 20:56:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedk" aria-label="Profile: thedk">@<bdi>thedk</bdi></a> said in <a href="/post/52364">Glossy or Non-Glossy Display</a>:</p>
<p dir="auto">Picture Upload doesnt work</p>
<p dir="auto">This happens to me if the picture is too high in resolution.  Try making it smaller maybe</p>
]]></description><link>https://forum.magicmirror.builders/post/52375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52375</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Thu, 14 Feb 2019 20:56:42 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Thu, 14 Feb 2019 21:08:12 GMT]]></title><description><![CDATA[<p dir="auto">Today the MIRASTAR glas came.<br />
Had a look again at the Display. Its a glossy one. Always thought its a non glossy. Maybe i will change this.</p>
<p dir="auto">Here ist the different between the glas:</p>
<p dir="auto">MIRROPANE<br />
<img src="/assets/uploads/files/1550178363109-20190213_135052_easy-resize.com.jpg" alt="0_1550178361831_20190213_135052_Easy-Resize.com.jpg" class="img-markdown  img-fluid" /><br />
Without light<br />
<img src="/assets/uploads/files/1550178343434-20190213_135100_easy-resize.com.jpg" alt="0_1550178341411_20190213_135100_Easy-Resize.com.jpg" class="img-markdown  img-fluid" /></p>
<p dir="auto">MIRASTAR<br />
<img src="/assets/uploads/files/1550178386390-20190214_150114_easy-resize.com.jpg" alt="0_1550178384715_20190214_150114_Easy-Resize.com.jpg" class="img-markdown  img-fluid" /><br />
Without light<br />
<img src="/assets/uploads/files/1550178406425-20190214_150125_easy-resize.com.jpg" alt="0_1550178404825_20190214_150125_Easy-Resize.com.jpg" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/post/52364</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52364</guid><dc:creator><![CDATA[thedk]]></dc:creator><pubDate>Thu, 14 Feb 2019 21:08:12 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Wed, 13 Feb 2019 08:47:24 GMT]]></title><description><![CDATA[<p dir="auto">Yes. I made a black Frame between the display and the frame of the mirror.<br />
I’ll post a picture later.</p>
]]></description><link>https://forum.magicmirror.builders/post/52277</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52277</guid><dc:creator><![CDATA[thedk]]></dc:creator><pubDate>Wed, 13 Feb 2019 08:47:24 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Wed, 13 Feb 2019 07:59:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedk" aria-label="Profile: thedk">@<bdi>thedk</bdi></a> It’s also very important to have no light coming to the glass from behind. However your setup is, make sure that it is as dark as possible behind the glass.</p>
]]></description><link>https://forum.magicmirror.builders/post/52271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52271</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 13 Feb 2019 07:59:18 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Wed, 13 Feb 2019 06:37:59 GMT]]></title><description><![CDATA[<p dir="auto">I allready did.<br />
I have only 40x30 Mirror. So the glas isnt that expensive and the first display was a gift. Till now, the Mirror wasnt that expensive ^^</p>
]]></description><link>https://forum.magicmirror.builders/post/52267</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52267</guid><dc:creator><![CDATA[thedk]]></dc:creator><pubDate>Wed, 13 Feb 2019 06:37:59 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Wed, 13 Feb 2019 04:16:21 GMT]]></title><description><![CDATA[<p dir="auto">Before you get too wrapped up in switching displays or glass, be sure to lower the brightness on your display and up the contrast. That should lower the amount of background illumination but make the content pop out a bit.</p>
]]></description><link>https://forum.magicmirror.builders/post/52260</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52260</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 13 Feb 2019 04:16:21 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Tue, 12 Feb 2019 20:29:21 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your answer.<br />
Yes, the brightness is the issue. As i could see the non-glossy Displays are brighter. Maybe with the glossy Displays i would have less ghosting, but then the mirror would be darker.<br />
After everything i read, i decided to try an other glas, the Mirastar with just 3% transmission. So i wont change the Display now.<br />
I will post photos when its here.</p>
]]></description><link>https://forum.magicmirror.builders/post/52211</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52211</guid><dc:creator><![CDATA[thedk]]></dc:creator><pubDate>Tue, 12 Feb 2019 20:29:21 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Tue, 12 Feb 2019 17:56:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedk" aria-label="Profile: thedk">@<bdi>thedk</bdi></a> I’m not sure that glossy vs non-glossy makes the biggest difference.  In fact, I would expect the glossy display to introduce some ghosting due to the second reflective surface behind the mirror.  My guess is that glossy displays tend to be on higher end machines and therefore tend to be brighter and more contrasty as a result to go along with the premium nature of the machine.  But I’m sure you could find very high quality displays in a non-glossy finish as well.  Brightness would be the biggest factor here, since the two-way glass steals some brightness in order to still offer a reflection.</p>
<p dir="auto">I used to work with a professional Eizo monitor for graphic design work that was capable of getting extremely bright, but it also had a non-reflective surface to eliminate any glare.  I would expect that monitor would have performed excellently behind a two-way mirror.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedk" aria-label="Profile: thedk">@<bdi>thedk</bdi></a> said in <a href="/post/52139">Glossy or Non-Glossy Display</a>:</p>
<p dir="auto">I can see the Display shining throw the glas.</p>
<p dir="auto">I take this to mean that you can see the rectangle of the entire display through the glass?  I have the same problem with mine in certain conditions, and I think you’ll find this to be a common issue as we try to keep the price down for this project.  Common screens are backlit in such a way that the whole screen is a source of light, even when displaying black.  I imagine an OLED display would not have this problem at all because it is not backlit in the same way as an LCD display, but the price of the display would likely be beyond what anyone is willing to pay to build their mirror.</p>
<p dir="auto">You can also try using a mirror that offers less light transmittance, but this also has the tradeoff of the display looking dimmer as a result.</p>
]]></description><link>https://forum.magicmirror.builders/post/52193</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52193</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Tue, 12 Feb 2019 17:56:14 GMT</pubDate></item><item><title><![CDATA[Reply to Glossy or Non-Glossy Display on Mon, 11 Feb 2019 21:12:23 GMT]]></title><description><![CDATA[<p dir="auto">I mean a non glossy was the better solution.</p>
]]></description><link>https://forum.magicmirror.builders/post/52143</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52143</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Mon, 11 Feb 2019 21:12:23 GMT</pubDate></item></channel></rss>
