<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[node serveronly]]></title><description><![CDATA[<p dir="auto">When I start with this “node serveronly” I become this:</p>
<p dir="auto">WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/Release/epoll.node’<br />
was compiled against a different Node.js version using<br />
NODE_MODULE_VERSION 57. This version of Node.js requires<br />
NODE_MODULE_VERSION 59. Please try re-compiling or re-installing<br />
the module (for instance, using <code>npm rebuild</code> or <code>npm install</code>).</p>
<p dir="auto">How to fix this?<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/9769/node-serveronly</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 13:07:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9769.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Feb 2019 21:06:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to node serveronly on Wed, 13 Feb 2019 11:41:13 GMT]]></title><description><![CDATA[<p dir="auto">The config.js seems to be OK<br />
My MM works fine with pm2 start mm,<br />
I just wanted to test it in server mode. And that’s just what it looks like!</p>
]]></description><link>https://forum.magicmirror.builders/post/52281</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52281</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Wed, 13 Feb 2019 11:41:13 GMT</pubDate></item><item><title><![CDATA[Reply to node serveronly on Wed, 13 Feb 2019 01:19:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robiv8" aria-label="Profile: robiv8">@<bdi>robiv8</bdi></a> said in <a href="/post/52142">node serveronly</a>:</p>
<p dir="auto">Could not load config file</p>
<p dir="auto">Tells me that you have a possible error in your config.js file…start there ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/52248</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52248</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 13 Feb 2019 01:19:08 GMT</pubDate></item></channel></rss>
