<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to start]]></title><description><![CDATA[<p dir="auto">Can anyone do me a favor and tell me step by step what has to be done in order get a Magic Mirror installed.<br />
Let’s assume that i have a RPi 3B+, drive with no Rasbian, nothing.<br />
Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9779/how-to-start</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 02:45:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9779.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Feb 2019 07:01:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 18:06:50 GMT]]></title><description><![CDATA[<p dir="auto">hey, after i cleared the whitelist and reboot the rpi, it works :) Thx you all =)</p>
<p dir="auto">The “Admin Tool” i ment was the module “MMM-Admin-Interface”</p>
<p dir="auto">now booth works :)</p>
<p dir="auto">Thanks a lot!! =)</p>
]]></description><link>https://forum.magicmirror.builders/post/68814</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68814</guid><dc:creator><![CDATA[Dodo88]]></dc:creator><pubDate>Thu, 30 Jan 2020 18:06:50 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 15:12:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> but thank you…  this got me thinking about my network… and sure enough the linux boxes added their names to the name server in the router… SO, I can use names  instead of numbers…</p>
<p dir="auto">My google wifi router does this better than my old TPLink router did…</p>
]]></description><link>https://forum.magicmirror.builders/post/68811</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68811</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 30 Jan 2020 15:12:10 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 14:22:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Guess you’re right. Thanks for highlighting. I may have changed the hostname manually at my main mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/68810</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68810</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 30 Jan 2020 14:22:56 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 14:46:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> said in <a href="/post/68808">How to start</a>:</p>
<p dir="auto"><a href="http://magicmirror" target="_blank" rel="noopener noreferrer nofollow ugc">http://magicmirror</a></p>
<p dir="auto">what is that?  none of my machines know where ‘magicmirror’ is located… (I have 6 different instances running, all installed from the same script)</p>
]]></description><link>https://forum.magicmirror.builders/post/68809</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68809</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 30 Jan 2020 14:46:44 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 14:23:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dodo88" aria-label="Profile: Dodo88">@<bdi>Dodo88</bdi></a> This is confusing me now.<br />
if you are</p>
<ul>
<li>
<p dir="auto">EITHER on the machine on which magicmirror is running on, you type:<br />
<code>http://localhost:8080</code></p>
</li>
<li>
<p dir="auto">OR on another machine, then you type:<br />
<code>http://192.168.178.33:8080</code> or <s><code>http://magicmirror:8080</code></s></p>
</li>
</ul>
<p dir="auto">And you need to do what <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said.</p>
]]></description><link>https://forum.magicmirror.builders/post/68808</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68808</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 30 Jan 2020 14:23:09 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 12:12:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dodo88" aria-label="Profile: Dodo88">@<bdi>Dodo88</bdi></a> said in <a href="/post/68800">How to start</a>:</p>
<p dir="auto">I’m new and could install the software, but i can’t connect to the mirror per localhost for the admin tool.</p>
<p dir="auto">there is no ‘admin’ tool on MagicMirror</p>
<p dir="auto">also, localhost mean the machine I’m on.   so if you are using a windows machine to connect to the mirror, and use localhost, that mean on the windows machine…</p>
<p dir="auto">in addition to what <a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> said, you also need to clear out the ipWhitelist to look like this</p>
<pre><code>ipWhitelist: []
<p dir="auto">which means ‘allow anyone to connect’</p>
]]></description><link>https://forum.magicmirror.builders/post/68806</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68806</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 30 Jan 2020 12:12:17 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 12:05:09 GMT]]></title><description><![CDATA[<p dir="auto">Hey :)</p>
<p dir="auto">No it doesn’t work :(</p>
<p dir="auto">I get this error by trying “<a href="http://192.168.178.33:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.178.33:8080</a>”</p>
<p dir="auto">"Die Website ist nicht erreichbar192.168.178.33 hat die Verbindung abgelehnt.<br />
Versuchen Sie Folgendes:</p>
<p dir="auto">Verbindung prüfen<br />
ERR_CONNECTION_REFUSED"</p>
<p dir="auto">Should i post my config.js?</p>
]]></description><link>https://forum.magicmirror.builders/post/68805</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68805</guid><dc:creator><![CDATA[Dodo88]]></dc:creator><pubDate>Thu, 30 Jan 2020 12:05:09 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 08:45:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dodo88" aria-label="Profile: Dodo88">@<bdi>Dodo88</bdi></a> No, you usually don’t need to do those things, the mirror should run by itself, but you need to use port 8080.</p>
<p dir="auto">Take care of the following:</p>
<ul>
<li>Go into your config.js and look for the “address” parameter. It needs to be<br />
<code>address: "0.0.0.0",</code></li>
<li>visit your mirror from your browser via: <code>http://localhost:8080</code><br />
If it doesn’t work, try visiting your mirror from another computer using: <code>http://magicmirror:8080</code><br />
-Report if it works :-)</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/68802</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68802</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 30 Jan 2020 08:45:37 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Thu, 30 Jan 2020 04:25:05 GMT]]></title><description><![CDATA[<p dir="auto">Hey together :)<br />
I’m new and could install the software, but i can’t connect to the mirror per localhost for the admin tool.<br />
Should i install apache2 and put the software to /var/www/html? Or can i run it without @ <a href="http://magicmirror" target="_blank" rel="noopener noreferrer nofollow ugc">http://magicmirror</a>?</p>
<p dir="auto">Greets :)<br />
Dodo</p>
]]></description><link>https://forum.magicmirror.builders/post/68800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68800</guid><dc:creator><![CDATA[Dodo88]]></dc:creator><pubDate>Thu, 30 Jan 2020 04:25:05 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Wed, 13 Feb 2019 08:52:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ganget" aria-label="Profile: ganget">@<bdi>ganget</bdi></a><br />
Very good guidance!</p>
]]></description><link>https://forum.magicmirror.builders/post/52279</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52279</guid><dc:creator><![CDATA[pukacz]]></dc:creator><pubDate>Wed, 13 Feb 2019 08:52:08 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Wed, 13 Feb 2019 08:47:53 GMT]]></title><description><![CDATA[<p dir="auto">There is a really nice <a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial">installation guide</a> from <a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> that will tell you every thing you need to know!</p>
]]></description><link>https://forum.magicmirror.builders/post/52278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52278</guid><dc:creator><![CDATA[ganget]]></dc:creator><pubDate>Wed, 13 Feb 2019 08:47:53 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Wed, 13 Feb 2019 08:43:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Thank You!</p>
]]></description><link>https://forum.magicmirror.builders/post/52276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52276</guid><dc:creator><![CDATA[pukacz]]></dc:creator><pubDate>Wed, 13 Feb 2019 08:43:20 GMT</pubDate></item><item><title><![CDATA[Reply to How to start on Wed, 13 Feb 2019 07:56:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pukacz" aria-label="Profile: pukacz">@<bdi>pukacz</bdi></a></p>
<ol>
<li>Install the latest Raspbian WITH desktop environment (but without recommended software) on your SD card <a href="https://www.raspberrypi.org/downloads/raspbian/" target="_blank" rel="noopener noreferrer nofollow ugc">from here</a></li>
<li>Fire up your RasPi 3B+, set up wifi or lan, SSH, and everything you would set up for a running Raspbian system (if you donÄt know why, you will first have to make yourself acquainted with Raspbian itself.</li>
<li>Open the console (directly on the RasPi or via ssh) and follow installation procedure given on <a href="https://github.com/MichMich/MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">github</a></li>
</ol>
<ol start="4">
<li>Enjoy!</li>
</ol>
<p dir="auto">Questions? Get back here :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/52270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52270</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 13 Feb 2019 07:56:15 GMT</pubDate></item></channel></rss>
